1.设计一个两输入与门(这个简单能看懂)
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity myand1 is
port(a,b:in std_logic;
q
![](http://bbs.21ic.com/static/image/smiley/default/shocked.gif)
end myand1;
architecture rtl of myand1 is
begin
q<=a and b;
end rtl;
2.通过元件例化语句和generic语句修改输入变量数目,本程序设计为8个输入端口
library ieee;
entity myand is
generic (sreg_width:integer:=8);
port(indata:in std_logic_vector(sreg_width-1 downto 0);
q
end myand;
architecture rtl of myand is
signal z:std_logic_vector(sreg_width-1 downto 0);
component myand1
q
end component;
begin
z(sreg_width)<='1';--z是定义个的一个位矢量信号,怎么能给它赋1?最起码应该是“1111 1111”,还有z(sreg—width)这种书写格式没见过?
g1:for i in sreg_width-1 downto 0 generate--有for generate这个语句嘛,它的作用是?
u1:myand1 port map (z(i+1),indata(i),z(i));端口映射时的端口对应关系,还有z(i+1),indata(i),z(i));什么意思?
end generate;--generate都没见过
q<=z(0);
end rtl;
