电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 1031
共28条 3/3 ‹ 1 2 3 跳转至页
2014-12-25 13:23:38     打赏
21楼
2014-12-25 13:27:44     打赏
22楼
#include "stm32f10x.h"
#include "stm32_eval.h"
#include    "stdio.h"
#include "math.h"
#define buff_size  16;
char rx_buff[], rx_buff_count=0;
GPIO_InitTypeDef  GPIO_InitStructure;
USART_InitTypeDef  USART_InitStructure;
NVIC_InitTypeDef  NVIC_InitStructure;
USART_ClockInitTypeDef  USART_ClockInitStructure;
void RCC_Configuration(void)
    RCC_DeInit();
    RCC_HSICmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
    RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
    RCC_HSEConfig(RCC_HSE_OFF);
    RCC_LSEConfig(RCC_LSE_OFF);
    RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
    RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
    RCC_PCLK2Config(RCC_HCLK_Div1);
    RCC_PCLK1Config(RCC_HCLK_Div2);
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    while(RCC_GetSYSCLKSource() != 0x08);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
void GPIO_INIT()
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//PC0-PC7
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
    GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化PC
void USART_int(long BaudRate)
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出
   GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化 PA9
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输入
   GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化 PA10
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
    USART_InitStructure.USART_BaudRate = BaudRate;//传输速率
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1
    USART_InitStructure.USART_Parity = USART_Parity_No;//
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
    USART_Init(USART1, &USART_InitStructure);//初始化USART1
    USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Configure four bit for preemption priority */
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//优先级
  /* Enable the USART1 Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择USART1中断通道
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);//
/*delay_us*/
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
/*delay_ms*/
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
void USART_SendStr(char *str)//
   while((*str)!='\0')//
        USART_SendData(USART1,*str++);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
unsigned int translate(char *S,char j)//
    unsigned int a[4],sum=0;
    char i;
    for(i=0;i<j;i++)
        a[i]=S[5+j-1-i]-48;//将字符转成整型数据
        sum+=a[i]*pow(10,i);//按照每一位的权值相乘再相加,还原data=n的本来面貌
    return sum;//sum保存目标整型数据
void func(char *S,char LEN)
    char count;//
    unsigned int sum,i,j,k;
    if((LEN!=6)&(LEN!=7)&(LEN!=8)&(LEN!=9))//data=1~999
    {USART_SendStr("\r\n Erro input!!!\r\n");}//
    else
        count=LEN-5;//
        sum = translate(S,count);//
        GPIO_SetBits(GPIOC,0x000000ff);//all LED off
        for(k=0;k<3;k++)//
            i=0x00000100;
            for(j=1;j<=8;j++)//LED D8-D1
                i>>=1;
                GPIO_ResetBits(GPIOC,i);    // on PC7-PC0 D8-D1
                delay_ms(50);
                GPIO_SetBits(GPIOC,i);
                delay_ms(sum);//
void input_ASK()
    char j;
    func(rx_buff,rx_buff_count);
    rx_buff_count=0;
    for (j=0;j<rx_buff_count;j++)
    {rx_buff[j]='\0';}//
    USART_SendStr("\n>");
int main(void)
    RCC_Configuration();
    GPIO_INIT();
    USART_int(9600);
    GPIO_ResetBits(GPIOC,0x000000ff);//
    delay_ms(200);
    GPIO_SetBits(GPIOC,0x000000ff);//l
    USART_SendStr("SyStem booting......\r\n");//
    USART_SendStr("\n>");//
    while(1)
void USART1_IRQHandler(void)
  while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
    if(USART_ReceiveData(USART1)==0x0d)//
    {input_ASK();}
    else
        USART_SendData(USART1,USART_ReceiveData(USART1));
        rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
        rx_buff_count++;
    USART_ClearFlag(USART1, USART_FLAG_RXNE);
2014-12-25 13:34:50     打赏
23楼
2014-12-25 14:05:31     打赏
24楼
2014-12-25 14:20:35     打赏
25楼
系统滴答时钟18b20读取18b20的温度与id:
/* Includes ------------------------------------------------------------------*/
#include  <stdio.h>
volatile int flag;
#define Set_B20()    GPIO_SetBits(GPIOC, GPIO_Pin_12)      //上拉关闭PC12
#define Reset_B20()  GPIO_ResetBits(GPIOC, GPIO_Pin_12)  //下拉打开PC12
#define Read_B20()   GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)  //读PC12状态
unsigned char Error_Flag=0;
unsigned char zf=0;
void SysTick_Configuration(void)
  /* Setup SysTick Timer for 10 msec interrupts  */
  if (SysTick_Config(48000))                //SysTick配置
    /* Capture error */
    while (1);
 /* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);                       //SysTick中断优先级
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef   GPIO_InitStructure;  //结构体的命名
USART_InitTypeDef USART_InitStructure;  //结构体的命名
USART_ClockInitTypeDef USART_ClockInitStructure;  //结构体的命名
  RCC_DeInit();                 //将外设RCC的所有寄存器重新设为缺省值
  RCC_HSICmd(ENABLE);            //使能内部高速晶振
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);      //当SHI晶振就绪则重新设定
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);      //设置系统时钟,选择SHI时钟为系统时钟
  RCC_HSEConfig(RCC_HSE_OFF);     //设置外部高速晶振,HSE晶振OFF
  RCC_LSEConfig(RCC_LSE_OFF);      //设置外部低速晶振,LSE晶振OFF
    //******配置PLL时钟频率为48MHZ*******//
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_8);    //RCC_PLLMul_x 即设置PLL时钟频率为 6*x MHz
  RCC_PLLCmd(ENABLE);             ////*******************使能PLL
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);        //PLL就绪
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);                     //  ADC时钟=PCLK/2
  RCC_PCLK2Config(RCC_HCLK_Div1);                       //  APB2时钟=HCLK
  RCC_PCLK1Config(RCC_HCLK_Div2);            /// APB1时钟=HCLK/2
  RCC_HCLKConfig(RCC_SYSCLK_Div1);         //  AHB时钟=系统时钟
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);       // 选择PLL为系统时钟
  while(RCC_GetSYSCLKSource() != 0x08);        //当PLL不是系统时钟
//  SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //使能APB2外设时钟/****GPIOD时钟和功能复用IO时钟***/
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG    SW_DP使能
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;         // //选择设置GPIO管脚
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  ////设置管脚速率
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     ////设置管脚工作状态,此为推挽输出
  GPIO_Init(GPIOD, &GPIO_InitStructure);    //初始化GPIOD
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);     //上拉关闭蜂鸣器
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//LED
    GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); // GPIOC.0到GPIOC.7输出胃叩缙姜
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //使能TIM2时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能GPIOA、USART1外设时钟
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  //GPIO的输出速率为50MHz
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //使能外设GPIOC端口时钟
        - One Stop Bit
        - No parity
  USART_InitStructure.USART_BaudRate = BaudRate;//设置USART传输波特率  BaudRate = 9600 可以直接写9600
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//一帧传输或者接收的数据位数为8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//在帧结尾传输一个停止位
  USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶模式失能
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件流控制失能
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//使能接收发模式
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;    //时钟低电平活动
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;      //引脚时钟输出低电平时钟
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;     //第二个时钟边沿开始捕获数据
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据的时钟脉冲不从SCLK输出
    USART_ClockInit(USART1, &USART_ClockInitStructure); //引用结构体的成员
  USART_Init(USART1, &USART_InitStructure);//USART1初始化
  USART_Cmd(USART1, ENABLE);//使能USART1时钟外设
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能接受中断
 USART_Cmd(USART1, ENABLE);  //使能 USART
void delay_18b20(u32 nus)    //18b20按照严格的时序工作,这是特定的一个延时函数(自定义)
    u16 i;
    while(nus--)
        for(i=12;i>0;i--);
void Init18B20(void)  //18B20初始化
   u8 aa=0;
   u8 count =0;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;  //配置端口GPIOC.12
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出
  GPIO_Init(GPIOC, &GPIO_InitStructure); //引用结构体的变量
   Set_B20() ;   // GPIO_SetBits(GPIOC, GPIO_Pin_12)
   delay_18b20(1);
   Reset_B20();  //重置18B20
   delay_18b20(480);
   Set_B20();
//  delay_18b20(500);
   delay_18b20(480);
    count=0;
    aa=Read_B20();         //温度读取
    /****个人认为限制温度不超过99度,作为一个保护*/
    while(!aa && count<100)  //判断aa的非和计数器count的值是否都小于100
    aa=Read_B20();  //
    count++;          //count自加1
   if(count>=99)
        Error_Flag=1;  //错误返回值1
    else
        Error_Flag=0;  //错误返回值0
unsigned char Read18B20(void)//按位读取数据
unsigned char i=0;
unsigned char date=0;
u8 tempp;
   for(i=8;i>0;i--)
   Reset_B20();   //打开PC12
   date>>=1;    //标志右移一位
   delay_18b20(1);
   Set_B20();    //关闭
    delay_18b20(1);
   tempp=Read_B20();   //读取温度
   if(tempp)   //判断tempp是否为1
        date|=0x80;     // 1000 0000   将最高位填1 ,然后右移,每次最高位由0变1,使8位全部传递完毕 0xff = 1111 1111
    delay_18b20(60);  //延时
    return(date);  //返回值是无符号的字符型的类型 date
void Write18B20(unsigned char date)//向18b20写数据
    unsigned char i=0;
    for (i=8; i>0; i--)
        Reset_B20();
        delay_18b20(1);
        if(date & 0x01)
            Set_B20();
        else
        {   Reset_B20();}
        delay_18b20(60);
        date>>=1;
         Set_B20();
         delay_18b20(1);
    delay_18b20(15);
 float Read_T()//读温度
        unsigned char TUp,TDown;
    unsigned char fTemp;
    u8 TT=0;
     float Temp = 0;
    Init18B20();
    Write18B20(0xcc);
    Write18B20(0x44);
    Init18B20();
    Write18B20(0xcc);
    Write18B20(0xbe);
    TDown = Read18B20();
    TUp = Read18B20();
    if(TUp>0x7f)
        TDown=~TDown;
        TUp=~TUp+1;
        TUp/=8;
        zf=1;
    else
        zf=0;
    fTemp=TDown&0x0f;
    TUp<<=4;
    TDown>>=4;
    TT=TUp|TDown;
    Temp=TT+(float)fTemp/16;
    return(Temp);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
    char ID[8];
    int i;
  USART_int(115200);
    SysTick_Configuration();
    printf(" config done...\r\n");
    Init18B20();     //初始化
    Write18B20(0x33);  //写入读取地址的命令
    delay_18b20(20);
    for(i=0;i<8;i++)   //这里必须用for不然 只会输出printf("event 1 oc......\r\n")这句,不会继续运行
        ID[i] = Read18B20();//读取地址
    while(1)
        if(flag == 300)
            printf("At the moment of ID is:")   ;
            for(i=0;i<8;i++)     //字符不能直接输出,要按位输出
          printf("%u",ID[i]);//输出地址
            printf("\r\n")  ;
        if(flag == 500)
            printf("温度:%f\r\n",Read_T());//读取温度并输出
            printf("===================================================\r\n");
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-12-25 14:22:57     打赏
26楼
2014-12-25 22:41:51     打赏
27楼
spi
  * @file    EXTI/EXTI_Config/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
	© COPYRIGHT 2011 STMicroelectronics
#include
#include "spi_flash.h"
#define VREF 3.3
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define RxBufferSize1   (countof(TxBuffer1) - 1)
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define  FLASH_WriteAddress     0x00000
#define  FLASH_ReadAddress      FLASH_WriteAddress
#define  FLASH_SectorToErase    FLASH_WriteAddress
#define  sFLASH_ID              0xEF3015     //W25X16
//#define  sFLASH_ID              0xEF4015   //W25Q16
char rx_buff[],rx_buff_count=0;
uint8_t Tx_Buffer[4096] ;
uint8_t Rx_Buffer[BufferSize];
__IO uint32_t DeviceID = 0;
__IO uint32_t FlashID = 0;
__IO TestStatus TransferStatus1 = FAILED;
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
char *int_to_string(int number,char *strnum)//整形数据转换为字符型
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
for(i=0;iLibraries->Small printf
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2015-01-06 21:40:32     打赏
28楼
这补丁打得,呵呵
