啊。。。。技巧?!是有什么不严谨地方吗?
15楼
/** ****************************************************************************** * @file GPIO/IOToggle/main.c * @author MCD Application Team * @version V3.5.0 * @date 08-April-2011 * @brief Main program body. ****************************************************************************** * @attention * * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. * * © COPYRIGHT 2011 STMicroelectronics ****************************************************************************** */ /* Includes ------------------------------------------------------------------*/ #include "stm32f10x.h" #include "stm32_eval.h" GPIO_InitTypeDef GPIO_InitStructure; void RCC_Configuration(void) { RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI); RCC_HSEConfig(RCC_HSE_OFF); RCC_LSEConfig(RCC_LSE_OFF); RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); // 72HMz RCC_PLLCmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); RCC_ADCCLKConfig(RCC_PCLK2_Div4); RCC_PCLK2Config(RCC_HCLK_Div1); RCC_PCLK1Config(RCC_HCLK_Div2); RCC_HCLKConfig(RCC_SYSCLK_Div1); RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); while(RCC_GetSYSCLKSource() != 0x08); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD,GPIO_Pin_2); } void GPIO_INIT() { //GPIOB(数码管)初始化 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOB, &GPIO_InitStructure); //按键初始化 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOC, &GPIO_InitStructure); } //微秒延时 void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } //毫秒延时 void delay_ms(u32 n) { while(n--) delay_us(1000); } /** * @brief Main program. * @param None * @retval None */ int main(void) { int i,j,k; RCC_Configuration(); GPIO_INIT(); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管 while(1){ if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))//S3键按下 {delay_ms(80); if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){i++;}}//延时后S3处于按下状态,i++ if(i%2==0){ //如果i是偶数 if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))//S1键按下 {delay_ms(80); if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){j++;}}//延时后S1处于按下状态,j++ if(j>15){j=0;} GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); switch(j){ case 0 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8); break; case 1 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 2 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5); break; case 3 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); break; case 4 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); break; case 5 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); break; case 6 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5); break; case 7 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12); break; case 8 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 9 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break; case 10 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 11 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 12 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 13 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 14 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 15 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; } } if(i%2==1){//如果i是奇数 if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2键按下 {delay_ms(80); if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){k++;}}//延时后S2处于按下状态,j++ if(k>15){k=0;} GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); switch(k){ case 0 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8); break; case 1 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 2 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5); break; case 3 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); break; case 4 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); break; case 5 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); break; case 6 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5); break; case 7 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12); break; case 8 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14); break; case 9 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break; case 10 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 11 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 12 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 13 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 14 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; case 15 : GPIO_SetBits(GPIOB,GPIO_Pin_1); GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5); GPIO_SetBits(GPIOB,GPIO_Pin_15); GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); delay_ms(1); GPIO_ResetBits(GPIOB,GPIO_Pin_15); GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12); break; } } } }
17楼
啊。。。动态扫描有啊,在数码管显示双位数时是的,只不过我延时只有1ms。
不过还是有地方不明白,我觉得都在main函数有点乱
尝试把两个按键记数用void func()的方法放在main外面,后面再用main函数里调用时却没法实现记数功能了。
19楼
我试着把按键记数在main函数计算好,然后通过一个形式参数传到void里面,解决了。
那老师我要不要把动态扫描弄慢点拍个新视频,顺便把新整理的代码再放上来?
有奖活动 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
