#include<reg52.h>
#include <intrins.h>
#define uint unsigned int
#define uchar unsigned char
uchar temp,num,num1;
sbit beep=P2^3;
void delay(uint);
void main()
temp=0xfe;
while(1)
for(num1=0;num1<3;num1++)
for(num=0;num<8;num++)
P1=temp;
beep=0;
delay(100);
temp=_crol_(temp,1);
P1=0xff;
beep=1;
delay(100);
P1=temp;
beep=0;
delay(100);
temp=_cror_(temp,1);
P1=0xff;
beep=1;
delay(100);
while(1);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
sbit beep=P2^3;
void delay(uint);
void main()
temp=0xfe;
while(1)
P1=temp;
beep=0;
delay(100);
P1=0xff;
beep=1;
delay(100);
P1=temp;
beep=0;
delay(100);
P1=0xff;
beep=1;
delay(100);
while(1);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
矩阵键盘的代码
#include <reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,
0x76,0x79,0x38,0x3f,0};
uchar temp,t0,t1,bai,shi,ge,flag,flag1;
uint shu;
void init();
void display(uchar,uchar,uchar,uchar,uchar,uchar);
void delay(uint z)
uint t1,y;
for(t1=z;t1>0;t1--)
for(y=110;y>0;y--);
void main()
init();
while(1)
if(flag1!=1)
display(7,6,5,bai,shi,ge);
else
display(16,17,18,18,19,20);
void init()
shu=432;
temp=0xfe;
P1=temp;
TMOD=0x11;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
EA=1;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
void timer0() interrupt 1
t0++;
if(flag!=1)
if(t0==10)
t0=1;
P1=temp;
else
if(t0%4==0)
P1=~P1;
if(t0==60)
TR0=0;
P1=0xff;
flag1=1;
void timer1() interrupt 3
t1++;
if(t1==2)
t1=0;
shu--;
bai=shu/100;
shi=shu%100/10;
ge=shu%10;
if(shu==398)
TR0=0;
TR0=1;
flag=1;
t0=0;
P1=0xff;
TR1=0;
void display(uchar aa,uchar bb,uchar cc,uchar ba,uchar sh,uchar g)
dula=1;
P0=table[aa];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delay(1);
dula=1;
P0=table[bb];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delay(1);
dula=1;
P0=table[cc];
dula=0;
P0=0xff;
wela=1;
P0=0xfb;
wela=0;
delay(1);
dula=1;
P0=table[ba];
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delay(1);
dula=1;
P0=table[sh];
dula=0;
P0=0xff;
wela=1;
P0=0xef;
wela=0;
delay(1);
dula=1;
P0=table[g];
dula=0;
P0=0xff;
wela=1;
P0=0xdf;
wela=0;
delay(1);
#include <reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
uint shu;
void init();
void delay(uint z)
uint t1,y;
for(t1=z;t1>0;t1--)
for(y=110;y>0;y--);
void main()
init();
while(1)
if(flag1!=1)
else
void init()
shu=432;
temp=0xfe;
P1=temp;
TMOD=0x11;
EA=1;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
t0++;
if(flag!=1)
if(t0==10)
t0=1;
P1=temp;
else
if(t0%4==0)
P1=~P1;
if(t0==60)
TR0=0;
P1=0xff;
flag1=1;
t1++;
if(t1==2)
t1=0;
shu--;
bai=shu/100;
shi=shu%100/10;
ge=shu%10;
if(shu==398)
TR0=0;
TR0=1;
flag=1;
t0=0;
P1=0xff;
TR1=0;
dula=1;
P0=table[aa];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delay(1);
dula=1;
P0=table[bb];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delay(1);
dula=1;
P0=table[cc];
dula=0;
P0=0xff;
wela=1;
P0=0xfb;
wela=0;
delay(1);
dula=1;
P0=table[ba];
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delay(1);
dula=1;
P0=table[sh];
dula=0;
P0=0xff;
wela=1;
P0=0xef;
wela=0;
delay(1);
dula=1;
P0=table[g];
dula=0;
P0=0xff;
wela=1;
P0=0xdf;
wela=0;
delay(1);
串口通信代码
#include<reg52.h>
unsigned char flag,a;
void main()
TMOD=0x20;//设置定时器1为工作方式2
TH1=0xfd;
TL1=0xfd;
TR1=1;
REN=1;
SM0=0;
SM1=1;
EA=1;
ES=1;
while(1)
/* if(RI==1)
RI=0;
P1=SBUF;
if(flag==1)
ES=0;
flag=0;
SBUF='1';//28;
while(!TI);
TI=0;
SBUF='2';//28;
while(!TI);
TI=0;
SBUF='3';//28;
while(!TI);
TI=0;
ES=1;
void ser() interrupt 4
RI=0;
// P1=SBUF;
a=SBUF;
flag=1;
#include<reg52.h>
void main()
TH1=0xfd;
TL1=0xfd;
TR1=1;
REN=1;
SM0=0;
SM1=1;
EA=1;
ES=1;
while(1)
/* if(RI==1)
RI=0;
P1=SBUF;
if(flag==1)
ES=0;
flag=0;
SBUF='1';//28;
while(!TI);
TI=0;
SBUF='2';//28;
while(!TI);
TI=0;
SBUF='3';//28;
while(!TI);
TI=0;
ES=1;
RI=0;
// P1=SBUF;
a=SBUF;
flag=1;
| 有奖活动 | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| SWM221CBT7显示开发板及其使用被打赏¥20元 | |
| 揭秘Chaos-nano:ArduinoProMini轻量级操作系统开发框架深度解析与实战应用被打赏¥19元 | |
