RS485 关于RS485通信的问题
下面是我写的关于485通信的程序,主机能够发送一次数据,从机能够接收,从机接受后发送确认信息,这时侯主机接收不到数据.希望大虾帮我看看这个程序
主机程序:
RX_D EQU P3.0
TX_D EQU P3.1
N_RE EQU P3.4
DE EQU P3.5
under equ 30h ;30h为子机选择字
org 0000h
ajmp main
;org 0023h
;ajmp int_ser
org 0030h
main: mov tmod,#00101001b ;set timer 1 style 2; timer 0 style 1
mov scon,#50h ;serial style 2 data 8 t/r
mov tl1,#0fdh ;9600 at 11.059Mhz clock
mov th1,#0fdh
;setb es
setb tr1
mov pcon,#00h
setb ea
;acall delay_4ms
send:
;mov 30h,#01h
att1: setb de
mov sbuf,#0aah
awat1: jbc ti,arr1
sjmp awat1
arr1: clr p1.1
clr n_re
clr de
acall delay_4ms
brr1: jbc ri,arr2
sjmp brr1
arr2:mov a,sbuf
xrl a,#02h
jnz att1
att2: clr p1.0
sjmp $
DELAY_4ms: ;延时4ms
MOV R7,#08H
DEL2:MOV R6, #0FFh
DJNZ R6, $
DJNZ R7,DEL2
RET
del_1s:mov 50h,#200
dl0: mov 51h,#200
dl1: mov 52h,#200
djnz 52h,$
djnz 51h,dl1
djnz 50h,dl0
end
从机程序:
RX_D EQU P3.0
TX_D EQU P3.1
N_RE EQU P3.4
DE EQU P3.5
org 0000h
ajmp main
;org 0023h
;ajmp int_ser
org 0030h
mov th1,#0fdh
;setb es
setb tr1
mov pcon,#00h
setb ea
clr n_re
clr de
brr1: jbc ri,brr2
sjmp brr1
brr2:
mov a,sbuf
xrl a,#0aah
jnz brr1
;clr sm2
clr p1.0
btt1: setb de
mov sbuf,#0bbh
bwat1:jbc ti,brr3
sjmp bwat1
brr3: clr p1.1
sjmp $
DELAY_4ms: ;延时4ms
MOV R7,#08H
DEL2:MOV R6, #0FFh
DJNZ R6, $
DJNZ R7,DEL2
RET
END
答 1: 我的看法从机未发送数据。
发送数据前需加SETB N_RE
如果主从机之间需连续通讯,主机接收完数据后也应加SETB N_RE
顺便请问你做什么产品?
答 2: 关于RS485通信的问题做视频监控数据传输,多谢兄弟了
主机程序:
RX_D EQU P3.0
TX_D EQU P3.1
N_RE EQU P3.4
DE EQU P3.5
org 0000h
ajmp main
;org 0023h
;ajmp int_ser
org 0030h
mov th1,#0fdh
;setb es
setb tr1
mov pcon,#00h
setb ea
;acall delay_4ms
send:
;mov 30h,#01h
att1: setb de
mov sbuf,#0aah
awat1: jbc ti,arr1
sjmp awat1
arr1: clr p1.1
clr n_re
clr de
acall delay_4ms
brr1: jbc ri,arr2
sjmp brr1
arr2:mov a,sbuf
xrl a,#02h
jnz att1
att2: clr p1.0
sjmp $
DELAY_4ms: ;延时4ms
MOV R7,#08H
DEL2:MOV R6, #0FFh
DJNZ R6, $
DJNZ R7,DEL2
RET
del_1s:mov 50h,#200
dl0: mov 51h,#200
dl1: mov 52h,#200
djnz 52h,$
djnz 51h,dl1
djnz 50h,dl0
end
从机程序:
RX_D EQU P3.0
TX_D EQU P3.1
N_RE EQU P3.4
DE EQU P3.5
org 0000h
ajmp main
;org 0023h
;ajmp int_ser
org 0030h
mov th1,#0fdh
;setb es
setb tr1
mov pcon,#00h
setb ea
clr n_re
clr de
brr1: jbc ri,brr2
sjmp brr1
brr2:
mov a,sbuf
xrl a,#0aah
jnz brr1
;clr sm2
clr p1.0
btt1: setb de
mov sbuf,#0bbh
bwat1:jbc ti,brr3
sjmp bwat1
brr3: clr p1.1
sjmp $
DELAY_4ms: ;延时4ms
MOV R7,#08H
DEL2:MOV R6, #0FFh
DJNZ R6, $
DJNZ R7,DEL2
RET
END
答 1: 我的看法从机未发送数据。
发送数据前需加SETB N_RE
顺便请问你做什么产品?
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
