电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 21号的作业,burden只能扔这里了。【更新: 时钟嘀嗒和18B20】
共54条 2/6 ‹ 1 2 3 4 5 6 › ›| 跳转至页
2014-10-21 21:42:16     打赏
11楼
啊。。。。技巧?!是有什么不严谨地方吗?
2014-10-21 21:45:50     打赏
12楼
程序逻辑上基本没有错误,功能上也正常
不过,有没有考虑过用更加简短的语句来实现这个功能?
这个对C语言的使用技巧有相对较高的要求
2014-10-21 21:49:17     打赏
13楼
要简短的话以后要多努力了
2014-10-21 21:50:23     打赏
14楼
对的,是个积累的过程,不是三言两语可以解释清楚的
2014-10-26 13:37:19     打赏
15楼
  * @file    GPIO/IOToggle/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
	© COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void GPIO_INIT()
   //GPIOB(数码管)初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  //按键初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
//微秒延时
void delay_us(u32 n)
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
//毫秒延时
void  delay_ms(u32 n)
	while(n--)
	delay_us(1000);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
    int i,j,k;
    RCC_Configuration();
    GPIO_INIT();
    GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管
	  while(1){
		    if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))//S3键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){i++;}}//延时后S3处于按下状态,i++
		if(i%2==0){ //如果i是偶数
		     if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))//S1键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){j++;}}//延时后S1处于按下状态,j++
		if(j>15){j=0;}
		   GPIO_ResetBits(GPIOB,GPIO_Pin_1);
		   GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
		switch(j){
		 case 0 :
			 GPIO_SetBits(GPIOB,GPIO_Pin_1);
			 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8);
		 break;
		 case 1 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
		 break;
			case 2 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5);
			break;
			case 3 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5);
			break;
			case 4 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5);
			break;
			case 5 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5);
			break;
			case 6 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5);
			break;
			case 7 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
			break;
			case 8 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
			break;
			case 9 :
			 GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
			break;
			case 10 :
		          delay_ms(1);
		          GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8);
		          GPIO_SetBits(GPIOB,GPIO_Pin_15);
		          delay_ms(1);
		          GPIO_ResetBits(GPIOB,GPIO_Pin_15);
		          GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
			break;
			case 11 :
		          delay_ms(1);
		          delay_ms(1);
			break;
			case 12 :
		          delay_ms(1);
		          GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5);
		          delay_ms(1);
			break;
			case 13 :
		          delay_ms(1);
		          GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5);
		          delay_ms(1);
			break;
			case 14 :
		          delay_ms(1);
		         GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5);
		         delay_ms(1);
			break;
			case 15 :
		          delay_ms(1);
		          GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5);
		          delay_ms(1);
			break;
      if(i%2==1){//如果i是奇数
		     if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){k++;}}//延时后S2处于按下状态,j++
		if(k>15){k=0;}
		switch(k){
		 case 0 :
		 break;
		 case 1 :
		 break;
			case 2 :
			break;
			case 3 :
			break;
			case 4 :
			break;
			case 5 :
			break;
			case 6 :
			break;
			case 7 :
			break;
			case 8 :
			break;
			case 9 :
			break;
			case 10 :
		          delay_ms(1);
		          delay_ms(1);
			break;
			case 11 :
		          delay_ms(1);
		          delay_ms(1);
			break;
			case 12 :
		          delay_ms(1);
		          delay_ms(1);
			break;
			case 13 :
		          delay_ms(1);
		          delay_ms(1);
			break;
			case 14 :
		          delay_ms(1);
		          delay_ms(1);
			break;
			case 15 :
		          delay_ms(1);
		          delay_ms(1);
			break;
2014-10-26 15:02:58     打赏
16楼
不错,大部分完成了
不过说好的动态扫瞄显示呢?
2014-10-26 17:21:15     打赏
17楼
啊。。。动态扫描有啊,在数码管显示双位数时是的,只不过我延时只有1ms。
不过还是有地方不明白,我觉得都在main函数有点乱
尝试把两个按键记数用void func()的方法放在main外面,后面再用main函数里调用时却没法实现记数功能了。
2014-10-26 21:59:13     打赏
18楼
有画过程序流程图的话,应该比较清晰的
2014-10-26 23:08:18     打赏
19楼
我试着把按键记数在main函数计算好,然后通过一个形式参数传到void里面,解决了。
那老师我要不要把动态扫描弄慢点拍个新视频,顺便把新整理的代码再放上来?
2014-10-27 11:47:34     打赏
20楼
上
