library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity ggg is
port(clk:in std_logic;
outp0,outp1:out std_logic);
end entity ggg;
architecture bh of ggg is
begin
process(clk)
variable sum:std_logic_vector(1 downto 0);
begin
if rising_edge(clk)then
sum:=sum+1;
outp0<=sum(0);
outp1<=sum(1);
if sum=4 then
sum:="00";
end if;
end if;
end process;
end architecture bh;
VHDL手把手起步
关键词: 手把手 起步
library ieee;
entity ggg is
port(D,clk,clr:in std_logic;
Q:out std_logic);
end entity ggg;
architecture one of ggg is
begin
process(clk,D,clr)
begin
if clk'event and clk='1' then
if clr='1' then
Q<='0';
else
Q<=D;
end if;
end if;
end process;
end architecture one;
library ieee;
entity ggg is
Q:out std_logic);
end entity ggg;
begin
process(clk,D,clr)
begin
if clr='1' then
Q<='0';
elsif clk'event and clk='1' then
Q<=D;
end if;
end process;
-- 全减器 --
entity full_sub is
port(x, y : in bit;--std_logic;
sub_in : in bit;--std_logic;--低借位
diffr : out bit;--std_logic; --差
sub_out: out bit);--std_logic);--高借位
end entity full_sub;
architecture b of full_sub is
begin
process(x,y,sub_in) is
subtype std3bit is bit_vector(0 to 2);
begin
case std3bit'(x&y&sub_in) is
when "000" => diffr <= '0'; sub_out <= '0';
when "001" => diffr <= '1'; sub_out <= '1';
when "010" => diffr <= '1'; sub_out <= '1';
when "011" => diffr <= '0'; sub_out <= '1';
when "100" => diffr <= '1'; sub_out <= '0';
when "101" => diffr <= '0'; sub_out <= '0';
when "110" => diffr <= '0'; sub_out <= '0';
when "111" => diffr <= '1'; sub_out <= '1';
end case;
end process;
end architecture b;
--结构化描述
architecture str of full_sub is
signal tempD, tempC1,tempC2 :bit;
component half_sub
port(x, y : in bit;
d, c : out bit);
end component;
component orgate
port(x, y : in bit;
z : out bit);
end component;
begin
u0: half_sub port map(x,y,tempD,tempC1);
u1: half_sub port map(tempD,sub_in,diffr,tempC2);
u2: orgate port map(tempC1,tempC2,sub_out);
end architecture str;
--配置
configuration xw of full_sub is
for b
end for;
end configuration xw;
configuration jgh of full_sub is
for str
end for;
end configuration jgh;
--半减器
entity half_sub is
port(x,y : in bit;
d,c : out bit); --d 差,c 高借位
end entity half_sub;
architecture a of half_sub is
begin
process(x,y)
begin
d <= x xor y;
c <=(not x) and y;
end process;
end architecture a;
--或门
entity orgate is
port(x,y : in bit;
z : out bit);
end entity orgate;
architecture a of orgate is
begin
z<= x or y;
end architecture a;
library ieee;
entity bcdtoled is
port(bcd : in std_logic_vector(3 downto 0);
led : out std_logic_vector(6 downto 0));--(6:0 is a,b,c,d,e,f,g);
end entity bcdtoled;
architecture a of bcdtoled is
begin
with bcd select
led <= "1111110" when "0000",
"0110000" when "0001",
"1101101" when "0010",
"1111001" when "0011",
"0110011" when "0100",
"1011011" when "0101",
"1011111" when "0110",
"1110000" when "0111",
"1111111" when "1000",
"1111011" when "1001",
"1110111" when "1010",
"0011111" when "1011",
"1001110" when "1100",
"0111101" when "1101",
"1001111" when "1110",
"1000111" when "1111",
"0000000" when others;
end architecture a;
| 【FreeRtos】FreeRtos + MPU模块的配置使用被打赏¥32元 | |
| 【分享开发笔记,赚取电动螺丝刀】墨水屏文本显示器被打赏¥25元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取磁力计iis2mdc被打赏¥19元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取LPS22HH气压、温度被打赏¥19元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取STTS751温度被打赏¥17元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX软件读取HTS221温湿度被打赏¥22元 | |
| M5PAPERESP32EINKDEVKIT评测|使用MicroPython开发M5Paper被打赏¥15元 | |
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
