电子产品世界 » 论坛首页 » DIY与开源设计 » 设计工具 » 【设计要点】提供LDO驱动和输出跟踪的紧凑型三路输出降压稳压器
2012-04-08 22:20:52     打赏
Typical industrial and automotive applications require multiple high current, low voltage power supplies to drive everything from disk drives to microprocessors. The LT®3507 triple step-down converter fi ts easily into these applications. It is simple and compact compared to multi-chip solutions.
Compact Triple Step-Down Regulator Offers LDO Driver and.pdf
关键词: 设计     要点     提供     驱动     输出     跟踪     紧凑型     三路
