共3条
ADC122S706为什么只能输出一路啊
简单看了一下datasheet
Channel A's conversionresult is outputted on DOUTA while Channel B's conversion re-sult is outputted on DOUTB.
貌似是2路输入输出,你确定你输入了2路被测信号?
还有建议看看第8个管脚DUAL,sheet上有这么一段说明:Applying a logic high to this pin causes the conversion result of Channel A to be outputon DOUTA and the conversion result of Channel B to be output on DOUTB. Grounding thispin causes the conversion result of Channel A and B to be output on DOUTA, with the resultof Channel A being output first. DOUTB is in a high impedance state when DUAL isgrounded.
大致意思是这个管脚的电平状态会影响输出位置。拉高,A路输入转换后从OUTA输出,B路输入转换后从OUTB输出;拉低,AB输入转换后都从OUTA输出,A先输出,B再输出,这个时候OUTB端高阻。
理论上TTL工艺IC的管脚悬空默认为高电平,但是实际上有很多不可预计的问题。
以上仅供参考。
共3条
