共9条
关于用modelsim做时序仿真的问题
# Loading project led
# Compile of led_flicker.vo was successful.
# Compile of led_flicker.v was successful.
# Compile of led_flicker_tb.v was successful.
# 3 compiles, 0 failed with no errors.
vsim -L altera_device -sdftyp /led_flicker_inst=C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo -novopt work.led_flicker_tb
# vsim -L altera_device -sdftyp /led_flicker_inst=C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo -novopt work.led_flicker_tb
# Refreshing C:\Users\zYo0\Desktop\led_flicker\modelsim_time\work.led_flicker_tb
# Loading work.led_flicker_tb
# Loading instances from C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(340): Failed to find INSTANCE '\Add0~0 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(72): Failed to find INSTANCE '\Add0~10 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(468): Failed to find INSTANCE '\Add0~12 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(510): Failed to find INSTANCE '\Add0~14 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(552): Failed to find INSTANCE '\Add0~16 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(86): Failed to find INSTANCE '\Add0~18 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(44): Failed to find INSTANCE '\Add0~2 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(598): Failed to find INSTANCE '\Add0~20 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(100): Failed to find INSTANCE '\Add0~22 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(628): Failed to find INSTANCE '\Add0~24 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(658): Failed to find INSTANCE '\Add0~26 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(688): Failed to find INSTANCE '\Add0~28 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(718): Failed to find INSTANCE '\Add0~30 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(748): Failed to find INSTANCE '\Add0~32 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(114): Failed to find INSTANCE '\Add0~34 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(762): Failed to find INSTANCE '\Add0~36 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(776): Failed to find INSTANCE '\Add0~38 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(58): Failed to find INSTANCE '\Add0~4 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(806): Failed to find INSTANCE '\Add0~40 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(868): Failed to find INSTANCE '\Add0~42 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(882): Failed to find INSTANCE '\Add0~44 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(896): Failed to find INSTANCE '\Add0~46 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(926): Failed to find INSTANCE '\Add0~48 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(368): Failed to find INSTANCE '\Add0~6 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(410): Failed to find INSTANCE '\Add0~8 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(985): Failed to find INSTANCE '\Equal0~0 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(852): Failed to find INSTANCE '\Equal0~1 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(1017): Failed to find INSTANCE '\Equal0~2 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(176): Failed to find INSTANCE '\Equal0~3 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(1033): Failed to find INSTANCE '\Equal0~4 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(582): Failed to find INSTANCE '\Equal0~5 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(452): Failed to find INSTANCE '\Equal0~6 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(1049): Failed to find INSTANCE '\Equal0~7 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(352): Failed to find INSTANCE '\delay_cnt[0] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(612): Failed to find INSTANCE '\delay_cnt[10] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(144): Failed to find INSTANCE '\delay_cnt[11] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(642): Failed to find INSTANCE '\delay_cnt[12] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(672): Failed to find INSTANCE '\delay_cnt[13] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(702): Failed to find INSTANCE '\delay_cnt[14] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(732): Failed to find INSTANCE '\delay_cnt[15] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(1001): Failed to find INSTANCE '\delay_cnt[16] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(128): Failed to find INSTANCE '\delay_cnt[17] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(836): Failed to find INSTANCE '\delay_cnt[18] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(790): Failed to find INSTANCE '\delay_cnt[19] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(324): Failed to find INSTANCE '\delay_cnt[1] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(820): Failed to find INSTANCE '\delay_cnt[20] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(953): Failed to find INSTANCE '\delay_cnt[21] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(969): Failed to find INSTANCE '\delay_cnt[22] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(910): Failed to find INSTANCE '\delay_cnt[23] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(937): Failed to find INSTANCE '\delay_cnt[24] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(208): Failed to find INSTANCE '\delay_cnt[2] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(394): Failed to find INSTANCE '\delay_cnt[3] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(436): Failed to find INSTANCE '\delay_cnt[4] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(192): Failed to find INSTANCE '\delay_cnt[5] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(494): Failed to find INSTANCE '\delay_cnt[6] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(536): Failed to find INSTANCE '\delay_cnt[7] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(566): Failed to find INSTANCE '\delay_cnt[8] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(160): Failed to find INSTANCE '\delay_cnt[9] '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(524): Failed to find INSTANCE '\delay_cnt~0 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(482): Failed to find INSTANCE '\delay_cnt~1 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(224): Failed to find INSTANCE '\delay_cnt~2 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(424): Failed to find INSTANCE '\delay_cnt~3 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(382): Failed to find INSTANCE '\delay_cnt~4 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(294): Failed to find INSTANCE '\delay_cnt~5 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(1065): Failed to find INSTANCE '\led[0]~0 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(236): Failed to find INSTANCE '\led[0]~output '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(1076): Failed to find INSTANCE '\led[0]~reg0 '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(246): Failed to find INSTANCE '\led[1]~output '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(256): Failed to find INSTANCE '\led[2]~output '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(266): Failed to find INSTANCE '\led[3]~output '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(276): Failed to find INSTANCE '\sys_clk~input '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(285): Failed to find INSTANCE '\sys_clk~inputclkctrl '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(306): Failed to find INSTANCE '\sys_rstn~input '.
# ** Error: (vsim-SDF-3250) C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo(315): Failed to find INSTANCE '\sys_rstn~inputclkctrl '.
# ** Error: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s).
# ** Error: (vsim-SDF-3445) Failed to parse SDF file "C:/Users/zYo0/Desktop/led_flicker/modelsim_time/led_flicker_v.sdo".
# Time: 0 ps Iteration: 0 Instance: /led_flicker_tb File: C:/Users/zYo0/Desktop/led_flicker/src/led_flicker_tb.v
# Error loading design
共9条
