DSP2407 请教DSP2407高手关于定时器1的问题
我想利用定时器产生一个在一个周期中有多个脉宽,脉宽是变化的波形,脉宽是预先给定的.我编了个两个脉宽交替变化的程序(用C语言),仿真时用示波器看结果,不管我怎么改变定时器1的周期值,输出波形总是一样的,请问是不什么原因?我把程序贴在下面,请各位大侠帮帮我吧,谢谢!
#include "register.h"
//int T[2]={0x6000,0x8000};
void inline disable( )
asm(" setc INTM");
void inline enable( )
asm(" clrc INTM");
initial( )
asm(" setc SXM");
asm(" clrc OVM");
asm(" clrc CNF");
*(unsigned int*)SCSR1=0x81FE;
*(unsigned int*)WDCR=0x0E8;
*(unsigned int*)IMR=0x0002;
*(unsigned int*)IFR=0x0FFFF;
*(unsigned int*)WSGR=0x00;
*(unsigned int*)MCRA=*(unsigned int*)MCRA&0x0FF;
*(unsigned int*)PBDATDIR=*(unsigned int*)PBDATDIR|0x0FF00;
*(unsigned int*)PBDATDIR=*(unsigned int*)PBDATDIR&0x0FF00;
int timer1int( )
*(unsigned int*)EVAIMRA=*(unsigned int*)EVAIMRA|0x0080;
*(unsigned int*)EVAIFRA=*(unsigned int*)EVAIFRA|0x0080;
*(unsigned int*)T1CON=0x100C;
*(unsigned int*)T1PR=0x6000;
*(unsigned int*)T1CNT=0x00;
void interrupt T1INT( )
int flag,i=0,led;
flag=*(unsigned int*)EVAIFRA&0x0080;
if (flag!=0x0080)
enable( );
return;
i=i+1;
if(i<2)
led=0x00FE;
if (i==2)
i=0;
led=0x00FF;
enable( );
return;
void interrupt nothing( )
enable( );
return;
main( )
int led=0x00FF;
disable( );
initial( );
timer1int( );
enable( );
*(unsigned int*)T1CON=*(unsigned int*)T1CON|0x0040;
while(1)
*(unsigned int*)PBDATDIR=*(unsigned int*)PBDATDIR|led;
答 1: ...void interrupt T1INT( ) 中的变量 i ,有什么用,按照理解,你是不是想用全局变量,不然它永远不会是2 答 2: 回复主题:请教DSP2407高手关于定时器1的问题为什么不用PWM来实现呢? 答 3: 同意一楼的。定时器中的变量一般都是全局变量,否则每次进中端之后又从新初始化为0。
asm(" setc INTM");
asm(" clrc INTM");
initial( )
asm(" setc SXM");
asm(" clrc OVM");
asm(" clrc CNF");
int timer1int( )
int flag,i=0,led;
if (flag!=0x0080)
enable( );
return;
i=i+1;
if(i<2)
led=0x00FE;
if (i==2)
i=0;
led=0x00FF;
enable( );
return;
enable( );
return;
main( )
int led=0x00FF;
disable( );
initial( );
timer1int( );
enable( );
while(1)
