啊。。。。技巧?!是有什么不严谨地方吗?
15楼
* @file GPIO/IOToggle/main.c
* @author MCD Application Team
* @version V3.5.0
* @date 08-April-2011
* @brief Main program body.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
© COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void GPIO_INIT()
//GPIOB(数码管)初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//按键初始化
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOC, &GPIO_InitStructure);
//微秒延时
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
//毫秒延时
void delay_ms(u32 n)
while(n--)
delay_us(1000);
* @brief Main program.
* @param None
* @retval None
int main(void)
int i,j,k;
RCC_Configuration();
GPIO_INIT();
GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管
while(1){
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))//S3键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){i++;}}//延时后S3处于按下状态,i++
if(i%2==0){ //如果i是偶数
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))//S1键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){j++;}}//延时后S1处于按下状态,j++
if(j>15){j=0;}
GPIO_ResetBits(GPIOB,GPIO_Pin_1);
GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
switch(j){
case 0 :
GPIO_SetBits(GPIOB,GPIO_Pin_1);
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8);
break;
case 1 :
GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
break;
case 2 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5);
break;
case 3 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5);
break;
case 4 :
GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5);
break;
case 5 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5);
break;
case 6 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5);
break;
case 7 :
GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
break;
case 8 :
GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
break;
case 9 :
GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
break;
case 10 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8);
GPIO_SetBits(GPIOB,GPIO_Pin_15);
delay_ms(1);
GPIO_ResetBits(GPIOB,GPIO_Pin_15);
GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
break;
case 11 :
delay_ms(1);
delay_ms(1);
break;
case 12 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5);
delay_ms(1);
break;
case 13 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5);
delay_ms(1);
break;
case 14 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5);
delay_ms(1);
break;
case 15 :
delay_ms(1);
GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5);
delay_ms(1);
break;
if(i%2==1){//如果i是奇数
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2键按下
{delay_ms(80);
if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){k++;}}//延时后S2处于按下状态,j++
if(k>15){k=0;}
switch(k){
case 0 :
break;
case 1 :
break;
case 2 :
break;
case 3 :
break;
case 4 :
break;
case 5 :
break;
case 6 :
break;
case 7 :
break;
case 8 :
break;
case 9 :
break;
case 10 :
delay_ms(1);
delay_ms(1);
break;
case 11 :
delay_ms(1);
delay_ms(1);
break;
case 12 :
delay_ms(1);
delay_ms(1);
break;
case 13 :
delay_ms(1);
delay_ms(1);
break;
case 14 :
delay_ms(1);
delay_ms(1);
break;
case 15 :
delay_ms(1);
delay_ms(1);
break;
17楼
啊。。。动态扫描有啊,在数码管显示双位数时是的,只不过我延时只有1ms。
不过还是有地方不明白,我觉得都在main函数有点乱
尝试把两个按键记数用void func()的方法放在main外面,后面再用main函数里调用时却没法实现记数功能了。
19楼
我试着把按键记数在main函数计算好,然后通过一个形式参数传到void里面,解决了。
那老师我要不要把动态扫描弄慢点拍个新视频,顺便把新整理的代码再放上来?
