共9条
Rhapsody v4.1 MR2 (C) I-Logix
苘
圹圹 圮
?谀 捋圹?圹圹 哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪?
圹圹苘苘圹圹圹圹苘圹? - TEAM ROR presents - ?
捋圹圹圹圹圹圹圹圹哌 ?
捋哌 ? 圹郯郯 Rhapsody v4.1 MR2 (C) I-Logix ?
?圹圹捋舶 哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪?
圹圹 捋?苒? SUPPLIER: TEAM ROR PROGRAM TYPE: DEVELOPMENT?
圹圹?圹佰圹? CRACKER : TEAM ROR PROTECTION : FLEXLM ?
圹圹?圹圹圹? PACKAGER: TEAM ROR RELEASE TYPE: LICENSE ?
苒圹郯 圹圹郯 哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪?
苒圹圹? 圹圹? ROR PLATFORM: WIN32 RELEASE DATE: 08-20-2003 ?
苒圹圹郯 苒圹圹圹 苘郾?LANGUAGE: ENGLISH ARCHIVE NAME: RORILR41.R*?
圹圹圹郯 佰圹圹圹圹圹?FORMATS: BIN/CUE RELEASE SIZE: 18 x 15MB ?
佰圹卑 滥哪? 圹圹圹圹郾澳哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪馁
圹圹圹脖?
圹鄄卑
谀哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪?
?氨槽 RELEASE INFORMATION ?
滥哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪?
Traditional system and software development is commonly divided in
two main areas: front-end analysis and design, and back-end
implementation and test, strung together serially. CASE tools were
originally created to automate the planning and analysis phase. While
some of these tools provided some design capture ability, and minimal
code frame generation, none linked the design to the implementation
and the documentation. This disconnect continues today in that as
soon as the requirements specifications are handed down, the system
architecture begins to deviate from the specifications. Most often
this is because the requirements are ambiguous, consequently, these
propagations are handed down into further phases of development. If
that isn't enough, as soon as coding begins, the implementation more
often than not diverges from the design documentation, introducing
another disconnect, increasing project risk, lowering overall system
quality and maintainability, and lengthening the development
lifecycle. Equally, since CASE tools were oblivious to behavior, they
did nothing to solve the trauma of system integration. Since behavior
is unknown until system integration, this phase is normally a hot
spot in the development life cycle. It only gets worse when the
pressure to increase functionality, improve quality and keep to
schedule with fewer resources drives development teams to take risky
short-cuts in attempts to recover time. Whether the team is
disciplined or in free fall, one thing is certain, waiting until the
end of the development cycle to first address behavior adds
incredible risk to the process. It is odd that chip designs are
validated continually during the development process while software
validation is postponed until the very end. It is no wonder that
hardware design productivity improves at a high rate while software
productivity is stuck at essentially the same level year after year.
Rhapsody reverses the traditional design process, allowing you to
find problems as they occur, versus waiting until the very end when
they are far more costly to correct. Rhapsody provides a
collaborative Model-Driven Development (MDD) environment for system
and software engineers enabling you to work in an iterative fashion
where you can quickly analyze and make rapid system and software
design changes, generate an application and test the ramifications of
your changes quickly and efficiently, up front. Decisions are
validated as they are made through constant and consistent testing
while designing. You do not wait for systems integration to validate
your design decisions. Instead, you iterate and validate continually,
all the while building new functionality on top of proven behavior so
that when you are done, you are really done, saving development time,
energy and expense.
For more information:
http://www.ilogix.com
?氨槽 INSTALL NOTES ?
Unpack and Burn, look into /crack folder for install info.
Enjoy this fine release from TEAM ROR :)
?氨槽 TEAM ROR AGREEMENTS ?
Attention: Please read these terms carefully before using our
release. Using our release indicates that you have read and accepted
these agreements. If you do not agree to accept these terms, do not
use our release or infomation from it. We may change the terms of
this Agreement at any time.
YOU MAY USE OUR RELEASE FOR EVALUATION PRUPOSES ONLY. WE WILL NOT BE
HELD RESPONSIBLE FOR OUR RELEASE. IF YOU LIKE THIS SOFTWARE, YOU'RE
STRONGLY ADVISED TO BUY IT. SOFTWARE COMPANIES NEED SUPPORT FOR
QUALITY PRODUCTS. YOU MAY NOT USE OUR RELEASE TO MAKE MONEY OR USE IT
FOR COMMERCIAL PURPOSE.
?氨槽 TEAM ROR NEWS ?
We have changed our email address, Please find at bottom of the page.
Wanna Join? Getting In Touch With Us If...
- You are familiar with commercial protections (Flexlm,Dongle,etc...)
- You can do keygen for generic software
- You can supply unreleased quality softwares
?氨槽 TEAM ROR GREETS ?
TEAM ROR send GREETS to:
All groups who bring releases of high quality to the scene.
?氨槽 CONTACT INFORMATION ?
Contact Us: RORteam[at]hotbox[dot]ru
关键词: Rhapsody I-Logix 圹圹 哪哪
共9条
| 有奖活动 | |
| 这个春节你犒赏自己什么了?分享你的故事,有奖征集 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
| OK1126B-S开发板的脚本编程及应用设计被打赏¥27元 | |
| 5v升压8.4v两节锂电池充电芯片,针对同步和异步的IC测试被打赏¥35元 | |
| 【S32K3XX】S32DS LPI2C 配置失败问题解决被打赏¥22元 | |
| 【S32K3XX】FLASH 的 DID 保护机制被打赏¥19元 | |
| OK1126B-S开发板串口通信及其使用被打赏¥18元 | |
| 【S32K3XX】多核 CORE ID 获取被打赏¥18元 | |
| OK1126B-S开发板的GPIO资源及其使用被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】三分钟快速上手驱动屏幕(Arduino IDE环境)被打赏¥23元 | |
