之前在这问过几个问题,都得到解答了,很感谢这里朋友,虽然素未谋面。呵呵,
我在使3E开发板里的AD,写了个程序。但是总也调不出来。我自己觉得可能是时序方面没没理解好。把程序贴上,希望大家帮我看下,哪里有问题,让我能调出AD来,谢谢了/
module adc(clk,reset,spi_miso,amp_cs,amp_shdn,spi_mosi,ad_conv,spi_sck,x);
input clk,reset;
input spi_miso; //AD变换后输出的数据
output amp_cs,amp_shdn,ad_conv,spi_sck;
output spi_mosi; //8位可编程增益
output x;
reg spi_mosi;
reg amp_cs,ad_conv,amp_shdn;
reg [1:0]counter1;
always@(posedge clk or posedge reset)
begin
if(reset)
begin
counter1<=2'd0;
end
else
begin
if(counter1==2'd2)
begin
counter1<=2'd0;
end
else
begin
counter1<=counter1+1;
end
end
end
reg spi_sck;
begin
if(reset)
spi_sck<=1'b0;
else
begin
if(counter1==2'd2)
spi_sck<=1'b1;
else
spi_sck<=1'b0;
end
end
reg [9:0]delay_count;
reg [9:0]num_count;
parameter state1 =6'b000001;
parameter state2 =6'b000010;
parameter state3 =6'b000011;
parameter state4 =6'b000100;
parameter state5 =6'b000101;
parameter state6 =6'b000110;
parameter state7 =6'b000111;
parameter state8 =6'b001000;
parameter state9 =6'b001001;
parameter state10=6'b001010;
parameter state11=6'b001011;
parameter state12=6'b001100;
parameter state13=6'b001101;
parameter state14=6'b001110;
reg[5:0]state; //状态信号
reg state_change; //状态改变信号
if(reset)
begin
state_change<=1'b0;
delay_count<=1'b0;
end
else
if(delay_count==num_count-1)
begin
state_change<=1'b1;
delay_count<=1'b0;
end
else
begin
state_change<=1'b0;
delay_count<=delay_count+1'b1;
end
reg[13:0]data1;
reg[3:0]count2;
reg[13:0]rcv_data;
always@(posedge state_change or posedge reset)
if(reset)
begin
state<=state1;
num_count<=10'd4;
data1<=14'd0;
count2<=4'd0;
rcv_data<=14'b0111_1111_1111_11;
end
else
case(state)
state1:begin
state<=state2;
num_count<=10'd2;
amp_cs<=1'b1;
amp_shdn<=1'b1;
ad_conv<=1'b1;
end
state2:begin
state<=state3;
num_count<=10'd60;
amp_cs<=1'b0;
amp_shdn<=1'b0;
ad_conv<=1'b1;
end
state3:begin //spi-mosi八位增益
state<=state4;
num_count<=10'd5;
spi_mosi<=1'h0;
ad_conv<=1'b1;
end
state4:begin
state<=state5;
num_count<=10'd5;
spi_mosi<=1'h0;
ad_conv<=1'b1;
end
state5:begin
state<=state6;
num_count<=10'd5;
spi_mosi<=1'h0;
ad_conv<=1'b1;
end
state6:begin
state<=state7;
num_count<=10'd5;
spi_mosi<=1'h1;
ad_conv<=1'b1;
end
state7:begin
state<=state8;
num_count<=10'd5;
spi_mosi<=1'h0;
ad_conv<=1'b1;
end
state8:begin
state<=state9;
num_count<=10'd5;
spi_mosi<=1'h0;
ad_conv<=1'b1;
end
state9:begin
state<=state10;
num_count<=10'd5;
spi_mosi<=1'h0;
ad_conv<=1'b1;
end
state10:begin
state<=state11;
num_count<=10'd5;
spi_mosi<=1'h1;
ad_conv<=1'b1;
end //spi-mosi八位增益
state11:begin
state<=state12;
num_count<=10'd4;
amp_cs<=1'b1;
amp_shdn<=1'b1;
ad_conv<=1'b0;
end
state12:begin
state<=state13;
num_count<=10'd202;
if(count2==13)
begin
rcv_data<=data1;
count2<=4'd0;
end
else
begin
data1<={spi_miso,data1[13:1]};
count2<=count2+1;
end
end
state13:begin
state<=state14;
num_count<=10'd2;
ad_conv<=1'b1;
amp_cs<=1'b1;
amp_shdn<=1'b1;
end
state14:begin
state<=state11;
num_count<=10'd4;
end
default:begin
state<=state1;
num_count<=10'd4;
end
endcase
reg x;
begin
if(reset)
x<=1'b0;
else
x<=rcv_data[13];
end
endmodule
我只用了rcv_data[13];,其他的没有使用。
共10条
sparten 3e,AD的使用问题。听说标题要很长····
简单看了一下。现在手头没有Sparten 3E的板,没法帮你验证。
提出以下一些建议:
1. 状态机的写法不好,可参考“三段式”写法,我以前发过,论坛上有;
2. 这段代码
state12:begin
state<=state13;
num_count<=10'd202;
if(count2==13)
begin
rcv_data<=data1;
count2<=4'd0;
end
else
begin
count2<=count2+1;
end
end
我觉得你的本意是连续读出spi_miso,但你的程序不是这样的,因为读取一个后即可跳转到state13;
还有不明白为什么要设置一个可变的 num_count,并用state_change 作为时钟,这些写法都不好
一般用状态机实现,先把配置、读取等状态列清楚。
一般是大状态套小状态的方式实现。
像这种设计SPI时序接口的东西,一般在小状态中用Counter来计数就可以了,没必要再parameter状态。
共10条
