数码管按键切换扫描
	脑袋不够用了,本来想优化简洁一下程序的,想了几个晚上还是不能实现。只好用siwtch一条条copy,明明每条语句都一样,是可以用循环做出来的,可是自己C语言底子差,不够努力,没有创新精神,只能耐烦的copy了30遍,写这样一切都怪自己啦
  * @file    GPIO/IOToggle/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
    ? COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
uint16_t Dis_tab[]={GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8,//0
	GPIO_Pin_9|GPIO_Pin_12,//1
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5,//2
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5,//3
	GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5,//4
	GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5,//5
	GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5,//6
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12,//7
	GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14,//8
	GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14//9
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void GPIO_INIT()
   //GPIOB(数码管)初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  //按键初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
//微秒延时
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
//毫秒延时
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
    int i,j;
    RCC_Configuration();
    GPIO_INIT();
    GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管
      while(1){
            if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))//S3键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){j++;}}//延时后S3处于按下状态,j++
        if(j%2==0){ //如果i是偶数
             if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){i++;}
           }}//延时后S2处于按下状态,j++
				else{//如果i是奇数
        					  if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))//S1键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){i++;}}
				 }//延时后S1处于按下状态,j++
        if(i>30){i=0;}
           GPIO_ResetBits(GPIOB,GPIO_Pin_1);
           GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
        switch(i){
         case 0 :
             GPIO_SetBits(GPIOB,GPIO_Pin_1);
             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
         break;
         case 1 :
         break;
            case 2 :
            break;
            case 3 :
            break;
            case 4 :
            break;
            case 5 :
            break;
            case 6 :
            break;
            case 7 :
            break;
            case 8 :
            break;
            case 9 :
            break;
					  case 10 :
           GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
						delay_ms(1);
						            GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
						delay_ms(1);
                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
						delay_ms(1);
            break;
						case 11 :
						delay_ms(1);
						delay_ms(1);
						delay_ms(1);
            break;
						case 12 :
						delay_ms(1);
						delay_ms(1);
						delay_ms(1);
            break;
		       case 13:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
					  case 14:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
						 case 15:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
						  case 16:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
							 case 17:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
							  case 18:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break; case 19:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
						 case 20:
						delay_ms(1);
						delay_ms(1);
                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
					 delay_ms(1);
            break;
						  case 21:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
							 case 22:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
							  case 23:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
								 case 24:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
								 case 25:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
								 case 26:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
								 		 case 27:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
										 		 case 28:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
						 case 29:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
					 case 30:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
