22楼
#include "stm32f10x.h" #include "stm32_eval.h" #include "stdio.h" #include "math.h" #define buff_size 16; char rx_buff[], rx_buff_count=0; GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; void RCC_Configuration(void) { RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); RCC_HSEConfig(RCC_HSE_OFF); RCC_LSEConfig(RCC_LSE_OFF); RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器 } void GPIO_INIT() { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//PC0-PC7 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出 GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化PC } void USART_int(long BaudRate) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化 PA9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输入 GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化 PA10 /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate;//传输速率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特 USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1 USART_InitStructure.USART_Parity = USART_Parity_No;// USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式 USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable; USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟 USART_Init(USART1, &USART_InitStructure);//初始化USART1 USART_Cmd(USART1, ENABLE); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); /* Configure four bit for preemption priority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//优先级 /* Enable the USART1 Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择USART1中断通道 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure);// } /*delay_us*/ void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } /*delay_ms*/ void delay_ms(u32 n) { while(n--) delay_us(1000); } void USART_SendStr(char *str)// { while((*str)!='\0')// { USART_SendData(USART1,*str++); while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); } } unsigned int translate(char *S,char j)// { unsigned int a[4],sum=0; char i; for(i=0;i<j;i++) { a[i]=S[5+j-1-i]-48;//将字符转成整型数据 sum+=a[i]*pow(10,i);//按照每一位的权值相乘再相加,还原data=n的本来面貌 } return sum;//sum保存目标整型数据 } void func(char *S,char LEN) { char count;// unsigned int sum,i,j,k; if((LEN!=6)&(LEN!=7)&(LEN!=8)&(LEN!=9))//data=1~999 {USART_SendStr("\r\n Erro input!!!\r\n");}// else { count=LEN-5;// sum = translate(S,count);// GPIO_SetBits(GPIOC,0x000000ff);//all LED off for(k=0;k<3;k++)// { i=0x00000100; for(j=1;j<=8;j++)//LED D8-D1 { i>>=1; GPIO_ResetBits(GPIOC,i); // on PC7-PC0 D8-D1 delay_ms(50); GPIO_SetBits(GPIOC,i); delay_ms(sum);// } } } } void input_ASK() { char j; func(rx_buff,rx_buff_count); rx_buff_count=0; for (j=0;j<rx_buff_count;j++) {rx_buff[j]='\0';}// USART_SendStr("\n>"); } int main(void) { RCC_Configuration(); GPIO_INIT(); USART_int(9600); GPIO_ResetBits(GPIOC,0x000000ff);// delay_ms(200); GPIO_SetBits(GPIOC,0x000000ff);//l USART_SendStr("SyStem booting......\r\n");// USART_SendStr("\n>");// while(1) {} } void USART1_IRQHandler(void) { while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET) { } if(USART_ReceiveData(USART1)==0x0d)// {input_ASK();} else { USART_SendData(USART1,USART_ReceiveData(USART1)); rx_buff[rx_buff_count]= USART_ReceiveData(USART1); rx_buff_count++; } USART_ClearFlag(USART1, USART_FLAG_RXNE); }
23楼
24楼
25楼
系统滴答时钟18b20读取18b20的温度与id:
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h" #include "stm32_eval.h" #include <stdio.h> volatile int flag; #define Set_B20() GPIO_SetBits(GPIOC, GPIO_Pin_12) //上拉关闭PC12 #define Reset_B20() GPIO_ResetBits(GPIOC, GPIO_Pin_12) //下拉打开PC12 #define Read_B20() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12) //读PC12状态 unsigned char Error_Flag=0; unsigned char zf=0; void SysTick_Configuration(void) { /* Setup SysTick Timer for 10 msec interrupts */ if (SysTick_Config(48000)) //SysTick配置 { /* Capture error */ while (1); } /* Configure the SysTick handler priority */ NVIC_SetPriority(SysTick_IRQn, 0x0); //SysTick中断优先级 } /** @addtogroup STM32F10x_StdPeriph_Examples * @{ */ /** @addtogroup EXTI_Config * @{ */ /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ GPIO_InitTypeDef GPIO_InitStructure; //结构体的命名 USART_InitTypeDef USART_InitStructure; //结构体的命名 USART_ClockInitTypeDef USART_ClockInitStructure; //结构体的命名 void RCC_Configuration(void) { RCC_DeInit(); //将外设RCC的所有寄存器重新设为缺省值 RCC_HSICmd(ENABLE); //使能内部高速晶振 while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); //当SHI晶振就绪则重新设定 RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); //设置系统时钟,选择SHI时钟为系统时钟 RCC_HSEConfig(RCC_HSE_OFF); //设置外部高速晶振,HSE晶振OFF RCC_LSEConfig(RCC_LSE_OFF); //设置外部低速晶振,LSE晶振OFF //******配置PLL时钟频率为48MHZ*******// RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_8); //RCC_PLLMul_x 即设置PLL时钟频率为 6*x MHz //************************************// RCC_PLLCmd(ENABLE); ////*******************使能PLL while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //PLL就绪 RCC_ADCCLKConfig(RCC_PCLK2_Div4); // ADC时钟=PCLK/2 RCC_PCLK2Config(RCC_HCLK_Div1); // APB2时钟=HCLK RCC_PCLK1Config(RCC_HCLK_Div2); /// APB1时钟=HCLK/2 RCC_HCLKConfig(RCC_SYSCLK_Div1); // AHB时钟=系统时钟 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); // 选择PLL为系统时钟 while(RCC_GetSYSCLKSource() != 0x08); //当PLL不是系统时钟 // SystemInit(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //使能APB2外设时钟/****GPIOD时钟和功能复用IO时钟***/ GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG SW_DP使能 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; // //选择设置GPIO管脚 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; ////设置管脚速率 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; ////设置管脚工作状态,此为推挽输出 GPIO_Init(GPIOD, &GPIO_InitStructure); //初始化GPIOD GPIO_ResetBits(GPIOD,GPIO_Pin_2); //上拉关闭蜂鸣器 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//LED GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); // GPIOC.0到GPIOC.7输出胃叩缙姜 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //使能TIM2时钟 } void USART_int(long BaudRate) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能GPIOA、USART1外设时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //GPIO的输出速率为50MHz GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* PA10 USART1_Rx */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //使能外设GPIOC端口时钟 GPIO_Init(GPIOA, &GPIO_InitStructure); /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = BaudRate;//设置USART传输波特率 BaudRate = 9600 可以直接写9600 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//一帧传输或者接收的数据位数为8bit USART_InitStructure.USART_StopBits = USART_StopBits_1;//在帧结尾传输一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶模式失能 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件流控制失能 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//使能接收发模式 USART_ClockInitStructure.USART_Clock = USART_Clock_Disable; //时钟低电平活动 USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; //引脚时钟输出低电平时钟 USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge; //第二个时钟边沿开始捕获数据 USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据的时钟脉冲不从SCLK输出 USART_ClockInit(USART1, &USART_ClockInitStructure); //引用结构体的成员 USART_Init(USART1, &USART_InitStructure);//USART1初始化 USART_Cmd(USART1, ENABLE);//使能USART1时钟外设 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能接受中断 USART_Cmd(USART1, ENABLE); //使能 USART } void delay_18b20(u32 nus) //18b20按照严格的时序工作,这是特定的一个延时函数(自定义) { u16 i; while(nus--) for(i=12;i>0;i--); } void Init18B20(void) //18B20初始化 { u8 aa=0; u8 count =0; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; //配置端口GPIOC.12 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出 GPIO_Init(GPIOC, &GPIO_InitStructure); //引用结构体的变量 Set_B20() ; // GPIO_SetBits(GPIOC, GPIO_Pin_12) delay_18b20(1); Reset_B20(); //重置18B20 delay_18b20(480); Set_B20(); // delay_18b20(500); delay_18b20(480); count=0; aa=Read_B20(); //温度读取 /****个人认为限制温度不超过99度,作为一个保护*/ while(!aa && count<100) //判断aa的非和计数器count的值是否都小于100 { aa=Read_B20(); // count++; //count自加1 } if(count>=99) Error_Flag=1; //错误返回值1 else Error_Flag=0; //错误返回值0 } unsigned char Read18B20(void)//按位读取数据 { unsigned char i=0; unsigned char date=0; u8 tempp; for(i=8;i>0;i--) { Reset_B20(); //打开PC12 date>>=1; //标志右移一位 delay_18b20(1); Set_B20(); //关闭 delay_18b20(1); tempp=Read_B20(); //读取温度 if(tempp) //判断tempp是否为1 date|=0x80; // 1000 0000 将最高位填1 ,然后右移,每次最高位由0变1,使8位全部传递完毕 0xff = 1111 1111 delay_18b20(60); //延时 } return(date); //返回值是无符号的字符型的类型 date } void Write18B20(unsigned char date)//向18b20写数据 { unsigned char i=0; for (i=8; i>0; i--) { Reset_B20(); delay_18b20(1); if(date & 0x01) { Set_B20(); } else { Reset_B20();} delay_18b20(60); date>>=1; Set_B20(); delay_18b20(1); } delay_18b20(15); } float Read_T()//读温度 { unsigned char TUp,TDown; unsigned char fTemp; u8 TT=0; float Temp = 0; Init18B20(); Write18B20(0xcc); Write18B20(0x44); Init18B20(); Write18B20(0xcc); Write18B20(0xbe); TDown = Read18B20(); TUp = Read18B20(); if(TUp>0x7f) { TDown=~TDown; TUp=~TUp+1; TUp/=8; zf=1; } else zf=0; fTemp=TDown&0x0f; TUp<<=4; TDown>>=4; TT=TUp|TDown; Temp=TT+(float)fTemp/16; return(Temp); } int main(void) { /*!< At this stage the microcontroller clock setting is already configured, this is done through SystemInit() function which is called from startup file (startup_stm32f10x_xx.s) before to branch to application main. To reconfigure the default setting of SystemInit() function, refer to system_stm32f10x.c file */ /* System Clocks Configuration */ char ID[8]; int i; RCC_Configuration(); USART_int(115200); SysTick_Configuration(); printf(" config done...\r\n"); Init18B20(); //初始化 Write18B20(0x33); //写入读取地址的命令 delay_18b20(20); for(i=0;i<8;i++) //这里必须用for不然 只会输出printf("event 1 oc......\r\n")这句,不会继续运行 { ID[i] = Read18B20();//读取地址 } while(1) { if(flag == 300) { printf("At the moment of ID is:") ; for(i=0;i<8;i++) //字符不能直接输出,要按位输出 { printf("%u",ID[i]);//输出地址 } printf("\r\n") ; } if(flag == 500) { printf("温度:%f\r\n",Read_T());//读取温度并输出 printf("===================================================\r\n"); } } } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif /** * @} */ /** * @} */ #ifdef __GNUC__ /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ /** * @brief Retargets the C library printf function to the USART. * @param None * @retval None */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) {} return ch; } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif
27楼
spi
/** ****************************************************************************** * @file EXTI/EXTI_Config/main.c * @author MCD Application Team * @version V3.5.0 * @date 08-April-2011 * @brief Main program body ****************************************************************************** * @attention * * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. * * © COPYRIGHT 2011 STMicroelectronics ****************************************************************************** */ /* Includes ------------------------------------------------------------------*/ #include "stm32f10x.h" #include "stm32_eval.h" #include #include "spi_flash.h" #define VREF 3.3 void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) { while(n--) delay_us(1000); } #define TxBufferSize1 (countof(TxBuffer1) - 1) #define RxBufferSize1 (countof(TxBuffer1) - 1) #define countof(a) (sizeof(a) / sizeof(*(a))) #define BufferSize (countof(Tx_Buffer)-1) typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus; #define FLASH_WriteAddress 0x00000 #define FLASH_ReadAddress FLASH_WriteAddress #define FLASH_SectorToErase FLASH_WriteAddress #define sFLASH_ID 0xEF3015 //W25X16 //#define sFLASH_ID 0xEF4015 //W25Q16 #define buff_size 16; char rx_buff[],rx_buff_count=0; /* ???????? */ uint8_t Tx_Buffer[4096] ; uint8_t Rx_Buffer[BufferSize]; __IO uint32_t DeviceID = 0; __IO uint32_t FlashID = 0; __IO TestStatus TransferStatus1 = FAILED; // ?????? void Delay(__IO uint32_t nCount); TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength); /** @addtogroup STM32F10x_StdPeriph_Examples * @{ */ /** @addtogroup EXTI_Config * @{ */ /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; char *int_to_string(int number,char *strnum)//整形数据转换为字符型 { int j=0,i=0,n=0; char temp; while(number>0) { *(strnum+j)=number%10+48; j++; number=number/10; n++; } for(i=0;iLibraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ /** * @brief Retargets the C library printf function to the USART. * @param None * @retval None */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) {} return ch; } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif
打赏帖 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 | |
汽车电子中巡航控制系统的使用被打赏10分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏100分 | |
分享汽车电子中巡航控制系统知识被打赏10分 | |
分享安全气囊系统的检修注意事项被打赏10分 | |
分享电子控制安全气囊计算机知识点被打赏10分 | |
【分享开发笔记,赚取电动螺丝刀】【OZONE】使用方法总结被打赏20分 | |
【分享开发笔记,赚取电动螺丝刀】【S32K314】芯片启动流程分析被打赏40分 | |
【分享开发笔记,赚取电动螺丝刀】【S32K146】S32DS RTD 驱动环境搭建被打赏12分 | |
【分享开发笔记,赚取电动螺丝刀】【IAR】libc标注库time相关库函数使用被打赏23分 |
