RGB、LED点亮代码:
代码很露野,简单粗暴,注释是从用户手册里面弄来的,自己都看不懂多少,以后请各位多关照了
注:视频在15楼
/* Includes ------------------------------------------------------------------*/ #include "stm32f10x.h" #include "stm32_eval.h" GPIO_InitTypeDef GPIO_InitStructure; void RCC_Configuration(void) { RCC_DeInit(); //将外设RCC重新设为缺省值 RCC_HSICmd(ENABLE); //使能内部高速晶振 while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); //当SHI晶振就绪则重新设定 RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); //设置系统时钟,选择SHI时钟为系统时钟 RCC_HSEConfig(RCC_HSE_OFF); //设置外部高速晶振,HSE晶振OFF RCC_LSEConfig(RCC_LSE_OFF); //设置外部低速晶振,LSE晶振OFF RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz PLL输入时钟=HSI时钟频率除以2 PLL输入时钟*9 RCC_PLLCmd(ENABLE); ////*******************使能PLL while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); /////PLL就绪 RCC_ADCCLKConfig(RCC_PCLK2_Div4); // ADC时钟=PCLK/2 RCC_PCLK2Config(RCC_HCLK_Div1); // APB2时钟=HCLK RCC_PCLK1Config(RCC_HCLK_Div2); /// APB1时钟=HCLK/2 RCC_HCLKConfig(RCC_SYSCLK_Div1); // AHB时钟=系统时钟 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); // 选择PLL为系统时钟 while(RCC_GetSYSCLKSource() != 0x08); //当PLL不是系统时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //使能APB2外设时钟/****GPIOD时钟和功能复用IO时钟***/ GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG SW_DP使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; // //选择设置GPIO管脚 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; ////设置管脚速率 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; ////设置管脚工作状态,此为推挽输出 GPIO_Init(GPIOD, &GPIO_InitStructure); //初始化GPIOD GPIO_ResetBits(GPIOD,GPIO_Pin_2); //上拉关闭蜂鸣器 } void GPIO_INIT() { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //使能APB2外设时钟(GPIOA寄存器) RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3; /选择设置GPIO管脚 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_3; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //设置管脚速率 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//设置管脚工作状态,此为推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA GPIO_Init(GPIOC, &GPIO_InitStructure); } void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) //延时函数 32位 { while(n--) delay_us(1000); } /** * @brief Main program. * @param None * @retval None */ void func(void) //自定义函数,方便在主函数中调用,提高执行速率 { GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3); //拉高PA使RGB灭掉 delay_ms(70);//延时70ms GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_3); //拉高PC使LED灭掉 delay_ms(70); while(1){ //*************LED*******************// // LED一端接+3.3v,一端接PC,所以PC端为高电平时LED灭,反之变量 //PC1 GPIO_ResetBits(GPIOC,GPIO_Pin_0);//下拉给个低电平,PC1亮 delay_ms(70); GPIO_SetBits(GPIOC,GPIO_Pin_0);//上拉给个高电平,PC1灭 delay_ms(70); //PC5 GPIO_ResetBits(GPIOC,GPIO_Pin_4); delay_ms(70); GPIO_SetBits(GPIOC,GPIO_Pin_4); delay_ms(70); //PC6 GPIO_ResetBits(GPIOC,GPIO_Pin_5); delay_ms(70); GPIO_SetBits(GPIOC,GPIO_Pin_5); delay_ms(70); //PC2 GPIO_ResetBits(GPIOC,GPIO_Pin_1); delay_ms(70); GPIO_SetBits(GPIOC,GPIO_Pin_1); delay_ms(70); //PC3 GPIO_ResetBits(GPIOC,GPIO_Pin_2); delay_ms(70); GPIO_SetBits(GPIOC,GPIO_Pin_2); delay_ms(70); //PC7 GPIO_ResetBits(GPIOC,GPIO_Pin_6); delay_ms(70); GPIO_SetBits(GPIOC,GPIO_Pin_6); delay_ms(70); //PC8 GPIO_ResetBits(GPIOC,GPIO_Pin_7); delay_ms(70); GPIO_SetBits(GPIOC,GPIO_Pin_7); delay_ms(70); //PC4 GPIO_ResetBits(GPIOC,GPIO_Pin_3); delay_ms(70); GPIO_SetBits(GPIOC,GPIO_Pin_3); delay_ms(70); ////根据所需要的团进行排布,这可能是最笨的方法了。。。 //********************RGB******************/// //******RGB闪烁 //点亮蓝色 GPIO_ResetBits(GPIOA,GPIO_Pin_1); delay_ms(200); //这里给200ms是方便观察RGB颜色的变化,太快太慢都不适合 GPIO_SetBits(GPIOA,GPIO_Pin_1); delay_ms(200); //点亮紫色 GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); delay_ms(200); GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); delay_ms(200); //点亮红色 GPIO_ResetBits(GPIOA,GPIO_Pin_2); delay_ms(200); GPIO_SetBits(GPIOA,GPIO_Pin_2); delay_ms(200); //点亮青色 GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3); delay_ms(200); GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3); delay_ms(200); //点亮绿色 GPIO_ResetBits(GPIOA,GPIO_Pin_3); delay_ms(200); GPIO_SetBits(GPIOA,GPIO_Pin_3); delay_ms(200); //点亮黄色 GPIO_ResetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2); delay_ms(200); GPIO_SetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2); delay_ms(200); //点亮白色 GPIO_ResetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2|GPIO_Pin_1); delay_ms(200); GPIO_SetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2|GPIO_Pin_1); delay_ms(200); //******RGB逐渐变颜色 //蓝色亮后灭掉,紧接着下个颜色亮,看不到闪烁 GPIO_ResetBits(GPIOA,GPIO_Pin_1); delay_ms(700); //时间加长可以看到颜色变化过程,由于没有用脉宽调制,所以不能改变亮度 GPIO_SetBits(GPIOA,GPIO_Pin_1); //这里没有延时,所以看不到灯在闪烁 //红色亮,灭 GPIO_ResetBits(GPIOA,GPIO_Pin_2); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_2); //绿色亮,灭 GPIO_ResetBits(GPIOA,GPIO_Pin_3); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_3); //紫色亮,灭 GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); //青色亮,灭 GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3); //如果不想写那么多,点亮青色的时候可以这么写: // 紫色亮,灭 // GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); // delay_ms(700); // GPIO_SetBits(GPIOA,GPIO_Pin_2); // 青色亮,灭 // GPIO_ResetBits(GPIOA,GPIO_Pin_3); // delay_ms(700); // GPIO_SetBits(GPIOA,...........); GPIO_ResetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2); GPIO_ResetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2|GPIO_Pin_1); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2|GPIO_Pin_1); GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3); GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2); GPIO_ResetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2); delay_ms(700); GPIO_SetBits(GPIOA,GPIO_Pin_3|GPIO_Pin_2); } } int main(void) { RCC_Configuration(); //时钟初始化 GPIO_INIT(); // IO引脚初始化 func(); //执行自定义函数 }
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 | |
汽车电子中巡航控制系统的使用被打赏10分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏100分 | |
分享汽车电子中巡航控制系统知识被打赏10分 | |
分享安全气囊系统的检修注意事项被打赏10分 | |
分享电子控制安全气囊计算机知识点被打赏10分 | |
【分享开发笔记,赚取电动螺丝刀】【OZONE】使用方法总结被打赏20分 |
