数码管按键切换扫描
脑袋不够用了,本来想优化简洁一下程序的,想了几个晚上还是不能实现。只好用siwtch一条条copy,明明每条语句都一样,是可以用循环做出来的,可是自己C语言底子差,不够努力,没有创新精神,只能耐烦的copy了30遍,写这样一切都怪自己啦![](http://forum.eepw.com.cn/pub/kindeditor/plugins/emoticons/images/9.gif)
视频地址:http://player.youku.com/player.php/sid/XODEzMDAzOTU2/v.swf
* @file GPIO/IOToggle/main.c
* @author MCD Application Team
* @version V3.5.0
* @date 08-April-2011
* @brief Main program body.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
? COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
uint16_t Dis_tab[]={GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8,//0
GPIO_Pin_9|GPIO_Pin_12,//1
GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5,//2
GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5,//3
GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5,//4
GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5,//5
GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5,//6
GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12,//7
GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14,//8
GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14//9
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void GPIO_INIT()
//GPIOB(数码管)初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//按键初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOC, &GPIO_InitStructure);
//微秒延时
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
//毫秒延时
void delay_ms(u32 n)
while(n--)
delay_us(1000);
* @brief Main program.
* @param None
* @retval None
int main(void)
int i,j;
RCC_Configuration();
GPIO_INIT();
GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管
while(1){
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))//S3键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){j++;}}//延时后S3处于按下状态,j++
if(j%2==0){ //如果i是偶数
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){i++;}
}}//延时后S2处于按下状态,j++
else{//如果i是奇数
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))//S1键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){i++;}}
}//延时后S1处于按下状态,j++
if(i>30){i=0;}
GPIO_ResetBits(GPIOB,GPIO_Pin_1);
GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
switch(i){
case 0 :
GPIO_SetBits(GPIOB,GPIO_Pin_1);
GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
break;
case 1 :
break;
case 2 :
break;
case 3 :
break;
case 4 :
break;
case 5 :
break;
case 6 :
break;
case 7 :
break;
case 8 :
break;
case 9 :
break;
case 10 :
GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1 on
delay_ms(1);
GPIO_SetBits(GPIOB,Dis_tab[i%10]); //off
GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
delay_ms(1);
GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
delay_ms(1);
break;
case 11 :
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 12 :
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 13:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 14:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 15:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 16:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 17:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 18:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break; case 19:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 20:
delay_ms(1);
delay_ms(1);
GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
delay_ms(1);
break;
case 21:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 22:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 23:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 24:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 25:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 26:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 27:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 28:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 29:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
case 30:
delay_ms(1);
delay_ms(1);
delay_ms(1);
break;
