电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » MSP,TS430PZ100,rev 在哪里下载MSP-TS430PZ100 r
MSP,TS430PZ100,rev 在哪里下载MSP-TS430PZ100 rev:1.2的原理图?
2006-09-17 18:14:16     打赏
关键词: TS430PZ100     在哪里     下载     MSP-TS4
2006-12-22 22:43:00     打赏
问 买仿真器时配套的评估板的原理图哪里下啊?
板的编号:
找了www.ti.com没有,在IAR的
EW430_user_guide.pdf 里P189有提及:
HARDWARE INSTALLATION, MSP-FET430PXX0
('P120, 'P140, 'P410, 'P440)
1 Use the 25-conductor cable to connect the FET Interface module to the parallel port of
your PC.
2 Use the 14-conductor cable to connect the FET Interface module to the Target Socket
module.
3 Ensure that the MSP430 device is securely seated in the socket, and that its pin 1
(indicated with a circular indentation on the top surface) aligns with the 1 mark on the
PCB.
4 Ensure that the two jumpers (LED and Vcc) near the 2x7 pin male connector are in
place.
谢谢!:confused: 答 1: 找到了,谢谢!
在MSP430-FET user guide.pdf
