电子产品世界 » 论坛首页 » DIY与开源设计 » 设计工具 » 【设计要点】输入电压可低至2.2V的降压式同步控制器
2012-04-08 22:07:44     打赏
Many telecommunications and computing applications need high efficiency step-down DC/DC converters that can operate from a very low input voltage. The high output power synchronous controller LT3740 is ideal for these applications, converting input supplies ranging from 2.2V to 22V to outputs as low as 0.8V with load currents from 2A to 20A. Applications include distributed power systems, point-of-load regulation and conversion of logic supplies.
Step-Down Synchronous Controller Operates from Inputs Down to 2.2V.pdf
关键词: 设计     要点     输入     电压     可低     降压     同步     控制器
