电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 时钟滴答-这是08的作业
共36条 4/4 |‹ 1 2 3 4 跳转至
2014-12-25 16:42:17     打赏
31楼
时钟滴答:
  * @file    EXTI/EXTI_Config/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
    ?COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
//#include "delay.h"
#include <stdio.h>
volatile int flag;
#define Set_B20()    GPIO_SetBits(GPIOC, GPIO_Pin_12)
#define Reset_B20()  GPIO_ResetBits(GPIOC, GPIO_Pin_12)
#define Read_B20()   GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)
unsigned char Error_Flag=0;
unsigned char zf=0;
void SysTick_Configuration(void)
  /* Setup SysTick Timer for 10 msec interrupts  */
  if (SysTick_Config(48000))                //SysTick??
    /* Capture error */
    while (1);
 /* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);                       //SysTick?????
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef   GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
    //******48MHZ*******//
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_6);//6*8=24MHz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);        //检查指定的RCC标志位(PLL)设置与否
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);                     //设置ADC时钟频率
  RCC_PCLK2Config(RCC_HCLK_Div1);                       //  APB2=HCLK/1   PCLK2=HCLK/1
  RCC_PCLK1Config(RCC_HCLK_Div2);            /// APB1=HCLK/2    PCLK1=HCLK/2
  RCC_HCLKConfig(RCC_SYSCLK_Div1);         //  AHB使用系统时钟  HCLK=SYSCLK
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);       // 配置系统时钟
  while(RCC_GetSYSCLKSource() != 0x08)        //检查是否将HES 6倍频后作为系统时钟
//  SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//LED
  GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //TIM2
void USART_int(long BaudRate)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void delay_18b20(u32 nus)    //18b20延时
    u16 i;
    while(nus--)
        for(i=12;i>0;i--);
void delay_us(u32 n) //延时
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
void Init18B20(void)  //18B20
   u8 aa=0;
   u8 count =0;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能GPIOC时钟
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出
   Set_B20() ;   // GPIO_SetBits(GPIOC, GPIO_Pin_12)
   delay_18b20(1);
   Reset_B20(); // GPIO_ResetBits(GPIOC, GPIO_Pin_12)
   delay_18b20(480);
   Set_B20();
//  delay_18b20(500);
   delay_18b20(480);
    count=0;
    aa=Read_B20();         //读取温度
    while(!aa && count<100) //温度不宜超过99°C
    aa=Read_B20();
    count++;
   if(count>=99)
        Error_Flag=1;
    else
        Error_Flag=0;
unsigned char Read18B20(void)//读数据
unsigned char i=0;
unsigned char date=0;
u8 tempp;
   for(i=8;i>0;i--)
   date>>=1;    //右移一位
   delay_18b20(1);
   Set_B20();    //置1
    delay_18b20(1);
   tempp=Read_B20(); //读取温度
   if(tempp)
        date|=0x80;// 1000 0000将最高位填1 ,然后右移,每次最高位由0变1,使8位全部传递完毕 0xff = 1111 1111
    delay_18b20(60);
    return(date);
void Write18B20(unsigned char date)//写数据
    unsigned char i=0;
    for (i=8; i>0; i--)
        Reset_B20(); //置0
        delay_18b20(1);
        if(date & 0x01)
            Set_B20();
        else
        {   Reset_B20();}
        delay_18b20(60);
        date>>=1;       //数据右移一位
         Set_B20();
         delay_18b20(1);
    delay_18b20(15);
 float Read_T()//读温度
        unsigned char TUp,TDown;
    unsigned char fTemp;
    u8 TT=0;
     float Temp = 0;
    Init18B20();     //18B20的初始化
    Write18B20(0xcc);//写指令:跳过ROM,仅一个DS18B20
    Write18B20(0x44);//启动温度转换
    Init18B20();
    Write18B20(0xbe);//读暂存寄存器
    TDown = Read18B20();//低字节
    TUp = Read18B20();//高字节
    if(TUp>0x7f)
        TDown=~TDown;
        TUp=~TUp+1;
        TUp/=8;
        zf=1;
    else
        zf=0;
    fTemp=TDown&0x0f;
    TUp<<=4;
    TDown>>=4;
    TT=TUp|TDown;
    Temp=TT+(float)fTemp/16;
    return(Temp);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
    char ID[8];
    int i;
  RCC_Configuration();
  USART_int(115200);
    SysTick_Configuration();
    printf(" config done...\r\n");
    delay_ms(1000);
    Init18B20();
    Write18B20(0x33);
    delay_18b20(20);
    for(i=0;i<8;i++)
        ID[i] = Read18B20();
    while(1)
        if(flag == 300)
            printf("At the moment of ID is:");// 每300ms输出ID
            for(i=0;i<8;i++)
          printf("%x",ID[i]);
            printf("\r\n")  ;
        if(flag == 500)
            printf("The Temperature is:%f\r\n",Read_T());//每500ms输出温度
            printf("===================================================\r\n");
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2014-12-25 18:41:02     打赏
32楼
2014-12-25 18:43:20     打赏
33楼
焊板图片:
2014-12-25 23:12:17     打赏
34楼
程序测试:
2014-12-25 23:15:30     打赏
35楼
用ADC写满一页,全部输出:
#include <stm32f10x.h>
#include <stdio.h>
#include "spi_flash.h"
#define VREF 3.3
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define RxBufferSize1   (countof(TxBuffer1) - 1)
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define  FLASH_WriteAddress     0x00000
#define  FLASH_ReadAddress      FLASH_WriteAddress
#define  FLASH_SectorToErase    FLASH_WriteAddress
#define  sFLASH_ID              0xEF3015     //W25X16
//#define  sFLASH_ID              0xEF4015   //W25Q16
#define buff_size  16;
char rx_buff_count=0;
uint8_t Tx_Buffer[4096] ;  //????
uint8_t Rx_Buffer[BufferSize];  //????
__IO uint32_t DeviceID = 0;  //??ID
__IO uint32_t FlashID = 0; //??ID
__IO TestStatus TransferStatus1 = FAILED;  //????
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
char *int_to_string(int number,char *strnum)//??????????
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
for(i=0;i<n/2;i++)
temp=*(strnum+j+i-n);
*(strnum+j+i-n)=*(strnum+j-i-1);
*(strnum+j-i-1)=temp;
strnum[n]='\0';
return strnum;
  RCC_DeInit();
  RCC_DeInit();//?RCC?????????
  RCC_HSICmd(ENABLE);//????????
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//HSI????reset
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);//??HSI??????
  RCC_HSEConfig(RCC_HSE_OFF);//HSE???
  RCC_LSEConfig(RCC_LSE_OFF);//LSE???
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);//??PLL??
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);//ADC??=PCLK/4
  RCC_PCLK2Config(RCC_HCLK_Div1);//APB2??=HCLK
  RCC_PCLK1Config(RCC_HCLK_Div2);//APB1??=HCLK/2
  RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB??=????
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//??PLL??????
  while(RCC_GetSYSCLKSource() != 0x08);
  GPIO_ResetBits(GPIOD,GPIO_Pin_2);//?????
        - One Stop Bit
        - No parity
  USART_InitStructure.USART_BaudRate = BaudRate;//usart?????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//??????1????
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//???????
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//????,????
  USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//???????
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;//?????
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//????????????
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//???????????SCLK??
  USART_ClockInit(USART1, &USART_ClockInitStructure);//??USART1??
  USART_Init(USART1, &USART_InitStructure);//???USART1
  USART_Cmd(USART1, ENABLE);//??USART1??
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//????
  while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
  for(; nCount != 0; nCount--);
void ADC_CONFIG(){
    ADC_InitTypeDef ADC_InitStructure;
    #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  /* ADCCLK = PCLK2/2 */
  RCC_ADCCLKConfig(RCC_PCLK2_Div2);
#else
  /* ADCCLK = PCLK2/4 */
#endif
ADC_DeInit(ADC1);
  /* Enable ADC1 and GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
    /* Configure PB0 (ADC Channel14) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
int Get_ADC(){
     /* ADC1 regular channel configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);
    /* Enable ADC1 reset calibration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
    return ADC_GetConversionValue(ADC1);
void SPI_TEST()
    int i=0;
    int ADValue = 0;
    float Volt=0.00;
//    char shuzu[100];
    for(i=0;i<5;i++){
      ADValue = Get_ADC();
      Volt = VREF*ADValue/4095;
      printf("===============================\r\n");
      printf("The ADC value is:%d\r\n",ADValue);
      printf("The Volt is:%f V\r\n",Volt);
      delay_ms(500);
    printf("\r\n????2M SPI??flash(W25X16)?? \r\n");
    SPI_FLASH_Init();
    /* Get SPI Flash Device ID */
    DeviceID = SPI_FLASH_ReadDeviceID();
    Delay( 200 );
    /* Get SPI Flash ID */
    FlashID = SPI_FLASH_ReadID();
    printf("\r\n FlashID is 0x%X,  Manufacturer Device ID is 0x%X\r\n", FlashID, DeviceID);
    /* Check the SPI Flash ID */
    if (FlashID == sFLASH_ID)  /* #define  sFLASH_ID  0xEF3015 */
        printf("\r\n ?????flash W25X16 !\r\n");
        /* Erase SPI FLASH Sector to write on */
        SPI_FLASH_SectorErase(FLASH_SectorToErase);
        SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
        printf("\r\n??????:%s \r\t", Tx_Buffer);
        SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
        printf("\r\n??????:%s \r\n", Rx_Buffer);
        TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
        if( PASSED == TransferStatus1 )
            printf("\r\n 2M SPI??flash(W25X16)????!\n\r");
        else
    }// if (FlashID == sFLASH_ID)
    else
        printf("\r\n ???? W25X16 ID!\n\r");
    SPI_Flash_PowerDown();
    printf("\r\n=================================================\n\r");
int main(void)
  USART_int(115200);
  ADC_CONFIG();
  Get_ADC();
  delay_ms(1000);
  while(1){
    SPI_TEST();
    delay_ms(1000);
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
  while (1)
#endif
2015-01-06 21:18:01     打赏
36楼
其实也是个不错的帖子,但是没有看到热情啊
