电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » s3c2410中usb device中寄存器定义的问题!
2007-05-22 02:34:59     打赏
// USB DEVICE
#ifdef __BIG_ENDIAN
<ERROR IF BIG_ENDIAN>
#define rFUNC_ADDR_REG (*(volatile unsigned char *)0x52000143) //Function address
#define rPWR_REG (*(volatile unsigned char *)0x52000147) //Power management
#define rEP_INT_REG (*(volatile unsigned char *)0x5200014b) //EP Interrupt pending and clear
#define rUSB_INT_REG (*(volatile unsigned char *)0x5200015b) //USB Interrupt pending and clear
#define rEP_INT_EN_REG (*(volatile unsigned char *)0x5200015f) //Interrupt enable
#define rUSB_INT_EN_REG (*(volatile unsigned char *)0x5200016f)
中<ERROR IF BIG_ENDIAN>是什么意思呢?干什么用的,不明白
关键词: s3c2410     device     寄存器     定义     问题
