| 日期 | 进程 | 楼层 | 备注 |
| 10.31 | 板子搞到手焊接ing~~~ | 2 | 上大图 |
| 11.02 | 上一个动态扫描程序 | 4 | 程序+图 |
| 11.03 | 来个vhdl版本的lcd1602 | 7 | 程序+图 |
| 日期 | 进程 | 楼层 | 备注 |
数码管动态显示
module scan_led(clk,rst,sm_seg,sm_bit);
input clk,rst;
output[7:0] sm_seg;
output[7:0] sm_bit;
reg[7:0] sm_seg;
reg[7:0] sm_bit;
reg[15:0] cnt_scan;
reg[4:0] dataout_buf;
always@(posedge clk or negedge rst)
begin
if(!rst) begin
cnt_scan<=0;
end
else begin
cnt_scan<=cnt_scan+1'b1;
end
end
always @(cnt_scan)
begin
case(cnt_scan[15:13])
3'b000 :
sm_bit = 8'b1111_1110;
3'b001 :
sm_bit = 8'b1111_1101;
3'b010 :
sm_bit = 8'b1111_1011;
3'b011 :
sm_bit = 8'b1111_0111;
3'b100 :
sm_bit = 8'b1110_1111;
3'b101 :
sm_bit = 8'b1101_1111;
3'b110 :
sm_bit = 8'b1011_1111;
3'b111 :
sm_bit = 8'b0111_1111;
default :
endcase
end
always@(sm_bit)
begin
case(sm_bit)
8'b1111_1110:
dataout_buf=0;
8'b1111_1101:
dataout_buf=1;
8'b1111_1011:
dataout_buf=2;
8'b1111_0111:
dataout_buf=3;
8'b1110_1111:
dataout_buf=4;
8'b1101_1111:
dataout_buf=5;
8'b1011_1111:
dataout_buf=6;
8'b0111_1111:
dataout_buf=7;
default:
dataout_buf=8;
endcase
end
always@(dataout_buf)
begin
case(dataout_buf)
4'h0 : sm_seg = 8'b00000011; // "0"
4'h1 : sm_seg = 8'b10011111; // "1"
4'h2 : sm_seg = 8'b00100101; // "2"
4'h3 : sm_seg = 8'b00001101; // "3"
4'h4 : sm_seg = 8'b10011001; // "4"
4'h5 : sm_seg = 8'b01001001; // "5"
4'h6 : sm_seg = 8'b01000001; // "6"
4'h7 : sm_seg = 8'b00011111; // "7"
/* 4'h8 : sm_seg = 8'h80; // "8"
4'h9 : sm_seg = 8'h90; // "9"
4'ha : sm_seg = 8'h88; // "a"
4'hb : sm_seg = 8'h83; // "b"
4'hc : sm_seg = 8'hc6; // "c"
4'hd : sm_seg = 8'ha1; // "d"
4'he : sm_seg = 8'h86; // "e"
4'hf : sm_seg = 8'h8e; // "f"*/
endcase
end
endmodule
上图
来个vhdl lcd1602的 注释乱码咯 见谅啊~~
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity lcd is
port(clk:in std_logic;
lcd_rs,lcd_rw,lcd_e:out std_logic;
dataout:out std_logic_vector(7 downto 0));
end lcd;
architecture behave of lcd is
signal p:std_logic_vector(15 downto 0);
signal m:std_logic_vector(7 downto 0);
signal t,n:std_logic:='0';
begin
process(clk,n)
begin
if(n='0')then
if(clk'event and clk='1')then ---¸ßµçƽ´¥·¢·½Ê½
p<=p+1;
if(p>"0111111111111111")then -- 5000000000m/3760
t<='1';
else
t<='0';
end if;
end if;
end if;
end process;
lcd_e<=t; --//ÿ¸öÂö³å¿ª¹ØÊ¹ÄÜ
process(t,m)
begin
if(t'event and t='1')then
m<=m+1;
if(m>39)then
n<='1';
end if;
if(m<6 or m=23)then --//µ±m<5ʱΪ³õʼ»¯m=6£¬m=23ʱΪÉ趨ÐÐ Æä¶¼ÎªÐ´Ö¸Áî
lcd_rs<='0';
lcd_rw<='0';
else --//ÆäÓà¾ùΪдÊý¾Ý
lcd_rs<='1';
lcd_rw<='0';
end if;
end if;
case m is
when"00000001"=>dataout<=X"38"; --//lcd1602 ³õʼ»¯º¯ÊýÖ¸Áî 0x38 0x0c 0x06 0x80 0x01
when"00000010"=>dataout<=X"0C";
when"00000011"=>dataout<=X"06";
when"00000100"=>dataout<=X"80";
when"00000101"=>dataout<=X"01";
when"00000110"=>dataout<=X"40"; ------www.eepw.com --
when"00000111"=>dataout<=X"77";
when"00001000"=>dataout<=X"77";
when"00001001"=>dataout<=X"77";
when"00001010"=>dataout<=X"2E";
when"00001011"=>dataout<=X"65";
when"00001100"=>dataout<=X"65";
when"00001101"=>dataout<=X"70";
when"00001110"=>dataout<=X"77";
when"00001111"=>dataout<=X"2E";
when"00010000"=>dataout<=X"63";
when"00010001"=>dataout<=X"6F";
when"00010010"=>dataout<=X"6D";
when"00010100"=>dataout<=X"20";
when"00010101"=>dataout<=X"20";
when"00010110"=>dataout<=X"20";
when"00010111"=>dataout<=X"20";
when"00011000"=>dataout<=X"C0"; --//»»ÐÐ aihai0002275
when"00011001"=>dataout<=X"20";
when"00011010"=>dataout<=X"20";
when"00011011"=>dataout<=X"20";
when"00011100"=>dataout<=X"20";
when"00011101"=>dataout<=X"61";
when"00011110"=>dataout<=X"69";
when"00011111"=>dataout<=X"68";
when"00100000"=>dataout<=X"61";
when"00100001"=>dataout<=X"69";
when"00100010"=>dataout<=X"30";
when"00100011"=>dataout<=X"30";
when"00100100"=>dataout<=X"30";
when"00100101"=>dataout<=X"32";
when"00100110"=>dataout<=X"32";
when"00100111"=>dataout<=X"37";
when"00101000"=>dataout<=X"35";
when others=>dataout<=X"20"; --//¿Õ¸ñ
end case;
end process;
end behave;
上大图
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
