电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » halibote523使用手记(从安装到程序编写)
共88条 4/9 |‹ ‹ 2 3 4 5 6 7 › ›| 跳转至页
2010-10-17 18:51:40     打赏
31楼
自己复制的!!SRC文件夹里面包含了一些文件!
MB95200 head files.rar
2010-10-17 22:17:09     打赏
32楼
今晚和明晚介绍AD的采集
寄存器的介绍:ADC1
2010-10-17 22:17:58     打赏
33楼
ADC2:
2010-10-17 22:19:17     打赏
34楼
ADCH与ADCL:(数据位由8位或者是10位决定)
2010-10-17 22:25:56     打赏
35楼
AD转换的设置步骤:
1、设置输入口DDR1
2、设定中断级别ILR4
3、使能AD输入ADC2:ANS0--ANS3
4、设定采样时间ADC2:TIM1--TIM0
5、选择时钟ADC2:CKDIV1  CKDIV0
6、设定AD转换精度ADC2:AD8
7、选择操作模式ADC2:EXT
8、选择启动触发ADC2:ADCK
9、使能中断ADC2:ADIE=1
10、激活AD转换器ADC1:AD=1
中断处理:
1、ADC1:AD1=0
2、读取转换值ADDH、ADDL
3、激活AD转换器ADC1:AD=1
2010-10-17 22:27:24     打赏
36楼
程序1:查询方式::::::::::::::::::
LIN_UART_Syn.rar
#include "mb95200.h"
int ADVoltage=0x01;
void UART_chars(unsigned char cdata);
void UART_init (void)
 BGR1 = 0x00;  // Reloadvalue = 0d51 = 0x33 (500KHz, 9600Baud)
 BGR0 = 0x33;  // Reloadvalue = 0x33 = 0x00<<8 + 0x33 (500KHz, 9600Baud)
 SMR = 0x87;     // enable SOT, Reset, synchronous mode
 SSR = 0x00;     // clear flags, no interrupt
 ECCR_SSM = 1;    // have ST/STP bit
 SCR = 0xc3;     // enable transmit, Odd parity
char UART_readbyte (void)
 while (! SSR_RDRF);   // wait, until a byte is received
 return (RDR_TDR);    // return the received byte
void delay(unsigned int i)
   unsigned int m,n;
   for(m=0;m<i;m++)
     for(n=0;n<6000;n++)
       asm("\tNOP");
void UART_sendbyte (char ch)
 while (! SSR_TDRE);
 RDR_TDR = ch;     //transmit data
void UARTPut(const char *data,unsigned char len)
    unsigned char i;
    for(i=0; i<len; i++) UART_sendbyte(data[i]);
    unsigned char i;
    i=cdata>>4;
    if(i>=0 && i<=9) UART_sendbyte(i+0x30);
    else             UART_sendbyte(i+0x37);
    i=cdata & 0x0F;
void InitADC(void)
    ADC2 = 0x81;                // 8-bit resolution, enable interrupts
    ADC1 = 0x01;                // AN0 pin as input, start AD
void AD_Sample (void)
    ADVoltage=ADD_ADDL;
    ADC1=0x01;
    //ADC2 = 0x81;
FUNCTION: synchronously transmit a byte or receive a byte
void main (void)
 //unsigned char rec_data = 0;
   DDR0_P00 = 0;        //P00 intput
   //DDR0_P05 = 1;         //P05 output
   //DDR0_P06 = 0;        //P06 input
   DDR0_P03 = 1;        //P03 output
   DDR0_P04 = 0;        //P04 input
   AIDRL = 0xfe;       //Port input enabled
   PDR0_P00 = 0x00;
   //PDR0_P05 = 0x01;
   UART_init ();
   InitIrqLevels();            // initialise Interrupt level register and IRQ vector table
    __EI();                     // global interrupt enable
    //__set_il(3);                // set global interrupt mask to allow all IRQ levels
    InitADC();                  // init AD - converte
    while (1)
  asm("\tNOP");
  //UART_sendbyte(0xaa);
  delay(10);
  UARTPut("ADVal:",7);
  //DDR0_P00 = 0;
  //delay(1);
  AD_Sample();
  UART_chars(ADVoltage);
  UARTPut("\n",2);
  //rec_data = UART_readbyte ();
  asm("\tNOP");
  asm("\tNOP");
2010-10-17 22:31:00     打赏
37楼
转换的值为:
AD的引脚接到地线时:采集的电压是:(00~=0V)
AD引脚悬空的采集电压是:(96~=2.94V)
2010-10-17 22:36:04     打赏
38楼
程序2:中断方式::::::::::::::::::
int ADVoltage=0x01;
   unsigned int m,n;
   for(m=0;m<i;m++)
     for(n=0;n<6000;n++)
       asm("\tNOP");
 while (! SSR_TDRE);
    unsigned char i;
    unsigned char i;
    i=cdata>>4;
    i=cdata & 0x0F;
void InitADC(void)
__interrupt void ISR_ADC (void)
    ADVoltage=ADD_ADDL;                            // voltage calculating
    ADC1=0x01;                           // clear interrupt flag, start AD again
void main (void)
   PDR0_P00 = 0x00;
   //PDR0_P05 = 0x01;
   UART_init ();
    while (1)
  asm("\tNOP");
  delay(10);
  //DDR0_P00 = 0;
  //delay(1);
  UARTPut("\n",2);
  asm("\tNOP");
  asm("\tNOP");
在Vector文件::
1、ILR4 = 0xDF;
2、
__interrupt void DefaultIRQHandler (void);
__interrupt void ISR_ADC (void);
3、
修改:#pragma intvect ISR_ADC 18
2010-10-18 09:18:11     打赏
39楼
应用的场合不一样,书写程序的方法也不一样!!不在于中断或者是查询,在于能够对AD转换器原理的理解
2010-10-18 19:21:22     打赏
40楼
外部中断测试:
中断请求号  中断级设置寄存器  中断源
IRQ0             L00【1:0】           外部中断ch4
IRQ1             L01【1:0】           外部中断ch5
IRQ2             L02【1:0】           外部中断ch2、ch6
IRQ3             L03【1:0】           外部中断ch7
外部中断电路0注意事项:
1、边缘极性选择位SL值位过程中,使中断请求位EIE清0(禁止中断请求),设定边缘极性后,外部中断请求标志位EIR清0
2、若外部中断请求标志位置1,且使能中断中断请求使能位,操作不能从中断服务例程中回复,必须始终清理中断服务例程中的外部中断请求使能位
