bingxue1682002进程贴
视频地址:http://player.youku.com/player.php/sid/XNDkyMzgwNjQ0/v.swf
module cnt60(sys_clk ,
sys_rstn ,
sm_seg ,
sm_bit
input sys_clk ;
input sys_rstn ;
output [7:0] sm_seg ;
output [7:0] sm_bit ;
reg [7:0] sm_seg ;
reg [7:0] sm_bit ;
reg [25:0] delay_a ;
reg [7:0] g ;
reg [7:0] s ;
reg delay_1s ;
reg delay_1ms ;
reg [15:0] delay_b ;
reg [3:0] num_g ;
reg [3:0] num_s ;
always@(posedge sys_clk or negedge sys_rstn)
begin
if(!sys_rstn)
delay_a<=26'd0;
else
begin
if(delay_a==26'd24999999)
begin
delay_1s<=~delay_1s;
delay_a<=26'd0;
end
else
delay_a<=delay_a+1'b1;
end
end
begin
if(!sys_rstn)
delay_1ms<=16'd0;
else
begin
if(delay_b==16'd49999)
begin
delay_1ms<=~delay_1ms;
delay_b<=16'd0;
end
else
delay_b<=delay_b+1'b1;
end
end
always@(posedge delay_1s or negedge sys_rstn)
begin
if(!sys_rstn)
begin
num_g<=4'd0;
num_s<=3'd0;
end
else
begin
if(num_g==4'd9)
begin
num_g<=4'd0;
num_s<=num_s+1'd1;
end
else
begin
if(num_g==4'd9&&num_s==3'd5)
begin
num_g<=4'd0;
num_s<=3'd0;
end
else
num_g<=num_g+1'd1;
end
end
end
always@(num_g)
begin
case(num_g)
4'd0: g= 8'hc0;
4'd1: g= 8'hf9;
4'd2: g= 8'ha4;
4'd3: g= 8'hb0;
4'd4: g= 8'h99;
4'd5: g= 8'h92;
4'd6: g= 8'h82;
4'd7: g= 8'hf8;
4'd8: g= 8'h80;
4'd9: g= 8'h90;
default g= 8'hc0;
endcase
end
always@(num_s)
begin
case(num_s)
3'd0: s = 8'hc0;
3'd1: s = 8'hf9;
3'd2: s = 8'ha4;
3'd3: s = 8'hb0;
3'd4: s = 8'h99;
3'd5: s = 8'h92;
default s=8'hc0;
endcase
end
always@(delay_1ms)
begin
if(delay_1ms)
begin
sm_seg<=g;
sm_bit<=8'hfe;
end
if(!delay_1ms)
begin
sm_seg<=s;
sm_bit<=8'hfd;
end
end
endmodule
视频地址:http://player.youku.com/player.php/sid/XNTMzMzEwNDc2/v.swf
按键消抖控制2位数码管循环显示0~59
module key_debounce(sys_clk ,
sys_rstn ,
key_in ,
sm_seg ,
sm_bit
input sys_clk ;
input sys_rstn ;
input key_in ;
reg key_out ;
reg [3:0] key_cnt ;
reg [3:0] key_cnt_r ;
reg [19:0] delay_cnt ;
reg [3:0] dataout_buf;
reg [7:0] sm_seg ;
wire key_scan ;
wire key_low ;
reg [7:0] sm_bit ;
reg key_samp ;
reg key_samp_r ;
reg key_rst ;
reg key_rst_r ;
reg [7:0] g;
reg [7:0] s;
reg [15:0] delay_b;
reg delay_1ms;
begin
if(!sys_rstn)
key_samp<=1'b1;
else
key_samp<=key_in;
end
begin
if(!sys_rstn)
key_samp_r<=1'b1;
else
key_samp_r<=key_samp;
end
assign key_scan=key_samp_r&(~key_samp);
begin
if(!sys_rstn)
delay_cnt<=20'h0;
else if(key_scan)
delay_cnt<=20'h0;
else
delay_cnt<=delay_cnt+1'b1;
end
begin
if(!sys_rstn)
key_rst<=1'b1;
else
if(delay_cnt==20'hf4240)
key_rst<=key_in;
end
begin
if(!sys_rstn)
key_rst_r<=1'b1;
else
key_rst_r<=key_rst;
end
assign key_low=key_rst_r&(~key_rst);
always@(posedge key_low or negedge sys_rstn )
begin
if(!sys_rstn)
begin
key_cnt<=4'd0;
key_cnt_r<=4'd0;
end
else
begin
if(key_cnt==4'd9)
begin
key_cnt<=4'd0;
key_cnt_r<=key_cnt_r+1'd1;
end
else
begin
if(key_cnt==4'd9&&key_cnt_r==4'd5)
begin
key_cnt<=4'd0;
key_cnt_r<=4'd0;
end
else
key_cnt<=key_cnt+1'b1;
end
end
end
begin
if(!sys_rstn)
delay_1ms<=1'b0;
else
begin
begin
delay_b<=16'd0;
end
else
end
end
always@(key_cnt)
begin
case(key_cnt)
4'd0:g=8'hc0;
4'd1:g=8'hf9;
4'd2:g=8'ha4;
4'd3:g=8'hb0;
4'd4:g=8'h99;
4'd5:g=8'h92;
4'd6:g=8'h82;
4'd7:g=8'hf8;
4'd8:g=8'h80;
4'd9:g=8'h90;
default:
g=8'hc0;
endcase
end
always@(key_cnt_r)
begin
case(key_cnt_r)
4'd0:s=8'hc0;
4'd1:s=8'hf9;
4'd2:s=8'ha4;
4'd3:s=8'hb0;
4'd4:s=8'h99;
4'd5:s=8'h92;
default:
s=8'hc0;
endcase
end
always@(delay_1ms)
begin
if(delay_1ms)
begin
sm_seg<=g;
sm_bit<=8'hfe;
end
if(!delay_1ms)
begin
sm_seg<=s;
sm_bit<=8'hfd;
end
end
endmodule
视频地址:http://player.youku.com/player.php/sid/XNTMzMzA0Mzcy/v.swf
实现LCD1602显示两行字母或数字从左向右滚动
module lcd1602(sys_clk ,
sys_rstn ,lcd_rs ,
lcd_rw ,
lcd_en ,
lcd_data
input sys_clk ;
input sys_rstn ;
output lcd_rs ;
output lcd_rw ;
output lcd_en ;
output [7:0] lcd_data ;
reg lcd_rs ;
reg clk_div ;
reg [17:0] delay_cnt ;
reg [7:0] lcd_data ;
reg [4:0] char_cnt ;
reg [7:0] data_disp ;
reg [9:0] state ;
parameter idle = 10'b000000000,
clear = 10'b000000001,
set_function = 10'b000000010,
switch_mode = 10'b000000100,
set_mode = 10'b000001000,
shift = 10'b000010000,
set_ddram1 = 10'b000100000,
set_ddram2 = 10'b001000000,
write_ram1 = 10'b010000000,
write_ram2 = 10'b100000000;
assign lcd_rw = 1'b0;
assign lcd_en = clk_div;
begin
if(!sys_rstn)
begin
delay_cnt<=18'd0;
clk_div<=1'b0;
end
else if(delay_cnt==18'd249999)
begin
delay_cnt<=18'd0;
clk_div<=~clk_div;
end
else
begin
clk_div<=clk_div;
end
end
always@(posedge clk_div or negedge sys_rstn)
begin
if(!sys_rstn)
begin
state <= idle;
lcd_data <= 8'bzzzzzzzz;
char_cnt <= 5'd0;
end
else
begin
case(state)
idle: begin
state <= clear;
end
clear: begin
state <= set_function;
lcd_rs<=1'b0;
lcd_data <= 8'b00000001;
end
set_function:
begin
state <= switch_mode;
lcd_rs<=1'b0;
lcd_data <= 8'b00111000;
end
switch_mode:
begin
state <= set_mode;
lcd_rs<=1'b0;
lcd_data <= 8'b00001111;
end
set_mode:begin
state <= shift;
lcd_rs<=1'b0;
lcd_data <= 8'b00000110;
end
shift: begin
state <= set_ddram1;
lcd_rs<=1'b0;
lcd_data <= 8'b0001_1100;
end
set_ddram1:
begin
state <= write_ram1;
lcd_rs<=1'b0;
lcd_data <= 8'b1000_0000;
end
set_ddram2:
begin
state <= write_ram2;
lcd_rs<=1'b0;
lcd_data <= 8'b1100_0000;
end
write_ram1:
begin
if(char_cnt <=5'd15)
begin
char_cnt <= char_cnt + 1'b1;
lcd_rs<=1'b1;
lcd_data <= data_disp;
end
else
begin
state <= set_ddram2;
end
end
write_ram2:
begin
if(char_cnt <=5'd30)
begin
lcd_rs<=1'b1;
end
else
begin
char_cnt <=5'd0;
state <= shift;
end
end
default: state <= idle;
endcase
end
end
always @(char_cnt)
begin
case (char_cnt)
5'd0: data_disp = 8'b01010111;
5'd1: data_disp = 8'b01100101;
5'd2: data_disp = 8'b01101100;
5'd3: data_disp = 8'b01100011;
5'd4: data_disp = 8'b01101111;
5'd5: data_disp = 8'b01101101;
5'd6: data_disp = 8'b01100101;
5'd7: data_disp = 8'b00100000;
5'd8: data_disp = 8'b01110100;
5'd9: data_disp = 8'b01101111;
5'd10: data_disp = 8'b00100000;
5'd11: data_disp = 8'b01110111;
5'd12: data_disp = 8'b01110111;
5'd13: data_disp = 8'b01110111;
5'd14: data_disp = 8'b00101110;
5'd15: data_disp = 8'b01100101;
5'd16: data_disp = 8'b01100101;
5'd17: data_disp = 8'b01110000;
5'd18: data_disp = 8'b01110111;
5'd19: data_disp = 8'b00101110;
5'd20: data_disp = 8'b01100011;
5'd21: data_disp = 8'b01101111;
5'd22: data_disp = 8'b01101101;
5'd23: data_disp = 8'b00101110;
5'd24: data_disp = 8'b01100011;
5'd25: data_disp = 8'b01101110;
5'd26: data_disp = 8'b00100001;
5'd27: data_disp = 8'b00110001;
5'd28: data_disp = 8'b00110010;
5'd29: data_disp = 8'b00110011;
5'd30: data_disp = 8'b00110100;
5'd31: data_disp = 8'b00110101;
5'd32: data_disp = 8'b00110110;
default : data_disp = 8'b00100000;
endcase
end
endmodule
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 | |
汽车电子中巡航控制系统的使用被打赏10分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏100分 | |
分享汽车电子中巡航控制系统知识被打赏10分 | |
分享安全气囊系统的检修注意事项被打赏10分 | |
分享电子控制安全气囊计算机知识点被打赏10分 | |
【分享开发笔记,赚取电动螺丝刀】【OZONE】使用方法总结被打赏20分 |
