电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 28号的作业本【更新spi作业】
共24条 2/3 1 2 3 跳转至
2014-12-04 21:06:50     打赏
11楼
  * @file    EXTI/EXTI_Config/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
#define VREF 3.3
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef   GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
	SystemInit();
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
	GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
	  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
	USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
	USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void PWM_Config()
{uint16_t PrescalerValue = 0;
	TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
	/* TIM2 clock enable */
  /* GPIOA  enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO  , ENABLE);
		GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
		TIM_Cmd(TIM2, ENABLE);
	  /* Compute the prescaler value */
  PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 0x07FF;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
	/* PWM1 Mode configuration: Channel3 */
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
	/* PWM1 Mode configuration: Channel4 */
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  TIM_ARRPreloadConfig(TIM2, ENABLE);
void delay_us(u32 n)
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
void  delay_ms(u32 n)
	while(n--)
	delay_us(1000);
void PWM_TEST()
    unsigned int temp0=0,temp1=0,temp2=0;
    printf("PWM-RGB TEST......\r\n");
    while(1)
   for(temp0=0;temp0<1500;temp0++)
        TIM_SetCompare2(TIM2, temp0);
            delay_us(1000);
    if (temp0>=3000)
        delay_ms(1000);
        temp0=0;
    for(temp1=1;temp1<2500;temp1++)
        TIM_SetCompare3(TIM2, temp1);
            delay_us(1000);
    if (temp1>=2500)
        delay_ms(100);
        temp1=0;
        for(temp2=0;temp2<2380;temp2++)
        TIM_SetCompare4(TIM2, temp2);
            delay_us(1000);
    if (temp2>=2380)
        delay_ms(1000);
        temp2=0;
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  RCC_Configuration();
USART_int(115200);
	printf(" config done...\r\n");
	PWM_Config();
	delay_ms(1000);
	while(1)
		PWM_TEST();
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2014-12-04 21:41:41     打赏
12楼
2014-12-08 22:12:28     打赏
13楼
来点注释呗
2014-12-18 22:34:49     打赏
14楼
下次会注意的。。
2014-12-18 23:59:30     打赏
15楼
#include <stdio.h>
#define VREF 3.3
unsigned char i=0;
void EXTIkeyS1_Config(void);
EXTI_InitTypeDef   EXTI_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
    //SystemInit();
        - One Stop Bit
        - No parity
      /* Configure four bit for preemption priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
  /* Enable the USART1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void IIc2_Init(void)
        I2C_InitTypeDef I2C_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2, ENABLE);
        //PB6-I2C2_SCL PB7-I2C2_SDA PB10-I2C2_SCL PB11-I2C2_SDA
        /* Configure IO connected to IIC*********************/
        GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10 | GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
        I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
        I2C_InitStructure.I2C_OwnAddress1 = 0xA0;
        I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
        I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_InitStructure.I2C_ClockSpeed = 400000;
        I2C_Cmd(I2C2, ENABLE);
        I2C_Init(I2C2, &I2C_InitStructure);
        I2C_AcknowledgeConfig(I2C2, ENABLE);
void I2C2_WriteByte(unsigned char id,unsigned char write_address,unsigned char byte)
        while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY));
        I2C_GenerateSTART(I2C2,ENABLE);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_MODE_SELECT));
        I2C_Send7bitAddress(I2C2,id,I2C_Direction_Transmitter);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
        I2C_SendData(I2C2, write_address);
        while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
        I2C_SendData(I2C2, byte);
        I2C_GenerateSTOP(I2C2, ENABLE);
        do
           /* Send START condition */
           I2C_GenerateSTART(I2C2, ENABLE);
          /* Read I2C2 SR1 register */
            /* Send EEPROM address for write */
            I2C_Send7bitAddress(I2C2, 0xA0, I2C_Direction_Transmitter);
        }while(!(I2C_ReadRegister(I2C2, I2C_Register_SR1) & 0x0002));
        /* Clear AF flag */
        I2C_ClearFlag(I2C2, I2C_FLAG_AF);
        /* STOP condition */
unsigned char I2C2_ReadByte(unsigned char  id, unsigned char read_address)
     unsigned char temp;
     while(I2C_GetFlagStatus(I2C2, I2C_FLAG_BUSY)){}
     I2C_Send7bitAddress(I2C2, id, I2C_Direction_Transmitter);
     I2C_SendData(I2C2, read_address);
     I2C_Send7bitAddress(I2C2, id, I2C_Direction_Receiver);
     while(!I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
    I2C_AcknowledgeConfig(I2C2, DISABLE);
    while(!(I2C_CheckEvent(I2C2, I2C_EVENT_MASTER_BYTE_RECEIVED)));
    temp = I2C_ReceiveData(I2C2);
     return temp;
/*delay_us*/
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
/*delay_ms*/
    while(n--)
    delay_us(1000);
int main(void)
  EXTIkeyS1_Config();
  USART_int(115200);
  IIc2_Init();
    i = I2C2_ReadByte(0xA0,0);//向0x00读取数据
    printf("从地址0x00读出数据 :%d\r\n",i);
    i++;
    I2C2_WriteByte(0xA0,0,i);//向0x00写入数据
    printf("向地址0x00写入数据 :%d\r\n",i);
    while(1)
     delay_ms(1000);
     printf(" 上电次数为%d\r\n",i);
void EXTIkeyS1_Config(void)//S1 PC8
  /* Enable GPIOA clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  /* Configure PA.00 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;//PC8 S1
  /* Enable AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
  EXTI_InitStructure.EXTI_Line = EXTI_Line8;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
void EXTI9_5_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line8) != RESET)
        i=0;
        I2C2_WriteByte(0xA0,0,0);
    /* Clear the  EXTI line 8 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line8);
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-12-19 22:26:20     打赏
16楼
2014-12-23 16:32:07     打赏
17楼
#include    "stdio.h"
#include "math.h"
#define buff_size  16;
char rx_buff[], rx_buff_count=0;
    RCC_DeInit();
    RCC_HSICmd(ENABLE);
    RCC_PLLCmd(ENABLE);
void GPIO_INIT()
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        - One Stop Bit
        - No parity
    NVIC_Init(&NVIC_InitStructure);//?????
/*delay_us*/
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
/*delay_ms*/
    while(n--)
    delay_us(1000);
void USART_SendStr(char *str)
   while((*str)!='\0')
        USART_SendData(USART1,*str++);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
unsigned int translate(char *S,char j)
    unsigned int a[4],sum=0;
    char i;
    for(i=0;i<j;i++)
        a[i]=S[5+j-1-i]-48;
        sum+=a[i]*pow(10,i);
    return sum;
void func(char *S,char LEN)
    char count;//
    unsigned int sum,i,j,k;
    if((LEN!=6)&(LEN!=7)&(LEN!=8)&(LEN!=9))
    {USART_SendStr("\r\n Erro input!!!\r\n");}
    else
        count=LEN-5;
        sum = translate(S,count);
        GPIO_SetBits(GPIOC,0x000000ff);
        for(k=0;k<3;k++)
            i=0x00000100;
            for(j=1;j<=8;j++)
                i>>=1;
                GPIO_ResetBits(GPIOC,i);
                delay_ms(50);
                GPIO_SetBits(GPIOC,i);
                delay_ms(sum);
void input_ASK()
    char j;
    func(rx_buff,rx_buff_count);
    rx_buff_count=0;
    for (j=0;j<rx_buff_count;j++)
    {rx_buff[j]='\0';}
    USART_SendStr("\n>");
int main(void)
    GPIO_INIT();
    USART_int(9600);
    GPIO_ResetBits(GPIOC,0x000000ff);  //LED灯亮
    delay_ms(200);
    GPIO_SetBits(GPIOC,0x000000ff); //LED灯灭
    USART_SendStr("SyStem booting......\r\n");
    USART_SendStr("\n>");//
    while(1)
void USART1_IRQHandler(void)
  while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
    if(USART_ReceiveData(USART1)==0x0d)
    {input_ASK();}
    else
        USART_SendData(USART1,USART_ReceiveData(USART1));
        rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
        rx_buff_count++;
    USART_ClearFlag(USART1, USART_FLAG_RXNE);
2014-12-23 16:33:07     打赏
18楼
2014-12-23 22:08:28     打赏
19楼
ADC调节RGB
#include
#define VREF 3.3
int volt;
unsigned int temp0,temp1,temp2;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
    SystemInit();
        - One Stop Bit
        - No parity
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
void PWM_Config()
  /* GPIOA  enable */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//PWM&RGB- PA1 PA2 PA3
  /* PWM1 Mode configuration: Channel2 ,PA1???2*/
    /* PWM1 Mode configuration: Channel3 PA2???3*/
    /* PWM1 Mode configuration: Channel4 PA3???4*/
void ADC_CONFIG(){
    ADC_InitTypeDef ADC_InitStructure;
    #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  /* ADCCLK = PCLK2/2 */
  RCC_ADCCLKConfig(RCC_PCLK2_Div2);
#else
  /* ADCCLK = PCLK2/4 */
#endif
ADC_DeInit(ADC1);
  /* Enable ADC1 and GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
    /* Configure PB0 (ADC Channel14) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;//ADC????PB0
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//??????
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//ADC?????
  ADC_InitStructure.ADC_NbrOfChannel = 1;//ADC????1
  ADC_Init(ADC1, &ADC_InitStructure);//???ADC1
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
int Get_ADC(){
     /* ADC1 regular channel configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);//??:8 ,????
    /* Enable ADC1 reset calibration register */
  ADC_ResetCalibration(ADC1);//??ADC1??????
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));//??????
  /* Start ADC1 calibration */
  ADC_StartCalibration(ADC1);//??ADC1??
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));//??????
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);//??ADC1??????
    return ADC_GetConversionValue(ADC1);
void PWM_TEST()
    /*????volt,??TIM_SetCompare2,TIM_SetCompare3,TIM_SetCompare4 ??????*/
    unsigned int temp0=volt,temp1=0,temp2=volt;
   for(;(temp0>0)||(temp10);temp0++,temp2--)//????  ????
       TIM_SetCompare2(TIM2, temp0);//temp0:0~volt
       TIM_SetCompare4(TIM2, temp2);//temp2:volt~0
       delay_us(1000);
for(;(temp1>0)||(temp2
视频:
视频地址:http://player.youku.com/player.php/sid/XODU1MjI1NzAw/v.swf
2014-12-25 11:46:31     打赏
20楼
板的焊接:
共24条 2/3 1 2 3 跳转至
