电子产品世界 » 论坛首页 » 企业专区 » Renesas » 小鱼也来提个问:RL78如何软件触发复位
共5条 1/1 1 跳转至页
2012-10-23 09:49:48     打赏
硬件触发复位比较方便,比如RESET脚输入低电平,低电压检测复位等等
那如何软件触发复位呢,小鱼不回答,求大家的答案
关键词: 小鱼     也来     提个     如何     软件     触发     复位
2012-10-23 10:07:19     打赏
WDT?
goto 0000H?
2012-10-23 10:12:04     打赏
(1) External reset input via RESET pin
(2) Internal reset by watchdog timer program loop detection
不喂狗就可復位
(3) Internal reset by comparison of supply voltage and detection voltage of power-on-reset (POR) circuit
(4) Internal reset by comparison of supply voltage of the voltage detector (LVD) and detection voltage
(5) Internal reset by execution of illegal instructionNote
The illegal instruction is generated when instruction code FFH is executed.
(6) Internal reset by RAM parity error
(7) Internal reset by illegal-memory access
2012-10-23 13:45:56     打赏
BINGO!
2012-10-23 14:31:31     打赏
楼上那位太快了。不到5分钟就把答案帖出来的。
唉,早起的鸟儿有虫吃啊~~
共5条 1/1 1 跳转至页
