实验内容:上位机向串口发送一个字符,进入接收中断,在接收中断函数内接收数据,LED1闪烁一下,紧接着接收到的数据发送回上位机,发送完成LED3闪烁一下。
实验目的:进一步熟悉串口应用。
源代码奉上
串口初始化:
#include "stm32f10x.h"
void Uart1_Init(void)
//uart 的GPIO管脚初始化 PA9 usart1_TX PA10 USART_RX
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;//推挽输出
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;//悬空输入
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//只有串口1 使用72M,其他串口使用36M
USART_InitTypeDef USART_InitStructure;
//串口参数配置:115200,8,1,无奇偶校验,无硬流量控制 ,使能发送和接收
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE); //接收中断
USART_Cmd(USART1, ENABLE);
/*发送字符是通过查询字符串的状态来来不断的发送下一个数据。接受数据是通过中断来实现的,把接受的数据放入缓冲区,来实现。*/
//发送一个字符
void Usart_SendData(unsigned char x)
USART_SendData(USART1,x);
while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)!=SET);//查询发送数据寄存器空标志,等待发送完毕
//发送字符串
void Usart_SendStr(unsigned char *Str)
{ while(*Str)
USART_SendData(USART1, (unsigned char)*Str++);
while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
NVIC初始化:
void Nvic_Init(void)
//使能串口中断,并设置优先级
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//先占优先级2位从2位
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;//USART1_IRQChannel_Priority;
NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
main()函数:
#include "led.h"
#include "uart.h"
#include "nvic.h"
int main(void)
Uart1_Init();
Nvic_Init();
while (1)
中断函数(位于stm32f10x_it.c中)
void USART1_IRQHandler(void)
unsigned char temp_trx;
if(USART_GetITStatus(USART1,USART_IT_RXNE)!=RESET)
temp_trx=USART_ReceiveData(USART1);
LedBlink(1);
Delay();
USART_SendData(USART1,temp_trx);
LedBlink(3);
Delay();
另外请教一个问题:在中断函数内是否需要清除接收完成中断标志?我没有找到相关的清中断的函数。多谢各位看官。。。
| OrangePiZero2W系统被打赏¥33元 | |
