循环结构的延时计算,怎么算延时了多长啊!
一个加法两个指令周期,大概这么可以换算
如果来实现延时的话,可以用汇编做,例如
;// TI File $Revision: /main/4 $
;// Checkin $Date: July 30, 2007 10:28:57 $
;// FILE: DSP2833x_usDelay.asm
;// TITLE: Simple delay function
;// DESCRIPTION:
;// This is a simple delay function that can be used to insert a specified
;// delay into code.
;// This function is only accurate if executed from internal zero-waitstate
;// SARAM. If it is executed from waitstate memory then the delay will be
;// longer then specified.
;// To use this function:
;// 1 - update the CPU clock speed in the DSP2833x_Examples.h
;// file. For example:
;// #define CPU_RATE 6.667L // for a 150MHz CPU clock speed
;// or #define CPU_RATE 10.000L // for a 100MHz CPU clock speed
;// 2 - Call this function by using the DELAY_US(A) macro
;// that is defined in the DSP2833x_Examples.h file. This macro
;// will convert the number of microseconds specified
;// into a loop count for use with this function.
;// This count will be based on the CPU frequency you specify.
;// 3 - For the most accurate delay
;// - Execute this function in 0 waitstate RAM.
;// - Disable interrupts before calling the function
;// If you do not disable interrupts, then think of
;// this as an "at least" delay function as the actual
;// delay may be longer.
;// The C assembly call from the DELAY_US(time) macro will
;// look as follows:
;// extern void Delay(long LoopCount);
;// MOV AL,#LowLoopCount
;// MOV AH,#HighLoopCount
;// LCR _Delay
;// Or as follows (if count is less then 16-bits):
;// MOV ACC,#LoopCount
;// LCR _Delay
;// $TI Release: DSP2833x/DSP2823x Header Files V1.20 $
;// $Release Date: August 1, 2008 $
.def _DSP28x_usDelay
.sect "ramfuncs"
.global __DSP28x_usDelay
_DSP28x_usDelay:
SUB ACC,#1
BF _DSP28x_usDelay,GEQ ;; Loop if ACC >= 0
LRETR
;There is a 9/10 cycle overhead and each loop
;takes five cycles. The LoopCount is given by
;the following formula:
; DELAY_CPU_CYCLES = 9 + 5*LoopCount
; LoopCount = (DELAY_CPU_CYCLES - 9) / 5
; The macro DELAY_US(A) performs this calculation for you
;// End of file.
想要2812的也是类似的道理啊
;// FILE: DSP281x_usDelay.asm
;// DESCRIPTION:
;// 1 - update the CPU clock speed in the DSP281x_Examples.h
;// #define CPU_CLOCK_SPEED 6.6667L // for a 150MHz CPU clock speed
;// that is defined in the DSP28_Device.h file. This macro
;// LCR _Delay
;// LCR _Delay
;// Ver | dd mmm yyyy | Who | Description of changes
;// 1.00| 11 Sep 2003 | L.H. | No changes since v.58
.sect "ramfuncs"
_DSP28x_usDelay:
SUB ACC,#1
LRETR
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
