// State Machine
// download from: www.pld.com.cn & www.fpga.com.cn
module statmach(clk, in, reset, out);
input clk, in, reset;
output out;
reg out;
reg state;
parameter s0 = 0, s1 = 1;
always @(state)
begin
case (state)
s0:
out = 0;
s1:
out = 1;
default:
out = 0;
endcase
end
always @(posedge clk or posedge reset)
begin
if (reset)
state = s0;
else
case (state)
s0:
state = s1;
s1:
if (in)
state = s0;
else
state = s1;
endcase
end
endmodule
一个同步状态机Verilog HDL: Synchronous State Machine
This is a Verilog example that shows the implementation of a state machine.
The first CASE statement defines the outputs that are dependent on the value of the state machine variable state.
The second CASE statement defines the transitions of state machine and the conditions that control them.
download from: http://www.fpga.com.cn
statem.v
module statem(clk, in, reset, out);
output [3:0] out;
reg [3:0] out;
reg [1:0] state;
parameter zero=0, one=1, two=2, three=3;
always @(state)
begin
case (state)
zero:
out = 4'b0000;
one:
out = 4'b0001;
two:
out = 4'b0010;
three:
out = 4'b0100;
default:
out = 4'b0000;
endcase
end
begin
if (reset)
state = zero;
else
case (state)
zero:
state = one;
one:
if (in)
state = zero;
else
state = two;
two:
state = three;
three:
state = zero;
endcase
end
endmodule
用状态机设计的交通灯控制器//
// Copyright (c) 2000 Exemplar Logic Inc. All rights reserved.
// This is a typical example of a state machine description
// in Verilog HDL.
// Two always statements, one to update the state on a clock plus
// or reset, and one to calculate the next state and
// the outputs in a case statement
// This description implements a traffic light controller
// download from: www.fpga.com.cn & www.pld.com.cn
module traffic (clock, reset, sensor1, sensor2,
red1, yellow1, green1, red2, yellow2, green2);
input clock, reset, sensor1, sensor2;
output red1, yellow1, green1, red2, yellow2, green2;
// Define the states. Enumerated type pragma allows Spectrum to chose encoding.
parameter /*exemplar enum ee1 */ st0 = 0, st1 = 1, st2 = 2, st3 = 3,
st4 = 4, st5 = 5, st6 = 6, st7 = 7;
reg [2:0] /* exemplar enum ee1 */ state, nxstate ;
reg red1, yellow1, green1, red2, yellow2, green2;
// Update the state with the next state on the clock edge
// or reset value.
always @(posedge clock or posedge reset)
begin
if (reset)
state = st0 ;
else
state = nxstate;
end
// Calculate the next state and the outputs,
// based on the present state and the inputs
always @(state or sensor1 or sensor2)
begin
// Default values for the outputs
red1 = 1'b0; yellow1 = 1'b0; green1 = 1'b0;
red2 = 1'b0; yellow2 = 1'b0; green2 = 1'b0;
case (state) /* exemplar full_case */ /* exemplar parallel_case */
st0: begin
green1 = 1'b1;
red2 = 1'b1;
if (sensor2 == sensor1)
nxstate = st1;
else if (~sensor1 & sensor2)
nxstate = st2;
else
nxstate = st0;
end
st1: begin
green1 = 1'b1;
red2 = 1'b1;
nxstate = st2;
end
st2: begin
green1 = 1'b1;
red2 = 1'b1;
nxstate = st3;
end
st3: begin
yellow1 = 1'b1;
red2 = 1'b1;
nxstate = st4;
end
st4: begin
red1 = 1'b1;
green2 = 1'b1;
if (~sensor1 & ~sensor2)
nxstate = st5;
else if (sensor1 & ~sensor2)
nxstate = st6;
else
nxstate = st4;
end
st5: begin
red1 = 1'b1;
green2 = 1'b1;
nxstate = st6;
end
st6: begin
red1 = 1'b1;
green2 = 1'b1;
nxstate = st7;
end
st7: begin
red1 = 1'b1;
yellow2 = 1'b1;
nxstate = st0;
end
endcase
end
endmodule
Verilog HDL 程序举例--状态机举例:
关键词: Verilog 程序 举例 状态机 reset s
