Warning: (vsim-3473) Component instance "I1 : inv" is not bound.
# Time: 0 ns Iteration: 0 Instance: /decode File: F:/eryi/eryi.vhd
# ** Warning: (vsim-3473) Component instance "I2 : inv" is not bound.
# ** Warning: (vsim-3473) Component instance "A1 : and3" is not bound.
# ** Warning: (vsim-3473) Component instance "A2 : and3" is not bound.
# ** Warning: (vsim-3473) Component instance "A3 : and3" is not bound.
# ** Warning: (vsim-3473) Component instance "A4 : and3" is not bound.
我把顶层文件还有各个子模块都放在了一个工程下,对顶层文件仿真时就会出现这个问题,添加信号以后没有输出。求指导!谢谢!
