电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » Patterson的MCU进程----DS18B20温度传感器实时温度显示
共6条 1/1 1 跳转至页
2011-12-25 11:55:04     打赏
利用DS18B20检测实时温度,并通过数码管显示,常温为14~15度,用手捂住传感器后温度上升,放开手后温度下降。程序如下:
#include <reg52.H>
extern GetTemp();
extern unsigned int  idata Temperature;
void delay(unsigned int i);
//else IO
sbit    LS138A=P2^0;       //管脚定义
sbit    LS138B=P2^1;
sbit    LS138C=P2^2;
//此表为 LED 的字模, 共阴数码管 0-9  -
unsigned char code Disp_Tab[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};
unsigned long  LedOut[5],LedNumVal;
void system_Ini()
    TMOD|= 0x11;
    TH1 = 0xD8;    //10
    TL1 = 0xF0;
 IE = 0x8A;
    TR1  = 1;
main()
{ unsigned char i;
  system_Ini();
    while(1)
   GetTemp();
          LedNumVal=Temperature;      //把实际温度送到LedNumVal变量中
   LedOut[0]=Disp_Tab[LedNumVal%10000/1000];
      LedOut[1]=Disp_Tab[LedNumVal%1000/100];
      LedOut[2]=Disp_Tab[LedNumVal%100/10];  //十位
      LedOut[3]=Disp_Tab[LedNumVal%10];    //个位
    for(i=0; i<4; i++)
   P0 = LedOut[i] ;
  switch(i)
           case 0:LS138A=0; LS138B=0; LS138C=0; break;
            case 1:LS138A=1; LS138B=0; LS138C=0; break;
            case 2:LS138A=0; LS138B=1; LS138C=0; break;
            case 3:LS138A=1; LS138B=1; LS138C=0; break;
  delay(100);
   P0 = 0;
 //延时程序
    char j;
    for(i; i > 0; i--)
        for(j = 200; j > 0; j--);
 /*************************此部分为18B20的驱动程序*************************************/
#include <reg52.H>
#include <intrins.h>
sbit    D18B20=P1^3;
#define  NOP()   _nop_()
#define  _Nop()  _nop_()
void TempDelay (unsigned char idata us);
void Init18b20 (void);
void WriteByte (unsigned char idata wr);  //单字节写入
void read_bytes (unsigned char idata j);
unsigned char CRC (unsigned char j);
void GemTemp (void);
void Config18b20 (void);
void ReadID (void);
void TemperatuerResult(void);
bit  flag;
unsigned char idata temp_buff[9]; //存储读取的字节,read scratchpad为9字节,read rom ID为8字节
unsigned char idata id_buff[8];
unsigned char idata *p,TIM;
unsigned char idata crc_data;
unsigned char code CrcTable [256]={
0,  94, 188,  226,  97,  63,  221,  131,  194,  156,  126,  32,  163,  253,  31,  65,
157,  195,  33,  127,  252,  162,  64,  30,  95,  1,  227,  189,  62,  96,  130,  220,
35,  125,  159,  193,  66,  28,  254,  160,  225,  191,  93,  3,  128,  222,  60,  98,
190,  224,  2,  92,  223,  129,  99,  61,  124,  34,  192,  158,  29,  67,  161,  255,
70,  24,  250,  164,  39,  121,  155,  197,  132,  218,  56,  102,  229,  187,  89,  7,
219,  133, 103,  57,  186,  228,  6,  88,  25,  71,  165,  251,  120,  38,  196,  154,
101,  59, 217,  135,  4,  90,  184,  230,  167,  249,  27,  69,  198,  152,  122,  36,
248,  166, 68,  26,  153,  199,  37,  123,  58,  100,  134,  216,  91,  5,  231,  185,
140,  210, 48,  110,  237,  179,  81,  15,  78,  16,  242,  172,  47,  113,  147,  205,
17,  79,  173,  243,  112,  46,  204,  146,  211,  141,  111,  49,  178,  236,  14,  80,
175,  241, 19,  77,  206,  144,  114,  44,  109,  51,  209,  143,  12,  82,  176,  238,
50,  108,  142,  208,  83,  13,  239,  177,  240,  174,  76,  18,  145,  207,  45,  115,
202,  148, 118,  40,  171,  245,  23,  73,  8,  86,  180,  234,  105,  55,  213, 139,
87,  9,  235,  181,  54,  104,  138,  212,  149,  203,  41,  119,  244,  170,  72,  22,
233,  183,  85,  11,  136,  214,  52,  106,  43,  117,  151,  201,  74,  20,  246,  168,
116,  42,  200,  150,  21,  75,  169,  247,  182,  232,  10,  84,  215,  137,  107,  53};
 while(us--);
 D18B20=1;
 _nop_();
 D18B20=0;
 TempDelay(80);   //delay 530 uS//80
 _nop_();
 D18B20=1;
 TempDelay(14);   //delay 100 uS//14
 _nop_();
 _nop_();
 _nop_();
 if(D18B20==0)
  flag = 1;   //detect 1820 success!
 else
  flag = 0;    //detect 1820 fail!
 TempDelay(20);       //20
 _nop_();
 _nop_();
 D18B20 = 1;
void WriteByte (unsigned char idata wr)  //单字节写入
 unsigned char idata i;
 for (i=0;i<8;i++)
  D18B20 = 0;
  _nop_();
  D18B20=wr&0x01;
  TempDelay(3);   //delay 45 uS //5
  _nop_();
  _nop_();
  D18B20=1;
  wr >>= 1;
unsigned char ReadByte (void)     //读取单字节
 unsigned char idata i,u=0;
 for(i=0;i<8;i++)
  D18B20 = 0;
  u >>= 1;
  D18B20 = 1;
  if(D18B20==1)
  u |= 0x80;
  TempDelay (2);
  _nop_();
 return(u);
  for(i=0;i<j;i++)
    *p = ReadByte();
    p++;
    unsigned char idata i,crc_data=0;
   for(i=0;i<j;i++)  //查表校验
     crc_data = CrcTable[crc_data^temp_buff[i]];
    return (crc_data);
void GemTemp (void)
   read_bytes (9);
   if (CRC(9)==0) //校验正确
     Temperature = temp_buff[1]*0x100 + temp_buff[0];
//     Temperature *= 0.625;
  Temperature /= 16;
  TempDelay(1);
void Config18b20 (void)  //重新配置报警限定值和分辨率
     Init18b20();
     WriteByte(0xcc);  //skip rom
     WriteByte(0x4e);  //write scratchpad
     WriteByte(0x19);  //上限
     WriteByte(0x1a);  //下限
     WriteByte(0x7f);     //set 12 bit (0.125)
     Init18b20();
     WriteByte(0x48);  //保存设定值
     Init18b20();
     WriteByte(0xb8);  //回调设定值
void ReadID (void)//读取器件 id
 Init18b20();
 WriteByte(0x33);  //read rom
 read_bytes(8);
   p = id_buff;
   ReadID();
   Config18b20();
 Init18b20 ();
 WriteByte(0x44);   //Temperature convert
 Init18b20 ();
 WriteByte(0xbe);   //read Temperature
 p = temp_buff;
 GemTemp();
void GetTemp()
     if(TIM==100) //每隔 1000ms 读取温度
 {  TIM=0;
    TemperatuerResult();
void T1zd(void) interrupt 3
   TH1 = 0xD8;    //10
   TL1 = 0xF0;
   TIM++;
关键词: Patterson     进程     ----DS18B20
2011-12-25 17:59:35     打赏
不错啊,继续哦,!!加油!!!
2011-12-25 22:28:06     打赏
最好也自己扩展一下自己的东西!!
2011-12-26 00:49:01     打赏
程序直接上附件更好
2011-12-27 20:58:50     打赏
你有积分就可以下载
2011-12-27 21:47:52     打赏
乍一看,以为是那个Patterson,呵呵
共6条 1/1 1 跳转至页
