写文件老有问题,明明设置的是从头开始写,结果还是添加到原文件后边,不知道怎么回事,请教高手,以下是代码
static void WriteFile(void)
VMUINT nSize = 0;
VMWCHAR wFileName[40];
VMFILE file;
vm_ascii_to_ucs2(wFileName, 40, g_FileName);
file = vm_file_open(wFileName, MODE_CREATE_ALWAYS_WRITE, FALSE);
if( 0 > file )
vm_log_debug( "Create file failure");
else
vm_log_debug( "Create file success");
if( vm_file_getfilesize(file, &nSize) )
vm_log_debug( "get file size failure\n");
vm_file_close(file);
return;
if( vm_file_seek( file, 0, BASE_BEGIN) )// BASE_BEGIN BASE_CURR BASE_END
vm_log_debug ( "设置文件指针错误" );
return;
else
vm_log_debug ( "设置文件指针成功" );
nSize = vm_file_write(file, g_Text, strlen(g_Text), &nSize);//修改
if( !nSize )
vm_log_debug ( " write file failure" );
else
vm_log_debug ( "write file success" );
另外,还有读文件的时候,文件太长就出错,不管length的参数传多少?都不管用,怎么回事?
| OrangePiZero2W系统被打赏¥33元 | |
