电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 29作业本【更新全部作业】
共24条 1/3 1 2 3 › 跳转至页
29作业本【更新全部作业】
2014-10-18 23:21:24     打赏
关键词: 焊接     过程
2014-10-19 00:04:41     打赏
安装前的准备
双击mdk472_a.exe
next
勾选,I agree……
接下来时一个漫长的过程
接下来
完成安装
再来破解
copy CID
将 copy的CID 粘贴,生成账号名
最终安装破解完成
2014-10-23 08:36:37     打赏
谢谢呢
2014-10-23 08:59:00     打赏
之前的调试视频一直没发,LED和RGB的视频又在审核中,
所以先发调试视频来试试手吧
2014-10-23 09:21:42     打赏
审核终于过了
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
  * @brief  Main program.
  * @param  None
  * @retval None
void RCC_Configuration(void)//时钟配置
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣
/*GPIO初始化*/
void GPIO_INIT()
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA, ENABLE);//使能PC,PA的时钟
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//要使用PC0至PC7
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
  GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化PC
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//要使用PA1,PA2,PA3
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化PA
/*延时函数 微秒*/
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
/*延时函数 微秒*/
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
/*点亮LED与RGB*/
void func(void)
            GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);//RGB熄灭
    while(1)
          GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);//LED全部熄灭
            delay_ms(100);
            GPIO_ResetBits(GPIOC,GPIO_Pin_3);//点亮D4
            delay_ms(100);
            GPIO_SetBits(GPIOC,GPIO_Pin_3);//熄灭D4
            GPIO_ResetBits(GPIOC,GPIO_Pin_2);//点亮D3
                          delay_ms(100);
            GPIO_SetBits(GPIOC,GPIO_Pin_2);//熄灭D3
            GPIO_ResetBits(GPIOC,GPIO_Pin_1);//点亮D2
            delay_ms(100);
            GPIO_SetBits(GPIOC,GPIO_Pin_1);//熄灭D2
            GPIO_ResetBits(GPIOC,GPIO_Pin_0);//点亮D1
            delay_ms(100);
            GPIO_SetBits(GPIOC,GPIO_Pin_0);//熄灭D1
					 GPIO_ResetBits(GPIOC,GPIO_Pin_4);//点亮D5
            delay_ms(100);
            GPIO_SetBits(GPIOC,GPIO_Pin_4);//熄灭D5
							GPIO_ResetBits(GPIOC,GPIO_Pin_5);//点亮D6
            delay_ms(100);
            GPIO_SetBits(GPIOC,GPIO_Pin_5);//熄灭D6
						      GPIO_ResetBits(GPIOC,GPIO_Pin_6);//点亮D7
            delay_ms(100);
            GPIO_SetBits(GPIOC,GPIO_Pin_6);//熄灭D7
            GPIO_ResetBits(GPIOC,GPIO_Pin_7);//点亮D8
            delay_ms(100);
            GPIO_SetBits(GPIOC,GPIO_Pin_7);//熄灭D8
/*RGB蓝红绿紫靛黄*/
            GPIO_ResetBits(GPIOA,GPIO_Pin_1);//蓝
            delay_ms(200);
            GPIO_SetBits(GPIOA,GPIO_Pin_1);
            GPIO_ResetBits(GPIOA,GPIO_Pin_2);//红
            delay_ms(200);
            GPIO_SetBits(GPIOA,GPIO_Pin_2);
            GPIO_ResetBits(GPIOA,GPIO_Pin_3);//绿
            delay_ms(200);
            GPIO_SetBits(GPIOA,GPIO_Pin_3);
            GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2);//紫
            delay_ms(200);
            GPIO_ResetBits(GPIOA,GPIO_Pin_3);//靛
            delay_ms(200);
            GPIO_ResetBits(GPIOA,GPIO_Pin_2);//黄
            delay_ms(200);
            GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);//RGB全部熄灭
  * @param  None
  * @retval None
int main(void)
    RCC_Configuration();
    GPIO_INIT();
    func();
2014-10-23 09:25:45     打赏
这个贴从主题帖中移出(都是因为当初太蠢)
这焊接的过程真是曲折坎坷呀,连想发个帖也是荆棘满路
在焊接过程没怎么拍照,文字功底又不怎么好,有什么不足之处望众大神教正
 首先焊的是核心板芯片,焊这颗芯片可真要瞎了。把管脚对齐,用透明胶布固定,再涂上焊锡膏,才敢开始焊。焊这颗芯片千万不要加焊锡,并且要处理干净电烙铁,不然会不小心把芯片管脚焊短路了。
涂焊锡膏
焊好芯片其他的贴片就很简单啦
可以先在焊盘上加一点焊锡,要有足够的焊锡才能把这些小贴片焊稳哦
这些小贴片只要按照原理图焊好行啦
后来调试的时候才发现忘记焊两个排针了,同学们不要粗心呀。
这个过程最想告诉大家的是,洗芯片好想哭,千万不要把焊上去的零件强行拆下!
由于之前焊核心板芯片的时候加了点焊锡,导致管脚短路,一气之下把芯片拆了,从此走上了洗芯片之路
2014-10-28 08:45:25     打赏
数码管按键切换扫描 脑袋不够用了,本来想优化简洁一下程序的,想了几个晚上还是不能实现。只好用siwtch一条条copy,明明每条语句都一样,是可以用循环做出来的,可是自己C语言底子差,不够努力,没有创新精神,只能耐烦的copy了30遍,写这样一切都怪自己啦
  * @file    GPIO/IOToggle/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
    ? COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
uint16_t Dis_tab[]={GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8,//0
	GPIO_Pin_9|GPIO_Pin_12,//1
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5,//2
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5,//3
	GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5,//4
	GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5,//5
	GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5,//6
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12,//7
	GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14,//8
	GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14//9
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
void GPIO_INIT()
   //GPIOB(数码管)初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  //按键初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
//微秒延时
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
//毫秒延时
    while(n--)
    delay_us(1000);
  * @param  None
  * @retval None
int main(void)
    int i,j;
    GPIO_INIT();
    GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管
      while(1){
            if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))//S3键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){j++;}}//延时后S3处于按下状态,j++
        if(j%2==0){ //如果i是偶数
             if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){i++;}
           }}//延时后S2处于按下状态,j++
				else{//如果i是奇数
        					  if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))//S1键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){i++;}}
				 }//延时后S1处于按下状态,j++
        if(i>30){i=0;}
           GPIO_ResetBits(GPIOB,GPIO_Pin_1);
           GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
        switch(i){
         case 0 :
             GPIO_SetBits(GPIOB,GPIO_Pin_1);
             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
         break;
         case 1 :
         break;
            case 2 :
            break;
            case 3 :
            break;
            case 4 :
            break;
            case 5 :
            break;
            case 6 :
            break;
            case 7 :
            break;
            case 8 :
            break;
            case 9 :
            break;
					  case 10 :
           GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
						delay_ms(1);
						            GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
						delay_ms(1);
                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
						delay_ms(1);
            break;
						case 11 :
						delay_ms(1);
						delay_ms(1);
						delay_ms(1);
            break;
						case 12 :
						delay_ms(1);
						delay_ms(1);
						delay_ms(1);
            break;
		       case 13:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
					  case 14:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
						 case 15:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
						  case 16:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
							 case 17:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
							  case 18:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break; case 19:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
						 case 20:
						delay_ms(1);
						delay_ms(1);
                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
					 delay_ms(1);
            break;
						  case 21:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
							 case 22:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
							  case 23:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
								 case 24:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
								 case 25:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
								 case 26:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
								 		 case 27:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
										 		 case 28:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
						 case 29:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
					 case 30:
						delay_ms(1);
						delay_ms(1);
					 delay_ms(1);
            break;
2014-10-29 00:06:53     打赏
脑袋不够用啦,有尝试,失败了,想上贴求助来着〒_〒
2014-10-29 00:11:08     打赏
也想简洁点的,可是自己功底差,又没有努力去学,只能做到这样了,有空再想想怎么优化了〒_〒
2014-11-07 09:57:43     打赏
本次作业没能按照老师的要求完成,数码管只能显示0~9,想要在数码管显示两位数时,十位数正确,个位数显示错误,一直都是显示8,比如当输入“data=29”时数码管显示的是 28 。
00
先贴代码,请大神们指教。
#include    "stdio.h"
#include "math.h"
#define buff_size  16;
char rx_buff[], rx_buff_count=0;
USART_InitTypeDef  USART_InitStructure;
NVIC_InitTypeDef  NVIC_InitStructure;
USART_ClockInitTypeDef  USART_ClockInitStructure;
    RCC_DeInit();
    RCC_HSICmd(ENABLE);
    RCC_PLLCmd(ENABLE);
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
  void GPIO_INIT()
  //GPIOB(数码管)初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);  //使能PB时钟
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;  //PC1--PC15
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //推挽输出
  GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化PB
void USART_int(long BaudRate)
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出
   GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化 PA9
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输入
   GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化 PA10
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
    USART_InitStructure.USART_BaudRate = BaudRate;//传输速率
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1
    USART_InitStructure.USART_Parity = USART_Parity_No;//
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
    USART_Init(USART1, &USART_InitStructure);//初始化USART1
    USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Configure four bit for preemption priority */
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//优先级
  /* Enable the USART1 Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择USART1中断通道
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);//初始化中断
/*delay_us*/
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
/*delay_ms*/
    while(n--)
    delay_us(1000);
void USART_SendStr(char *str)//发送字符串
   while((*str)!='\0')//到字符串的末尾才停止发送数据
        USART_SendData(USART1,*str++);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
unsigned int translate(char *S,char j)//将字符串组成的数字转换成整型数据
    unsigned int a[2],i=0;
    char c;
    for(c=0;c<j;c++)
        a[c]=S[5+j-1-c]-48;//将字符转成整型数据
        i=a[c]*pow(10,c);//按照每一位的权值相乘再相加,还原data=n的本来面貌
    return i;//i保存目标整型数据
void func(char *S,char LEN)
    char count;//  计数函数
    unsigned int i,c,j,k;
    if((LEN!=6)&(LEN!=7))//data=0~99
    {USART_SendStr("\r\n Erro input!!!\r\n");}//如果输入格式错误,发送提示
    else
        count=LEN-5;//从“=”后面开始是目标数据
        i = translate(S,count);//count记录“=”后有多少位,传递到translate中
		GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);	//关闭数码管
		switch(LEN){
         case 6 :
				 delay_ms(80);
         break;
				 case 7 :
						delay_ms(20);
				 delay_ms(2);
					 delay_ms(20);
				  delay_ms(2);
            break;
void input_ASK()
    char j;
    func(rx_buff,rx_buff_count);
    rx_buff_count=0;
    for (j=0;j<rx_buff_count;j++)
    {rx_buff[j]='\0';}//判断读入信息是否结束,如果结束则准备下一次读入
    USART_SendStr("\n>");
int main(void)
    GPIO_INIT();
    USART_int(9600);
    USART_SendStr("SyStem booting......\r\n");//
    USART_SendStr("\n>");//
    while(1)
void USART1_IRQHandler(void)
  while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
    if(USART_ReceiveData(USART1)==0x0d)//如果输入完毕,按下了回车
    {input_ASK();}
    else
        USART_SendData(USART1,USART_ReceiveData(USART1));
        rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
        rx_buff_count++;
    USART_ClearFlag(USART1, USART_FLAG_RXNE);
我不懂字符串转整型,是套用熙熙的……
可能是因为我强行套用才会出现错误吧……
    char c;
    for(c=0;c<j;c++)
在显示两位数时,是case7,我觉得这部分代码大体是正确的,不过闪现应该就是延时不对吧……大神们,求不鄙视……
case 7 :
		delay_ms(20);
		 delay_ms(2);
		delay_ms(20);
		delay_ms(2);
            break;
接下来,我只能交作业了,头脑一片混乱,想不出来办法了 ,求指教
