电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 29作业本【更新全部作业】
共36条 3/4 ‹ 1 2 3 4 › 跳转至页
2014-11-26 09:40:39     打赏
21楼
#include "stm32f10x.h"
#include "stm32_eval.h"
#include
EXTI_InitTypeDef   EXTI_InitStructure;
GPIO_InitTypeDef   GPIO_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
long flag;
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
void RCC_Configuration(void)//外设时钟使能
	SystemInit();
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG  管脚映射重映射
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
	GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
	  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3, ENABLE);//TIM2  TIM3
		RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);//TIM8
void USART_int(long BaudRate)//USART1初始化
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
	USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
	USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
 USART_Cmd(USART1, ENABLE);//使能USART1
void NVIC_Configuration(void)//中断优先级设置
  NVIC_InitTypeDef NVIC_InitStructure;//定义结构体变量
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//设置优先级分组
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;//TIM2TIM3中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//先占优先级0级
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 5;//从优先级1级
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//IRQ通道被使能
	NVIC_Init(&NVIC_InitStructure);//初始化NVIC寄存器
	/* Enable the TIM3 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;//TIM2TIM3中断
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 8;//从优先级1级
	/* Enable the TIM8 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;//从优先级1级
void Timer_Config(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;//定义结构体变量
	RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);//使能TIM2外设
	TIM_DeInit(TIM2);//复位时钟TIM2,恢复初始状态
	 /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 36000;//周期
  TIM_TimeBaseStructure.TIM_Prescaler = 1000;//分频系数
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;//设置时钟分割
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//向上计数模式
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);//初始化TIM2
	TIM_ClearFlag(TIM2,TIM_FLAG_Update);//清楚标志
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE ); //使能TIM2的更新中断
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);//使能TIM2外设
	RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);//使能TIM3外设
	TIM_DeInit(TIM3);//复位时钟TIM3,恢复初始状态
  TIM_TimeBaseStructure.TIM_Period = 56000;//周期
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);//初始化TIM3
	TIM_ClearFlag(TIM3,TIM_FLAG_Update);//清楚标志
  TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能TIM3的更新中断
  TIM_Cmd(TIM3, ENABLE);//使能TIM3外设
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);//使能TIM8外设
	TIM_DeInit(TIM8);//复位时钟TIM8,恢复初始状态
  TIM_TimeBaseStructure.TIM_Period = 50000;//周期
  TIM_TimeBaseStructure.TIM_Prescaler = 1100;//分频系数
  TIM_TimeBaseStructure.TIM_ClockDivision =TIM_CKD_DIV1 ;//设置时钟分割
  TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);//初始化TIM2
	TIM_ClearFlag(TIM8,TIM_FLAG_Update);//清楚标志
  TIM_ITConfig(TIM8,TIM_IT_Update,ENABLE ); //使能TIM8的更新中断
  TIM_Cmd(TIM8, ENABLE);//使能TIM2外设
void TIM2_IRQHandler(void) //TIM2中断
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //检查TIM2更新中断发生与否
TIM_ClearITPendingBit(TIM2, TIM_IT_Update ); //清除TIM2更新中断标志
	GPIO_SetBits(GPIOC,GPIO_Pin_1);
void TIM3_IRQHandler(void) //TIM2中断
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //检查TIM2更新中断发生与否
TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //清除TIM2更新中断标志
	GPIO_SetBits(GPIOC,GPIO_Pin_2);
void TIM8_IRQHandler(void) //TIM2中断
if (TIM_GetITStatus(TIM8, TIM_IT_Update) != RESET) //检查TIM2更新中断发生与否
TIM_ClearITPendingBit(TIM8, TIM_IT_Update ); //清除TIM2更新中断标志
	GPIO_SetBits(GPIOC,GPIO_Pin_3);
int main(void)
  RCC_Configuration();
  USART_int(115200);
	NVIC_Configuration();
	printf(" config done...\r\n");
  Timer_Config();
 TIM2_IRQHandler();
 TIM3_IRQHandler();
	TIM8_IRQHandler();
  while (1){
GPIO_ResetBits(GPIOC,GPIO_Pin_1);
		delay_ms(200);
GPIO_ResetBits(GPIOC,GPIO_Pin_2);
		delay_ms(400);
GPIO_ResetBits(GPIOC,GPIO_Pin_3);
		delay_ms(200);
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  while (1)
#endif
2014-11-26 10:19:33     打赏
22楼
童鞋,TIM8是哪里来的?
2014-11-26 12:12:29     打赏
23楼
没做 ,只是还没来得及提问呢~~~
2014-11-26 12:25:09     打赏
24楼
TIM8没定义 把 它改成其他基本定时器就可以了 TIM8还不懂用 正在反省
2014-12-02 21:55:08     打赏
25楼
简单地改下占空比而已,就是这么简单笨拙
#include
#define VREF 3.3
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
	SystemInit();
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
void PWM_Config()
{uint16_t PrescalerValue = 0;//预分频器值
	/* TIM2 clock enable */
  /* GPIOA  enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO  , ENABLE);//使能复用功能时钟
		GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//复用推挽输出
		TIM_Cmd(TIM2, ENABLE);//TIM2使能
	  /* Compute the prescaler value */
  PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  TIM_TimeBaseStructure.TIM_Period = 0x07FF;//设置自动重装载
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;//设置预分频值
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;//设置时钟分割TDTS=Tck_tim
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);//根据指定参数初始化TIMx
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//选择PWM模式1
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//输出极性高
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0xFFFF;//通道占空比时间
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);//初始化TIM2 OC2
	/* PWM1 Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//比较输出使能
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);//初始化TIM2 OC3
	/* PWM1 Mode configuration: Channel4 */
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);//初始化TIM2 OC4
  TIM_ARRPreloadConfig(TIM2, ENABLE);//使能预装载寄存器
void PWM_TEST()
{ unsigned int temp0,temp1,temp2;
	printf("PWM-RGB TEST......\r\n");
	while(1)
   if(temp0=0,temp1=2047,temp2=2047)
		   {TIM_SetCompare2(TIM2,temp0);delay_ms(400);
       TIM_SetCompare3(TIM2,temp1);delay_ms(400);
       TIM_SetCompare4(TIM2,temp2);delay_ms(400);
	if(temp0=2047,temp1=0,temp2=2047)
	if(temp0=2047,temp1=2047,temp2=0)
	if(temp0=250,temp1=1750,temp2=1750)
  if(temp0=500,temp1=250,temp2=1750)
	if(temp0=500,temp1=1500,temp2=1000)
   if(temp0=1250,temp1=750,temp2=1250)
int main(void)
USART_int(115200);
	PWM_Config();
	delay_ms(1000);
	while(1)
		PWM_TEST();
{while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
etval None
  while (1)
#endif
2014-12-08 21:43:02     打赏
26楼
hi there
主贴也更新下撒
2014-12-11 23:43:36     打赏
27楼
#include <stdio.h>
#define VREF 3.3
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
void GPIO_INIT()
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
        - One Stop Bit
        - No parity
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
void Iic1_Init(void)
        I2C_InitTypeDef I2C_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
        //PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
        /* Configure IO connected to IIC*********************/
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10 | GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
        I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
        I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
        I2C_InitStructure.I2C_OwnAddress1 = 0xA0;
        I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
        I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_InitStructure.I2C_ClockSpeed = 400000;
        I2C_Cmd(I2C2, ENABLE);
        I2C_Init(I2C2, &I2C_InitStructure);
        I2C_AcknowledgeConfig(I2C2, ENABLE);
uint16_t Dis_tab[]={GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8,//0
	GPIO_Pin_9|GPIO_Pin_12,//1
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5,//2
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5,//3
	GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5,//4
	GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5,//5
	GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5,//6
	GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12,//7
	GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14,//8
	GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14//9
unsigned char i=0;
void Dis_number(unsigned char i)
	GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
						delay_ms(20);
				                GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
				 delay_ms(2);
                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
					 delay_ms(20);
				                GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
						            GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
				  delay_ms(2);
void EXTIkeyS1_Config(void)
  /* Enable GPIOA clock */
  /* Configure PA.00 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  /* Enable AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  /* Connect EXTI0 Line to PA.00 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
  /* Configure EXTI0 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line8;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set EXTI0 Interrupt to the lowest priority */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
        while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));
        I2C_GenerateSTART(I2C2,ENABLE);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));
        I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
        I2C_SendData(I2C2, write_address);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
        I2C_SendData(I2C2, byte);
        I2C_GenerateSTOP(I2C2, ENABLE);
        do
                /* Send START condition */
                I2C_GenerateSTART(I2C2, ENABLE);
                /* Read I2C2 SR1 register */
                /* Send EEPROM address for write */
                I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
        }while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));
        /* Clear AF flag */
        I2C_ClearFlag(I2C2, I2C_FLAG_AF);
        /* STOP condition */
unsigned char I2C2_ReadByte(unsigned char  id, unsigned char read_address)
    unsigned char temp;
    while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
    I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
    I2C_SendData(I2C2, read_address);
    I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
    while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
    I2C_AcknowledgeConfig(I2C2, DISABLE);
    while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
    temp = I2C_ReceiveData(I2C2);
    return temp;
void IIC_TEST()
	unsigned char count=0;
	count=I2C2_ReadByte(0xA0,0);
	Dis_number(count);
int main(void)
  GPIO_INIT();
    USART_int(115200);
    Iic1_Init();
  EXTIkeyS1_Config();
    delay_ms(1000);
    while(1)
           IIC_TEST();
void EXTI9_5_IRQHandler(void)
    if(EXTI_GetITStatus(EXTI_Line8) != RESET)
        i++;
        I2C2_WriteByte(0xA0,0,i);
    EXTI_ClearITPendingBit(EXTI_Line8);
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
  while (1)
#endif
只能部分显示 出现错误的应该是
delay_ms(20);
delay_ms(2);
delay_ms(20);
 delay_ms(2);
这是复制之前作业的,不懂问题在哪里
2014-12-16 15:38:29     打赏
28楼
错误提示贴贴看
2014-12-17 10:22:00     打赏
29楼
是可以运行的,就是数码管没有按照想象中的样子显示
2014-12-17 10:26:54     打赏
30楼
IIC视频,之前没上传成功就忘了
