如下是写的一段发脉冲的程序,功能都是可以实现的,只是觉得是不是代码写得不好所以占用的资源较多,比如if判断太多了,希望大大们看看给点建议
	module  pulse(sclk, over,DATA, DATA_LAST,diff,dire, AbsErr_flag, rest);
   input sclk;            //10M时钟
   input over;            //一次数据读取(含校验)结束标志,结束后维持一周期(0.4us)高电平
   input [16:0] DATA;
   input [16:0] DATA_LAST;
   input [6:0] AbsErr_flag;
   input rest;
   output diff;
   output dire;
   wire diff;
   wire sclk;
   reg dire;
   reg [23:0] difcount;
   reg exclude_flag;
    assign diff = ((difcount)&&(~over))?sclk:1'b0;
 //脉冲输出,输出difcount个sclk(脉冲)
   always @(posedge over or negedge sclk or negedge rest)//(over|sclk))
   begin
     if(rest == 1'b0)
     begin
        difcount = 24'd0;
     end
     else
     begin
          if(over)                           //上升沿只一次
          begin
             if((AbsErr_flag[6:3] == 0)&&exclude_flag)
             begin
                 if(DATA > DATA_LAST)
                 begin
                     if((~(DATA_LAST[16]|DATA_LAST[15]))&(DATA[16]&DATA[15]))
                     begin
                         dire =1'b0;
                         difcount = 24'h20000-DATA+DATA_LAST;
                     end
                     else
                     begin
                         dire = 1'b1;
                         difcount = DATA-DATA_LAST;
                     end
                 end
                else
                begin
                    if((~(DATA[16]|DATA[15]))&(DATA_LAST[16]&DATA_LAST[15]))
                    begin
                        dire =1'b1;
                        difcount = 24'h20000-DATA_LAST+DATA;
                    end
                    else
                    begin
                    dire = 1'b0;
                    difcount = DATA_LAST-DATA;
                    end
                end
          end
      end
    else
    begin
           difcount <= (difcount)?(difcount-1'b1):0; //difcount自减至0
    end
  end
end
always @(negedge over or negedge rest)
begin
 if(rest == 1'b0)
 begin
     exclude_flag = 0;
 end
 else
 begin
      exclude_flag = 1;
 end
end
endmodule
这段代码加到主工程里多占了200多的逻辑单元,但是拿出来建工程编译后看好像没那么多。另外附上warnings:
Warning (10240): Verilog HDL Always Construct warning at pulse.v(23): inferring latch(es) for variable "dire", which holds its previous value in one or more paths through the always construct
Warning: Node "pulse:inst|dire" is a latch
Info: Assuming node "rest" is a latch enable. Will not compute fmax for this pin.
	Info: Detected gated clock "pulse:inst|always0~1" as buffer
Info: Detected ripple clock "pulse:inst|exclude_flag" as buffer
Info: Detected gated clock "pulse:inst|always0~0" as buffer
Info: Detected ripple clock "pulse:inst|difcount[23]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[22]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[21]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[20]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[19]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[18]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[17]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[16]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~3" as buffer
Info: Detected ripple clock "pulse:inst|difcount[15]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[14]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[13]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[12]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~2" as buffer
Info: Detected ripple clock "pulse:inst|difcount[11]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[10]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[9]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[8]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~1" as buffer
Info: Detected ripple clock "pulse:inst|difcount[7]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[6]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[5]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[4]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~0" as buffer
Info: Detected ripple clock "pulse:inst|difcount[3]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[2]" as buffer
Info: Detected ripple clock "pulse:inst|difcount[1]" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~6" as buffer
Info: Detected gated clock "pulse:inst|WideOr0~5" as buffer
Info: Detected ripple clock "pulse:inst|difcount[0]" as buffer
Info: Detected ripple clock "send:inst12|AbsErr_flag[3]" as buffer
Info: Detected ripple clock "send:inst12|AbsErr_flag[4]" as buffer
Info: Detected ripple clock "send:inst12|AbsErr_flag[5]" as buffer
Info: Detected ripple clock "send:inst12|AbsErr_flag[6]" as buffer
Info: Detected ripple clock "send:inst12|over" as buffer
Info: Detected gated clock "pulse:inst|dire~3" as buffer
Info: Detected gated clock "pulse:inst|diff" as buffer
Warning: Circuit may not operate. Detected 201 non-operational path(s) clocked by clock "sclk" with clock skew larger than data delay. See Compilation Report for details.
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
