我做了一个计数器,在两个信号的控制下启动和停止计数
并且在计数完成后,输出一个脉冲信号,如果clk直接接外部50M晶振的话,输出没有问题,但如果接PLL的话(甚至倍频到80M),计数完成后输出的脉冲就直接输出杂声(高频),请高手指教一二.....,谢谢!
module counter(clk_in,start,stop,rst,count_num,count_over);
input clk_in,start,stop,rst;
output[7:0] count_num;
output count_over;
reg count_over;
reg [7:0] count_num;
reg [32:0] count_over_wide;
reg [32:0] count_out_wide;
parameter pulsewide=80;
reg count_flag;
reg count_over_flag;
always@(negedge start or posedge stop or negedge rst)
begin
if(!rst)
count_flag<=0;
else if(stop)
begin
count_flag<=0;
end
else count_flag<=1;
end
always@(posedge clk_in )
begin
if(!rst)
begin
count_num<=0;
end
else if(count_flag==1)
begin
count_num<=count_num+1;
end
end
always@(posedge clk_in)
begin
if(!rst)
begin
count_over_flag<=0;
count_over_wide<=0;
count_over<=0;
end
else if((stop)&(!count_over_flag))
count_over_flag<=1;
else if(count_over_flag==1)
begin
if(count_over_wide<=pulsewide)
begin
count_over<=1;
count_over_wide<=count_over_wide+1;
end
else
begin
count_over_flag<=0;
count_over_wide<=0;
end
end
else
count_over<=0;
end
endmodule
