| 型号 | 材料 | 最高电压 | 最大电流 | 最大功率 | 频率 | 沟道电阻 |
| AF106 | GE-PNP | 25 V | 10 mA | - | 220 MHz | - |
| AF109R | GE-PNP | 20 V | 12 mA | - | 260 MHz | - |
| AF118 | GE-PNP | 70 V | 30 mA | 375 mW | 125 MHz | - |
| AC121 | GE-PNP | 20 V | 0,3 A | 0,9 W | - | - |
| AF121 | GE-PNP | 25 V | 10 mA | - | 270 MHz | - |
| AC122 | GE-PNP | 30 V | 0,2 A | 0,225 W | - | - |
| AC125 | GE-PNP | 32 V | 0,2 A | - | - | - |
| AF125 | GE-PNP | 32 V | 10 mA | - | 75 MHz | - |
| AC126 | GE-PNP | 32 V | 0,2 A | 0,5 W | - | - |
| AC127 | GE-NPN | 32 V | 0,5 A | - | - | - |
| AF127 | GE-PNP | 32 V | 10 mA | - | 75 MHz | - |
| AC128 | GE-PNP | 32 V | 1 A | 1 W | - | - |
| AC128K | GE-PNP | 32 V | 1 A | 1 W | - | - |
| AC131 | GE-PNP | 30 V | 1 A | 0,75 W | - | - |
| AC132 | GE-PNP | 32 V | 0,2 A | 0,5 W | - | - |
| AD133 | GE-PNP | 50 V | 15 A | 36 W | - | - |
| AD136 | GE-PNP | 40 V | 10 A | 11 W | - | - |
| AC138 | GE-PNP | 32 V | 1,2 A | 0,22 W | 1,5 MHz | - |
| AD139 | GE-PNP | 32 V | 3,5 A | 13 W | - | - |
| AF139 | GE-PNP | 20 V | 10 mA | - | 550 MHz | - |
| AC141K | GE-NPN | 32 V | 1,2 A | 1 W | - | - |
| AD148 | GE-PNP | 32 V | 3,5 A | 13,5 W | - | - |
| AD149 | GE-PNP | 50 V | 3,5 A | 27 W | - | - |
| AC151 | GE-PNP | 32 V | 0,2 A | 0,9 W | - | - |
| AC153 | GE-PNP | 32 V | 2 A | 1 W | - | - |
| AC153K | GE-PNP | 32 V | 2 A | 1 W | - | - |
| AD161 | GE-NPN | 32 V | 1 A | 6 W | - | - |
| AD162 | GE-PNP | 32 V | 1 A | 6 W | - | - |
| AD165 | GE-NPN | 25 V | 1 A | 6 W | - | - |
| AD166 | GE-PNP | 60 V | 5 A | 27,5 W | - | - |
| AC176K | GE-NPN | 32 V | 1 A | 1 W | - | - |
| AC180 | GE-PNP | 32 V | 1,5 A | 0,3 W | 1 MHz | - |
| AC187 | GE-NPN | 25 V | 1 A | 1 W | - | - |
| AC187K | GE-NPN | 25 V | 1 A | 1 W | - | - |
| AC188 | GE-PNP | 25 V | 1 A | 1 W | - | - |
| AC188K | GE-PNP | 25 V | 1 A | 1 W | - | - |
| AF200 | GE-PNP | 25 V | 10 mA | 0,145 W | - | - |
| AF201 | GE-PNP | 25 V | 10 mA | 0,145 W | - | - |
| AF239S | GE-PNP | 15 V | 10 mA | - | 700 MHz | - |
| AF279 | GE-PNP | 15 V | 10 mA | 60 mW | 780 MHz | - |
| AF279S | GE-PNP | 20 V | 10 mA | 0,6 W | - | - |
| AF306 | GE-PNP | 25 V | 15 mA | 60 mW | 500 MHz | - |
| AF367 | GE-PNP | 153 V | 10 mA | - | 800 MHz | - |
| AF379 | GE-PNP | UHF | - | - | 1250 MHz | - |
关键词: 欧洲晶体 参数大全
共1条
