电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 单片机C语言程序设计:INT0 及 INT1 中断计数
2013-10-25 15:47:21     打赏
/* 名称:INT0及INT1中断计数
说明:每次按下第1个计数键时,
第1组计数值累加并显示在右边3只数
码管上,每次按下第2个计数键时,第
2组计数值累加并显示在左边3只数码管上,后两个按键分别清零。
#includereg51.h>
#defineucharunsignedchar
#defineuintunsignedint
sbitK3=P3^4;//2个清零键
sbitK4=P3^5;
//数码管段码与位码
ucharcodeDSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};
ucharcodeDSY_Scan_Bits[]={0x20,0x10,0x08,0x04,0x02,0x01};
//2组计数的显示缓冲,前3位一组,后3位一组
uchardataBuffer_Counts[]={0,0,0,0,0,0};
uintCount_A,Count_B=0;
//延时
voidDelayMS(uintx)
uchart;
while(x--)for(t=0;t120;t++);
//数据显示
voidShow_Counts()
uchari;
Buffer_Counts[2]=Count_A/100;
Buffer_Counts[1]=Count_A%100/10;
Buffer_Counts[0]=Count_A%10;
if(Buffer_Counts[2]==0)
Buffer_Counts[2]=0x0a;
if(Buffer_Counts[1]==0)
Buffer_Counts[1]=0x0a;
Buffer_Counts[5]=Count_B/100;
Buffer_Counts[4]=Count_B%100/10;
Buffer_Counts[3]=Count_B%10;
if(Buffer_Counts[5]==0)
Buffer_Counts[5]=0x0a;
if(Buffer_Counts[4]==0)
Buffer_Counts[4]=0x0a;
for(i=0;i6;i++)
P2=DSY_Scan_Bits[i];
P1=DSY_CODE[Buffer_Counts[i]];
DelayMS(1);
//主程序
voidmain()
IE=0x85;
PX0=1;中断优先
IT0=1;
IT1=1;
while(1)
if(K3==0)Count_A=0;
if(K4==0)Count_B=0;
Show_Counts();
//INT0中断函数
voidEX_INT0()interrupt0
Count_A++;
//INT1中断函数
voidEX_INT1()interrupt2
Count_B++;
扩展阅读:外部INT0中断控制LED
关键词: 基础知识
