The shift registers available in Virtex®-II devices are ideal when building synchronous FIFOs. By using the flexibility of the shift register LUT primitive (SRL16), FIFOs can be built with any width while producing a 1-bit resolution. With cascaded SRL16 shift registers (SRLC16), a flexible depth in multiples of 16 is available. This document is obsolete/under obsolescence.
xapp256.pdf
共1条
FIFOs Using Virtex-II Shift Registers - Obsolete
关键词: FIFOs Using Virtex-II Shi
共1条
| OrangePiZero2W系统被打赏¥33元 | |
