21号的作业,burden只能扔这里了。【更新: 时钟嘀嗒和18B20】
这是我制作的PCB图
焊之前的各种零件图已经最后的成品图。
最后说一下原理:我用的FT232的芯片,然后跳线帽控制VCC out的是5V还是3.3V,电源提示是红色LED灯,用绿色LED灯负极连接TX和RX,正极连1.5K电阻,电阻上拉到VCC in。这样可以在有数据传输的时候让绿色LED灯变亮。
/** ****************************************************************************** * @file GPIO/IOToggle/main.c * @author MCD Application Team * @version V3.5.0 * @date 08-April-2011 * @brief Main program body. ****************************************************************************** * @attention * * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. * * © COPYRIGHT 2011 STMicroelectronics ****************************************************************************** */ /* Includes ------------------------------------------------------------------*/ #include "stm32f10x.h" #include "stm32_eval.h" GPIO_InitTypeDef GPIO_InitStructure; void RCC_Configuration(void) { RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); RCC_HSEConfig(RCC_HSE_OFF); RCC_LSEConfig(RCC_LSE_OFF); RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2); } void GPIO_INIT() { //GPIOA(跑马灯)的初始化 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); //GPIOC(LED)的初始化 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4| GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); } //延时微秒 void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } //延时毫秒 void delay_ms(u32 n) { while(n--) delay_us(1000); } /** * @brief Main program. * @param None * @retval None */ int main(void) { RCC_Configuration(); GPIO_INIT(); while(1){ //LED转圈 GPIO_ResetBits(GPIOC,GPIO_Pin_3);//D4灯亮 delay_ms(50); GPIO_SetBits(GPIOC,GPIO_Pin_3);//D4灯灭 GPIO_ResetBits(GPIOC,GPIO_Pin_2);//D3灯亮 delay_ms(50); GPIO_SetBits(GPIOC,GPIO_Pin_2);//D3灯灭 GPIO_ResetBits(GPIOC,GPIO_Pin_1);//D2灯亮 delay_ms(50); GPIO_SetBits(GPIOC,GPIO_Pin_1);//D2灯灭 GPIO_ResetBits(GPIOC,GPIO_Pin_0);//D1灯亮 delay_ms(50); GPIO_SetBits(GPIOC,GPIO_Pin_0);//D1灯灭 GPIO_ResetBits(GPIOC,GPIO_Pin_4);//D5灯亮 delay_ms(50); GPIO_SetBits(GPIOC,GPIO_Pin_4);//D5灯灭 GPIO_ResetBits(GPIOC,GPIO_Pin_5);//D6灯亮 delay_ms(50); GPIO_SetBits(GPIOC,GPIO_Pin_5);//D6灯灭 GPIO_ResetBits(GPIOC,GPIO_Pin_6);//D7灯亮 delay_ms(50); GPIO_SetBits(GPIOC,GPIO_Pin_6);//D7灯灭 GPIO_ResetBits(GPIOC,GPIO_Pin_7);//D8灯亮 delay_ms(50); GPIO_SetBits(GPIOC,GPIO_Pin_7);//D8灯灭 //跑马灯不亮白色光 GPIO_ResetBits(GPIOA,GPIO_Pin_1);//蓝色亮 delay_ms(100); GPIO_SetBits(GPIOA,GPIO_Pin_1);//蓝色灭 GPIO_ResetBits(GPIOA,GPIO_Pin_2);//红色亮 delay_ms(100); GPIO_SetBits(GPIOA,GPIO_Pin_2);//红色灭 GPIO_ResetBits(GPIOA,GPIO_Pin_3);//绿色亮 delay_ms(100); GPIO_SetBits(GPIOA,GPIO_Pin_3);//绿色灭 GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2);//紫色灭 delay_ms(100); GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_2);//紫色亮 GPIO_ResetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3);//青色亮 delay_ms(100); GPIO_SetBits(GPIOA,GPIO_Pin_1|GPIO_Pin_3);//青色灭 GPIO_ResetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3);//黄色亮 delay_ms(100); GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3);//黄色灭 } }
LED和跑马灯的作业放同一代码了
有点强迫症,之前的只转一圈不好看,无聊加了个for循环给LED灯
有奖活动 | |
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
