Project : transmit
Date : 2005-6-16
Comments: CAN发送子程序;
Chip type : ATmega128L
Clock frequency : 8.000000 MHz
#include <stdio.h>
#include <mega128.h>
#include <delay.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
#define unchar unsigned char
#define unint unsigned int
//SJA1000各寄存器的地址定义;
#define CAN_MODE *(volatile unsigned char *) 0X1100 //模式寄存器
#define CAN_CMR *(volatile unsigned char *) 0X1101 //命令寄存器
#define CAN_SR *(volatile unsigned char *) 0X1102 //状态寄存器
#define CAN_IR *(volatile unsigned char *) 0X1103 //中断寄存器
#define CAN_IER *(volatile unsigned char *) 0X1104 //中断使能寄存器
#define CAN_ALC *(volatile unsigned char *) 0X110B //仲裁丢失捕捉寄存器
#define CAN_ECC *(volatile unsigned char *) 0X110C //错误代码捕捉寄存器
#define CAN_EWLR *(volatile unsigned char *) 0X110D //错误报警限额寄存器
#define CAN_RXERR *(volatile unsigned char *) 0X110E //RX错误计数寄存器
#define CAN_TXERR *(volatile unsigned char *) 0X110F //TX错误计数寄存器
#define CAN_TXB *(volatile unsigned char *) 0X1110 //发送缓冲器
#define CAN_RXB *(volatile unsigned char *) 0X1110 //接收缓冲器
#define CAN_RMC *(volatile unsigned char *) 0X111D //RX报文计数器
#define CAN_RBSA *(volatile unsigned char *) 0X111E //RX缓冲器起始地址寄存器
#define CAN_BTR0 *(volatile unsigned char *) 0X1106 //总线时序寄存器0
#define CAN_BTR1 *(volatile unsigned char *) 0X1107 //总线时序寄存器1
#define CAN_OCR *(volatile unsigned char *) 0X1108 //输出控制寄存器
#define CAN_CDR *(volatile unsigned char *) 0X111F //时钟分频寄存器
#define CAN_ACR0 *(volatile unsigned char *) 0X1110 //验收代码寄存器0
#define CAN_ACR1 *(volatile unsigned char *) 0X1111 //验收代码寄存器1
#define CAN_ACR2 *(volatile unsigned char *) 0X1112 //验收代码寄存器2
#define CAN_ACR3 *(volatile unsigned char *) 0X1113 //验收代码寄存器3
#define CAN_AMR0 *(volatile unsigned char *) 0X1114 //验收屏蔽寄存器0
#define CAN_AMR1 *(volatile unsigned char *) 0X1115 //验收屏蔽寄存器1
#define CAN_AMR2 *(volatile unsigned char *) 0X1116 //验收屏蔽寄存器2
#define CAN_AMR3 *(volatile unsigned char *) 0X1117 //验收屏蔽寄存器3
#define CAN_0 *(volatile unsigned char *) 0X1110
#define CAN_1 *(volatile unsigned char *) 0X1111
#define CAN_2 *(volatile unsigned char *) 0X1112
#define CAN_3 *(volatile unsigned char *) 0X1113
#define CAN_4 *(volatile unsigned char *) 0X1114
#define CAN_5 *(volatile unsigned char *) 0X1115
#define CAN_6 *(volatile unsigned char *) 0X1116
#define CAN_7 *(volatile unsigned char *) 0X1117
#define CAN_8 *(volatile unsigned char *) 0X1118
#define CAN_9 *(volatile unsigned char *) 0X1119
#define CAN_10 *(volatile unsigned char *) 0X111a //直接往地址中写入要发送的标准帧的11个字节;
void CAN_INI(void);
// Get a character from the USART1 Receiver
#pragma used+
char getchar1(void)
char status1,data;
while (1)
while (((status1=UCSR1A) & RX_COMPLETE)==0);
data=UDR1;
if ((status1 & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
return data;
#pragma used-
// Write a character to the USART1 Transmitter
#pragma used+
void putchar1(char c)
while ((UCSR1A & DATA_REGISTER_EMPTY)==0);
UDR1=c;
#pragma used-
void main(void)
//unchar i;
//unchar *p;
//unchar status;
//static unchar transmit[11]={8,0,0,8,7,6,5,4,3,2,1};
SPH=0x07;
SPL=0xFF; //设置AVR堆栈为SP=0X0FFF;
MCUCR=0x80; //允许访问外部的SRAM;
XMCRA=0X00;
XMCRB=0X00;
CAN_INI(); //调用CAN初始化程序;
printf("CAN_SR_2=%x\n",CAN_SR); //读总线状态;
#asm("nop");
while(1)
do
printf("\nCAN_SR_3=%x\n",CAN_SR);
}while((CAN_SR&0x04)!=0x04); //等待总线状态正常;
#asm("nop");
printf("CAN_SR_4=%x\n", CAN_SR);
CAN_0=0x08;
#asm("nop");
printf("CAN_SR_5=%x\n", CAN_SR);
CAN_1=0x00;
#asm("nop");
printf("CAN_SR_6=%x\n", CAN_SR);
CAN_2=0x00;
#asm("nop");
printf("CAN_SR_7=%x\n", CAN_SR);
CAN_3=0x01;
#asm("nop");
printf("CAN_SR_8=%x\n", CAN_SR);
CAN_4=0x02;
#asm("nop");
printf("CAN_SR_9=%x\n", CAN_SR);
CAN_5=0x03;
#asm("nop");
printf("CAN_SR_10=%x\n", CAN_SR);
CAN_6=0x04;
#asm("nop");
printf("CAN_SR_11=%x\n", CAN_SR);
CAN_7=0x05;
#asm("nop");
//printf("CAN_SR_12=%x\n", CAN_SR);
CAN_8=0x06;
#asm("nop");
printf("CAN_SR_13=%x\n", CAN_SR);
CAN_9=0x07;
#asm("nop");
printf("CAN_SR_14=%x\n", CAN_SR);
CAN_10=0x08;
#asm("nop");
printf("CAN_SR_15=%x\n", CAN_SR);
CAN_CMR=0X01; //启动发送;
printf("\nCAN_SR_16=%x\n", CAN_SR);
#asm("nop");
delay_ms(1);
#asm("nop"); //发送后延时循环;
void CAN_INI(void)
// MCUCR=0X80; //允许外部存储器扩展,以便对SJA1000初始化;
#asm("cli"); //全局中断禁止;
#asm("nop");
CAN_MODE=0x09; //复位,单滤波器模式;用标准帧;
CAN_CDR=0X88; //采用Peli CAN; Clock out 不允许;
#asm("nop");
CAN_ACR0=0X00;
CAN_ACR1=0X00;
CAN_ACR2=0X00;
CAN_ACR3=0X00; //对验收代码寄存器进行设置;
CAN_AMR0=0XFF;
CAN_AMR1=0XFF;
CAN_AMR2=0XFF;
CAN_AMR3=0XFF; //对验收屏蔽寄存器进行设置;滤波11位ID和1位RTR标志,数据位不参加滤波;
//由设置可知AMR不进行任何屏蔽;
CAN_BTR0=0X03;
CAN_BTR1=0XFF; //设置波特率为80kbps,晶振为16M;
CAN_OCR=0XAA; //设置输出控制寄存器;
#asm("nop");
CAN_RBSA=0X00; //设置接收缓冲起始地址为0X00;
CAN_RXERR=0X00; //设置RX错误计数寄存器为0X00;
CAN_TXERR=0X00; //设置TX错误计数寄存器为0X00;
CAN_ECC=0X00; //设置错误代码捕捉寄存器为0X00;
CAN_MODE=0X08; //进入SJA1000的操作模式;
#asm("nop");
#asm("sei"); //开AVR全局中断;
printf("CAN_SR_1=%x\n", CAN_SR);
#asm("nop");
这是我用Atmega128和SJA1000搭的一个CAN节点的发送程序;
AVR和SJA1000的初始化都正常,现在的问题是:
在发送报文前,SJA1000的状态寄存器的值为:0X04(总线开启,发送缓冲器状态为释放)
在启动发送命令,发完一帧11个字节的标准帧报文后,状态寄存器的值变为:0X00(总线开启,发送缓冲器锁定)
循环发送报文时,状态寄存器的值却已变为:0XF4(总线关闭,发送缓冲器状态为释放)
为什么在发送第二条报文时总线就会关闭呢???????????
搞不清楚是怎么回事,请各位多多指教!!!!!!!!!!!!!!
wilson-pj@163.com
答 1: 也许你有错误帧!? 答 2: 继续请教chinawei97 CAN_CMR=0X01; //启动发送;
在我启动发送后,读总线状态变成0X00正常吗?应该是一个什么状态???它意味着:
总线状态开启; 错误状态正常;
发送状态空闲; 接收状态空闲;
发送完成状态 完成; 发送缓冲器状态 锁定;
数据溢出状态 未溢; 接收缓冲器状态 空;
延时后再发送相同的帧时,总线就关闭了。但是若将程序复位后再发送时,总线状态就变为0XF4,总线关闭了!!!!
答 3: 回复主题:CAN节点的调试问题总线上有其他节点吗? 答 4: 请教coleflyer 总线上没有其它的节点。
再发送报文的每一个字节时我都打印出SJA1000的状态寄存器的值结果直到置位发送命令前都还正常,值未0X04. 置位发送命令后总线状态寄存器的值就变为0X00。
Project : transmit
Date : 2005-6-16
Comments: CAN发送子程序;
#include <stdio.h>
#include <delay.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
//SJA1000各寄存器的地址定义;
void CAN_INI(void);
#pragma used+
char getchar1(void)
char status1,data;
while (1)
data=UDR1;
return data;
#pragma used-
#pragma used+
UDR1=c;
#pragma used-
void main(void)
//unchar i;
//unchar *p;
//unchar status;
SPH=0x07;
XMCRA=0X00;
XMCRB=0X00;
#asm("nop");
while(1)
do
#asm("nop");
CAN_0=0x08;
#asm("nop");
CAN_1=0x00;
#asm("nop");
CAN_2=0x00;
#asm("nop");
CAN_3=0x01;
#asm("nop");
CAN_4=0x02;
#asm("nop");
CAN_5=0x03;
#asm("nop");
CAN_6=0x04;
#asm("nop");
CAN_7=0x05;
#asm("nop");
CAN_8=0x06;
#asm("nop");
CAN_9=0x07;
#asm("nop");
CAN_10=0x08;
#asm("nop");
#asm("nop");
delay_ms(1);
void CAN_INI(void)
#asm("nop");
#asm("nop");
CAN_ACR0=0X00;
CAN_ACR1=0X00;
CAN_ACR2=0X00;
CAN_AMR0=0XFF;
CAN_AMR1=0XFF;
CAN_AMR2=0XFF;
//由设置可知AMR不进行任何屏蔽;
CAN_BTR0=0X03;
#asm("nop");
#asm("nop");
#asm("nop");
wilson-pj@163.com
总线状态开启; 错误状态正常;
发送状态空闲; 接收状态空闲;
| 2026年“我要开发板活动”第三季,开始了! | |
