电子产品世界 » 论坛首页 » 企业专区 » Xilinx » FIFOs Using Virtex-II Shift Registers -
FIFOs Using Virtex-II Shift Registers - Obsolete
2012-05-13 09:13:25     打赏
The shift registers available in Virtex®-II devices are ideal when building synchronous FIFOs. By using the flexibility of the shift register LUT primitive (SRL16), FIFOs can be built with any width while producing a 1-bit resolution. With cascaded SRL16 shift registers (SRLC16), a flexible depth in multiples of 16 is available. This document is obsolete/under obsolescence.
xapp256.pdf
关键词: FIFOs     Using     Virtex-II     Shi
