This application note describes a Virtex®-II device implementation of a CSIX-L1 common switch interface between a network processor’s traffic manager and the switching fabric for ATM, IP, MPLS, Ethernet, and similar data communications applications. This design uses a pipeline implementation to achieve a low clock period (approximately 166 MHz), and uses the 32-bit interface CSIX scheme. This document is obsolete/under obsolescence.
xapp289.pdf
共1条
Common Switch Interface CSIX-L1 Reference Design - Obsolete
关键词: Common Switch Interface C
共1条
