5、按键防抖控制LED
(这个只是个实例,效果不是很好,改进的请进http://forum.eepw.com.cn/thread/221172/15#147)
按键S1、S2、S3、S4,控制电平翻转进而控制LED1、LED2、LED3、LED4的亮灭,按键S8为复位键。
module key_debounce(rst_n,clk,keyin,ledout);
input rst_n;
input clk;
input[3:0] keyin;
output[3:0] ledout;
reg[19:0] cnt;
always @(posedge clk or negedge rst_n)
begin
if (!rst_n)
cnt <= 20'd0;
else
cnt <= cnt + 1'b1;
end
wire sample_pulse = cnt == 20'hF4240;
wire led0_out;
key0 U1
.en(sample_pulse),
.rst_n(rst_n),
.clk(clk),
.key(keyin[0]),
.ledout(led0_out)
wire led1_out;
key1 U2
.en(sample_pulse),
.rst_n(rst_n),
.clk(clk),
.key(keyin[1]),
.ledout(led1_out)
wire led2_out;
key2 U3
.en(sample_pulse),
.rst_n(rst_n),
.clk(clk),
.key(keyin[2]),
.ledout(led2_out)
wire led3_out;
key3 U4
.en(sample_pulse),
.rst_n(rst_n),
.clk(clk),
.key(keyin[3]),
.ledout(led3_out)
assign ledout = {led3_out,led2_out,led1_out,led0_out};
endmodule
//-----------------------key0-----------------------
module key0(en,rst_n,clk,key,ledout);
input clk;
input rst_n;
input en;
input key;
output ledout;
reg low_sw;
begin
if (!rst_n)
low_sw <= 1'b1;
else if(en)
low_sw <= key;
end
reg low_sw_r;
always @(posedge clk )
low_sw_r <= low_sw;
wire led_ctrl = low_sw_r & (!low_sw);
reg ledout_r;
begin
if (!rst_n)
ledout_r <= 1'b0;
else if(led_ctrl)
ledout_r <= ~ledout_r;
end
assign ledout = ledout_r;
endmodule
//-----------------------key1-----------------------
module key1(en,rst_n,clk,key,ledout);
input clk;
input rst_n;
input en;
input key;
output ledout;
reg low_sw;
begin
if (!rst_n)
low_sw <= 1'b1;
else if(en)
low_sw <= key;
end
reg low_sw_r;
low_sw_r <= low_sw;
reg ledout_r;
begin
if (!rst_n)
ledout_r <= 1'b0;
else if(led_ctrl)
end
endmodule
//-----------------------key2-----------------------
module key2(en,rst_n,clk,key,ledout);
input clk;
input rst_n;
input en;
input key;
output ledout;
reg low_sw;
begin
if (!rst_n)
low_sw <= 1'b1;
else if(en)
low_sw <= key;
end
reg low_sw_r;
low_sw_r <= low_sw;
reg ledout_r;
begin
if (!rst_n)
ledout_r <= 1'b0;
else if(led_ctrl)
end
endmodule
//-----------------------key3-----------------------
module key3(en,rst_n,clk,key,ledout);
input clk;
input rst_n;
input en;
input key;
output ledout;
reg low_sw;
begin
if (!rst_n)
low_sw <= 1'b1;
else if(en)
low_sw <= key;
end
reg low_sw_r;
low_sw_r <= low_sw;
reg ledout_r;
begin
if (!rst_n)
ledout_r <= 1'b0;
else if(led_ctrl)
end
endmodule
,下回泡妞的时候下手也得快啦
