电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 【作业完成】06作业本
共38条 4/4 |‹ ‹ 1 2 3 4 跳转至页
2014-12-24 22:53:06     打赏
31楼
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
#define VREF 3.3
GPIO_InitTypeDef   GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
    SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
void PWM_Config()
{uint16_t PrescalerValue = 0;
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
    /* TIM2 clock enable */
  /* GPIOA  enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO  , ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
        TIM_Cmd(TIM2, ENABLE);
      /* Compute the prescaler value */
  PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 0x07FF;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
    /* PWM1 Mode configuration: Channel3 */
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
    /* PWM1 Mode configuration: Channel4 */
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  TIM_ARRPreloadConfig(TIM2, ENABLE);
void ADC_CONFIG(){
    ADC_InitTypeDef ADC_InitStructure;
    #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  RCC_ADCCLKConfig(RCC_PCLK2_Div2);
#else
  /* ADCCLK = PCLK2/4 */
#endif
ADC_DeInit(ADC1);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  ADC_DMACmd(ADC1, ENABLE);
  ADC_Cmd(ADC1, ENABLE);
int Get_ADC(){
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);
  ADC_ResetCalibration(ADC1);
  while(ADC_GetResetCalibrationStatus(ADC1));
  ADC_StartCalibration(ADC1);
  while(ADC_GetCalibrationStatus(ADC1));
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
    return ADC_GetConversionValue(ADC1);
void PWM_TEST()
    float Volt=0.00;
    unsigned int temp0,temp1,temp2,ADValue = 0;
    while(1)
      ADValue = Get_ADC();
        Volt = VREF*ADValue/4095;
        printf("===============================\r\n");
        printf("The ADC value is:%d\r\n",ADValue);
        printf("The Volt is:%f V\r\n",Volt);
      TIM_SetCompare2(TIM2, temp0);
      TIM_SetCompare3(TIM2, temp1);
      TIM_SetCompare4(TIM2, temp2);
        if(ADValue>3000)
         {  temp0=ADValue/2-1300;temp1=ADValue/2-700;temp2=ADValue/2-150;
         }if(2000<ADValue<=3000)
        {  temp0=ADValue/2-300;temp1=ADValue/2-900;temp2=ADValue/2-50;
        }if(1000<ADValue<=2000)
        {  temp0=ADValue/2+900;temp1=ADValue/2;temp2=ADValue/2-500;
        }if(ADValue<=1000)
        {  temp0=ADValue+100;temp1=ADValue+600;temp2=ADValue+1000;
            delay_ms(50);
int main(void)
    RCC_Configuration();
  USART_int(115200);
    ADC_CONFIG();
    printf(" config done...\r\n");
    Get_ADC();
    PWM_Config();
    delay_ms(200);
    while(1)
        PWM_TEST();
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-12-24 22:53:35     打赏
32楼
2014-12-24 22:56:07     打赏
33楼
楼主下次可以试试DMA模式了,大数据传输很好用
2014-12-25 17:41:33     打赏
34楼
//#include "delay.h"
#include <stdio.h>
volatile int flag;
#define Set_B20()    GPIO_SetBits(GPIOC, GPIO_Pin_12)
#define Reset_B20()  GPIO_ResetBits(GPIOC, GPIO_Pin_12)
#define Read_B20()   GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)
unsigned char Error_Flag=0;
unsigned char zf=0;
unsigned char ID[8];
void SysTick_Configuration(void)
  /* Setup SysTick Timer for 10 msec interrupts  */
  if (SysTick_Config(48000))                //SysTick??
    /* Capture error */
    while (1);
 /* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_6);
  RCC_PLLCmd(ENABLE);
        - One Stop Bit
        - No parity
void delay_18b20(u32 nus)
    u16 i;
    while(nus--)
        for(i=12;i>0;i--);
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
void Init18B20(void)
   u8 aa=0;
   u8 count =0;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
   Set_B20() ;
   delay_18b20(1);
   Reset_B20();
   delay_18b20(480);
   Set_B20();
//  delay_18b20(500);
   delay_18b20(480);
    count=0;
    aa=Read_B20();     //???
    while(!aa && count<100)
    aa=Read_B20();
    count++;
   if(count>=99)
        Error_Flag=1;
    else
        Error_Flag=0;
unsigned char Read18B20(void)
unsigned char i=0;
unsigned char date=0;
u8 tempp;
   for(i=8;i>0;i--)
   Reset_B20();
   date>>=1;
   delay_18b20(1);
   Set_B20();
    delay_18b20(1);
   tempp=Read_B20();
   if(tempp)
        date|=0x80;   //
    delay_18b20(60);
    return(date);
void Write18B20(unsigned char date)
    unsigned char i=0;
    for (i=8; i>0; i--)
        Reset_B20();
        delay_18b20(1);
        if(date & 0x01)
            Set_B20();
        else
        {   Reset_B20();}
        delay_18b20(60);
        date>>=1;
         Set_B20();
         delay_18b20(1);
    delay_18b20(15);
 float Read_T()     //???
        unsigned char TUp,TDown;
    unsigned char fTemp;
    u8 TT=0;
     float Temp = 0;
    Init18B20();
    Write18B20(0xcc);
    Write18B20(0x44);
    Init18B20();
    Write18B20(0xcc);
    Write18B20(0xbe);
    TDown = Read18B20();
    TUp = Read18B20();
    if(TUp>0x7f)
        TDown=~TDown;
        TUp=~TUp+1;
        TUp/=8;
        zf=1;
    else
        zf=0;
    fTemp=TDown&0x0f;
    TUp<<=4;
    TDown>>=4;
    TT=TUp|TDown;
    Temp=TT+(float)fTemp/16;
    return(Temp);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
    int i=0;
  USART_int(115200);
    SysTick_Configuration();
    Init18B20();                //18B20???
    Write18B20(0x33);     //
  for(;i<8;i++)
        ID[i]=Read18B20();   //??18b20????????
    delay_ms(1000);
    while(1)
    {  flag++;
        if(flag==300)   //?300ms??????
            printf("The ID is:\n");
             for(;i<8;i++)
            printf("%x",ID[i]);
     printf("\n");
        if(flag == 500){     //?500 ms?????
            printf("The Temperature is:%f\r\n",Read_T());//????
            printf("\r\n");
            flag=0;
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
  /* Infinite loop */
  while (1)
#endif
2014-12-25 17:49:15     打赏
35楼
2014-12-25 22:54:40     打赏
36楼
#include <stdio.h>
#include "spi_flash.h"
#define VREF 3.3
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
#define TxBufferSize1   (countof(TxBuffer1) - 1)
#define RxBufferSize1   (countof(TxBuffer1) - 1)
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
#define  FLASH_WriteAddress     0x00000
#define  FLASH_ReadAddress      FLASH_WriteAddress
#define  FLASH_SectorToErase    FLASH_WriteAddress
#define  sFLASH_ID              0xEF3015
//#define  sFLASH_ID              0xEF4015
#define buff_size  16;
char rx_buff[],rx_buff_count=0;
uint8_t Tx_Buffer[4096] ;
uint8_t Rx_Buffer[BufferSize];
__IO uint32_t DeviceID = 0;
__IO uint32_t FlashID = 0;
__IO TestStatus TransferStatus1 = FAILED;
void Delay(__IO uint32_t nCount);
TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
char *int_to_string(int number,char *strnum)
int j=0,i=0,n=0;
char temp;
while(number>0)
*(strnum+j)=number%10+48;
j++;
number=number/10;
n++;
for(i=0;i<n/2;i++)
temp=*(strnum+j+i-n);
*(strnum+j+i-n)=*(strnum+j-i-1);
*(strnum+j-i-1)=temp;
strnum[n]='\0';
return strnum;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
        - One Stop Bit
        - No parity
  while(BufferLength--)
    if(*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
  for(; nCount != 0; nCount--);
void ADC_CONFIG(){
  /* ADCCLK = PCLK2/2 */
#else
#endif
ADC_DeInit(ADC1);
  /* Enable ADC1 and GPIOC clock */
    /* Configure PB0 (ADC Channel14) as analog input -------------------------*/
  /* ADC1 configuration ------------------------------------------------------*/
  /* Enable ADC1 DMA */
  /* Enable ADC1 */
int Get_ADC(){
void SPI_TEST()
    printf("\r\n这是一个2M SPI总线flash(W25X16)测试 \r\n");
    SPI_FLASH_Init();
    /* Get SPI Flash Device ID */
    DeviceID = SPI_FLASH_ReadDeviceID();
    Delay( 200 );
    /* Get SPI Flash ID */
    FlashID = SPI_FLASH_ReadID();
    printf("\r\n FlashID is 0x%X,  Manufacturer Device ID is 0x%X\r\n", FlashID, DeviceID);
    /* Check the SPI Flash ID */
    if (FlashID == sFLASH_ID)  /* #define  sFLASH_ID  0xEF3015 */
        printf("\r\n 检测到华邦flash W25X16 !\r\n");
        /* Erase SPI FLASH Sector to write on */
        SPI_FLASH_SectorErase(FLASH_SectorToErase);
        /*写缓存并发送*/
        SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
        printf("\r\n写入的数据是:%s \r\t", Tx_Buffer);
        /* 读出刚才写入的数据*/
        SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
        printf("\r\n读出的数据是:%s \r\n", Rx_Buffer);
        TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
        if( PASSED == TransferStatus1 )
            printf("\r\n 2M SPI总线flash(W25X16)测试成功!\n\r");
        else
            printf("\r\n 2M SPI总线flash(W25X16)测试失败!\n\r");
    }// if (FlashID == sFLASH_ID)
    else
        printf("\r\n 未检测到 W25X16 ID!\n\r");
    SPI_Flash_PowerDown();
    printf("\r\n=================================================\n\r");
/* Private functions ---------------------------------------------------------*/
int main(void)
    int i=0;
    int ADValue = 0;
     char Buffer[100];
  USART_int(115200);
    ADC_CONFIG();
    delay_ms(1000);
    while(1)
        for(i=0;i<5;i++)
              int_to_string(ADValue,Buffer);
            Tx_Buffer[i]=Buffer[i];
      SPI_TEST();
        delay_ms(1000);
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-12-25 22:56:01     打赏
37楼
2015-01-06 21:15:57     打赏
38楼
大赶工啊,呵呵
