[求助]请各位帮忙看看,编译uclinux时候的错误.
make[4]: Entering directory `/zyh/uClinux-dist/uClibc/libc/misc'
make -C assert
make[5]: Entering directory `/zyh/uClinux-dist/uClibc/libc/misc/assert'
arm-elf-gcc -Wall -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fstrict-aliasing -Os -O2 -g -fno-builtin -DEMBED -D__PIC__ -fpic -msingle-pic-base -I/zyh/uClinux-dist/lib/uClibc/include -I/zyh/uClinux-dist -Dlinux -D__linux__
-D__uClinux__ -Dunix -I/zyh/uClinux-dist/linux-2.4.x/include -fno-builtin -nostdinc -D_LIBC -I../../../include -I. -I/opt/uClinux/lib/gcc-lib/arm-elf/2.95.3/include -DNDEBUG -msoft-float -c __assert.c -o __assert.o
cc1: Invalid option `single-pic-base'
make[5]: *** [__assert.o] Error 1
make[5]: Leaving directory `/zyh/uClinux-dist/uClibc/libc/misc/assert'
make[4]: *** [_dir_assert] Error 2
make[4]: Leaving directory `/zyh/uClinux-dist/uClibc/libc/misc'
make[3]: *** [_dir_misc] Error 2
make[3]: Leaving directory `/zyh/uClinux-dist/uClibc/libc'
make[2]: *** [_dir_libc] Error 2
make[2]: Leaving directory `/zyh/uClinux-dist/uClibc'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/zyh/uClinux-dist/lib'
make: *** [subdirs] Error 1
这个错误如何解决啊 ?多谢!!!
关键词: 求助 各位 帮忙 看看 编译 uclinux 时候
uclinux启动时候 的错误哪位大虾指点一下该怎么解决!多谢!
Starting program: /zyh/skyeyedown/uClinux-dist/linux-2.4.x/linux
Linux version 2.4.19-uc1 (root@zyh) (gcc version 2.95.3 20010315 (release)) #8
五 8月 8 00:48:51 CST 2003
Processor: Atmel AT91M40xxx revision 0
Architecture: EB01
On node 0 totalpages: 1536
zone(0): 0 pages.
zone(1): 1536 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/rom0
Calibrating delay loop... 12.97 BogoMIPS
Memory: 6MB = 6MB total
Memory: 5244KB available (626K code, 157K data, 36K init)
Dentry cache hash table entries: 1024 (order: 1, 8192 bytes)
Inode cache hash table entries: 512 (order: 0, 4096 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 2048 (order: 1, 8192 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Atmel USART driver version 0.99
ttyS0 at 0xfffd0000 (irq = 2) is a builtin Atmel APB USART
ttyS1 at 0xfffcc000 (irq = 3) is a builtin Atmel APB USART
Blkmem copyright 1998,1999 D. Jeff Dionne
Blkmem copyright 1998 Kenneth Albanowski
Blkmem 1 disk images:
0: 1600000-15FFFFF [VIRTUAL 1600000-15FFFFF] (RO)
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 512 bind 512)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Blkmem: bad access: block=0, count=2 (pos=400, len=0)
end_request: I/O error, dev 1f:00 (Blkmem), sector 0
romfs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 1f:00
到这里就停止 了
[align=right][color=#000066][此贴子已经被作者于2003-8-8 17:02:13编辑过][/color][/align]
