http://share.eepw.com.cn/share/download/id/79306
前段时间很忙,耽误了一段时间,现在上传数码管的显示程序
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_Unsigned.ALL;
ENTITY showseg7 IS
PORT(clk_p: IN STD_LOGIC;
dig:OUT STD_LOGIC_VECTOR(7 DOWNTO 0);--数码管选择输出引脚
seg:OUT STD_LOGIC_VECTOR(7 DOWNTO 0));--数码管段输出引脚
END ENTITY showseg7;
ARCHITECTURE one OF showseg7 IS
SIGNAL count: STD_LOGIC_VECTOR(2 DOWNTO 0);--定义数码管输出寄存器
SIGNAL seg_r: STD_LOGIC_VECTOR(7 DOWNTO 0);--定义数码管选择输出寄存器
SIGNAL dig_r: STD_LOGIC_VECTOR(7 DOWNTO 0);--定义显示数据寄存器
SIGNAL disp_r:STD_LOGIC_VECTOR(2 DOWNTO 0);--定义计数寄存器
BEGIN
PROCESS(clk_p)
BEGIN
IF RISING_EDGE(clk_p) THEN
IF count="111" THEN count<="000";
ELSE count<=count+1;
END IF;
END IF;
END PROCESS;
PROCESS(count)
BEGIN
CASE count IS
WHEN "000" => disp_r<="000";dig_r<="01111111";seg_r<="11000000";--显示0
WHEN "001" => disp_r<="001";dig_r<="10111111";seg_r<="11111001";--显示1
WHEN "010" => disp_r<="010";dig_r<="11011111";seg_r<="10100100";--显示2
WHEN "011" => disp_r<="011";dig_r<="11101111";seg_r<="10110000";--显示3
WHEN "100" => disp_r<="100";dig_r<="11110111";seg_r<="10011001";--显示4
WHEN "101" => disp_r<="101";dig_r<="11111011";seg_r<="10010010";--显示5
WHEN "110" => disp_r<="110";dig_r<="11111101";seg_r<="10000010";--显示6
WHEN "111" => disp_r<="111";dig_r<="11111110";seg_r<="11111000";--显示7
WHEN OTHERS => NULL;
END CASE;
END PROCESS;
seg<=seg_r;
dig<=dig_r;
END ARCHITECTURE one;
LIBRARY IEEE;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
ENTITY yimaqi IS
PORT(clk2:IN STD_LOGIC;
doe:IN STD_LOGIC_VECTOR(23 DOWNTO 0);
dig2:OUT STD_LOGIC_VECTOR(5 DOWNTO 0);
seg2:OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END ;
ARCHITECTURE example OF yimaqi IS
SIGNAL a:STD_LOGIC_VECTOR(2 DOWNTO 0):="000";
SIGNAL b:STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
PROCESS(clk2)
BEGIN
IF clk2'event and clk2='1' THEN
IF a="101" THEN a<="000";ELSE a<=a+1;
END IF;
END IF;
END PROCESS;
PROCESS(a)
BEGIN
CASE a IS
WHEN"101"=>b<=doe(3 DOWNTO 0);dig2<="111110";
WHEN"100"=>b<=doe(7 DOWNTO 4);dig2<="111101";
WHEN"011"=>b<=doe(11 DOWNTO 8);dig2<="111011";
WHEN"010"=>b<=doe(15 DOWNTO 12);dig2<="110111";
WHEN"001"=>b<=doe(19 DOWNTO 16);dig2<="101111";
WHEN"000"=>b<=doe(23 DOWNTO 20);dig2<="011111";
WHEN OTHERS=>NULL;
END CASE;
END PROCESS;
PROCESS(b)
BEGIN
CASE b IS
WHEN"0000"=>seg2<="11000000";
WHEN"0001"=>seg2<="11111001";
WHEN"0010"=>seg2<="10100100";
WHEN"0011"=>seg2<="10110000";
WHEN"0100"=>seg2<="10011001";
WHEN"0101"=>seg2<="10010010";
WHEN"0110"=>seg2<="10000010";
WHEN"0111"=>seg2<="11111000";
WHEN"1000"=>seg2<="10000000";
WHEN"1001"=>seg2<="10010000";
WHEN OTHERS=>seg2<="11111111";
END CASE;
END PROCESS;
END example;
蜂鸣器程序:利用键盘控制音调
library ieee;
use ieee.std_logic_1164.all;
use ieee. std_logic_arith.all;
use ieee. std_logic_unsigned.all;
entity fengmq is
port (clk: in std_logic;
fmq: out std_logic
end fengmq;
architecture behave of fengmq is
--signal count: std_logic;
begin
process (clk)
begin
if clk'event and clk='1' then
-- count<=clk;
end if;
end process ;
fmq<=clk;
end behave ;
LIBRARY IEEE;
entity LCD1602 is
port ( clk :in std_logic;
lcd_rs:out std_logic;
lcd_rw:out std_logic;
lcd_e: out std_logic;
data:out std_logic_vector(7 downto 0)
end LCD1602;
architecture one of LCD1602 is
signal bcd: std_logic_vector(5 downto 0);
--signal cnt: std_logic_vector(9 downto 0);
begin
process(clk)
begin
bcd<=bcd+1;
-- cnt<=cnt+1;
case bcd is
when "000000"=>
lcd_rs<='0';
lcd_e<='1';
data<="00111000";
when "000001"=>
lcd_rs<='0';
lcd_e<='0';
when "000010"=>
lcd_rs<='0';
lcd_e<='1';
data<="00001100";
when "000011"=>
lcd_rs<='0';
lcd_e<='0';
when "000101"=>
lcd_rs<='0';
lcd_e<='0';
when "000110"=> --xian E
lcd_rs<='1';
lcd_e<='1';
data<="01000101";
when "000111"=>
lcd_rs<='1';
lcd_e<='0';
when "001000"=>
lcd_rs<='0';
lcd_e<='1';
data<="10000010";
when "001001"=>
lcd_rs<='0';
lcd_e<='0';
when "001010"=> --xian E
lcd_rs<='1';
lcd_e<='1';
data<="01000101";
when "001011"=>
lcd_rs<='1';
lcd_e<='0';
when "001100"=>
lcd_rs<='0';
lcd_e<='1';
data<="10000011";
when "001101"=>
lcd_rs<='0';
lcd_e<='0';
when "001110"=> --xian P
lcd_rs<='1';
lcd_e<='1';
data<="01010000";
when "001111"=>
lcd_rs<='1';
lcd_e<='0';
when "010000"=>
lcd_rs<='0';
lcd_e<='1';
data<="10000100";
when "010001"=>
lcd_rs<='0';
lcd_e<='0';
when "010010"=> --xian w
lcd_rs<='1';
lcd_e<='1';
data<="01010111";
when "010011"=>
lcd_rs<='1';
lcd_e<='0';
lcd_e<='0';
when others=>null;
end case;
end if;
end process;
end ;
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 |
