By integrating three independent LED drivers, the LTR3496 offers a highly effi cient, compact and cost-effective solution to drive multiple LED strings. All three drivers have independent on/off and PWM dimming control, and can drive different numbers or types of LEDs. High side current sensing and built-in gate drivers for PMOS LED disconnect allow the LT3496 to operate in buck, boost, SEPIC or buck-boost modes with up to 3000:1 True Color PWM™ dimming ratio.
Triple LED Driver in 4mm × 5mm QFN Supports LCD.pdf
| OrangePiZero2W系统被打赏¥33元 | |
