电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 30号作业 【 更新】外部中断清零和iic上电计数.
共41条 3/5 ‹ 1 2 3 4 5 › 跳转至页
2014-11-11 12:31:51     打赏
21楼
大哥是谁??llol一霸??
2014-11-12 11:17:57     打赏
22楼
又是判断固定数值的......
2014-11-12 12:53:54     打赏
23楼
不懂怎么把字符去掉啊,可不可以提示一下.
2014-11-14 18:22:59     打赏
24楼
只能有50,100,1000的延时??
2014-11-24 13:04:52     打赏
25楼
stm32外部中断和按键控制led灯视频:
stm32 串口调试助手:
stm32外部中断代码(软件去抖动):
  * @file    EXTI/EXTI_Config/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
EXTI_InitTypeDef   EXTI_InitStructure;
GPIO_InitTypeDef   GPIO_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
/* Private function prototypes -----------------------------------------------*/
void EXTIkeyS1_Config(void);
void EXTIkeyS2_Config(void);
void EXTIkeyS3_Config(void);
void EXTIkeyS4_Config(void);
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
void USART_int(long BaudRate)
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
	USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
	USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Configure four bit for preemption priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
  /* Enable the USART1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
void delay_us(u32 n)
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
void  delay_ms(u32 n)
	while(n--)
	delay_us(1000);
int main(void)
{RCC_Configuration();
  /* Configure PA.00 in interrupt mode */
  EXTIkeyS1_Config();
  /* Configure PB.09 or PG.08 in interrupt mode */
  EXTIkeyS2_Config();
	 EXTIkeyS3_Config();
	 EXTIkeyS4_Config();
USART_int(115200);
	printf("Config done,waiting for interrupt......\r\n");
  while (1)
  * @brief  Configure PA.00 in interrupt mode
  * @param  None
  * @retval None
  /* Enable GPIOA clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  /* Configure PA.00 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  /* Enable AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  /* Connect EXTI0 Line to PA.00 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
  /* Configure EXTI0 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line8;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set EXTI0 Interrupt to the lowest priority */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  * @brief  Configure PB.09 or PG.08 in interrupt mode
  * @param  None
  * @retval None
  /* Enable GPIOB clock */
  /* Configure PB.09 pin as input floating */
  /* Connect EXTI9 Line to PB.09 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource9);
  /* Configure EXTI9 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line9;
  /* Enable and set EXTI9_5 Interrupt to the lowest priority */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource10);
  EXTI_InitStructure.EXTI_Line = EXTI_Line10;
  NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource11);
  EXTI_InitStructure.EXTI_Line = EXTI_Line11;
/*            STM32F10x Peripherals Interrupt Handlers                        */
  * @brief  This function handles External lines 9 to 5 interrupt request.
  * @param  None
  * @retval None
void EXTI9_5_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line9) != RESET)
			delay_ms(200);
    /* Toggle LED2 */
     GPIO_SetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
printf("ÍⲿÖжÏS2´ò¿ª ......\r\n");
    /* Clear the  EXTI line 9 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line9);
	if(EXTI_GetITStatus(EXTI_Line8) != RESET)
    /* Toggle LED1 */
			delay_ms(200);
     GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
printf("ÍⲿÖжÏS1´ò¿ª ......\r\n");
    /* Clear the  EXTI line 0 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line8);
void EXTI15_10_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line10) != RESET)
  { delay_ms(200);
    /* Toggle LED2 */
  GPIO_ResetBits(GPIOC,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  printf("ÍⲿÖжÏS3´ò¿ª ......\r\n");
    EXTI_ClearITPendingBit(EXTI_Line10);
	if(EXTI_GetITStatus(EXTI_Line11) != RESET)
    /* Toggle LED1 */
		delay_ms(200);
      GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3);
printf("ÍⲿÖжÏS4´ò¿ª ......\r\n");
    EXTI_ClearITPendingBit(EXTI_Line11);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2014-11-25 21:39:58     打赏
26楼
建议一下
中断服务里面,还是不要使用延时。
2014-11-25 21:40:54     打赏
27楼
可以嵌套个定时器中断来处理
2014-11-27 14:11:07     打赏
28楼
stm32定时器视频:
stm32定时器代码:
  * @version V3.5.0
  * @attention
	© COPYRIGHT 2011 STMicroelectronics
#include
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
long flag,temp,num;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
	SystemInit();
	GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
	  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
		RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
			RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE);
        - One Stop Bit
        - No parity
void NVIC_Configuration(void)
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
	  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
	  NVIC_InitStructure.NVIC_IRQChannel = TIM7_IRQn;
	/* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 24000;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
	/*NVIC_InitStructure.NVIC_IRQChannel =TIM8_CC_IRQn;
	  NVIC_Init(&NVIC_InitStructure);*/
  * @param  None
  * @retval None
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
	while(n--)
	delay_us(1000);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
NVIC_Configuration();
USART_int(115200);
	printf(" config done...\r\n");
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
	 TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE );
	 TIM_TimeBaseInit(TIM7, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM7,TIM_IT_Update,ENABLE );
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
	 TIM_Cmd(TIM3, ENABLE);
	 	 TIM_Cmd(TIM7, ENABLE);
  while (1){
		if(flag == 2000)
		{printf("TIM2 interrupt......\r\n");
    flag = 0;
    GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3);
			//delay_ms(80)
		if(temp == 3000)
		{printf("TIM3 interrupt......\r\n");
    temp = 0;
	if(num == 1000)
		{printf("TIM7 interrupt......\r\n");
    num = 0;
  /*GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
		delay_ms(150);*/
void TIM2_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //?? TIM3 ????????
TIM_ClearITPendingBit(TIM2, TIM_IT_Update ); //?? TIM3 ??????
	flag++;
void TIM3_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //?? TIM3 ????????
TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //?? TIM3 ??????
	temp++;
void TIM7_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM7, TIM_IT_Update) != RESET) //?? TIM3 ????????
TIM_ClearITPendingBit(TIM7, TIM_IT_Update ); //?? TIM3 ??????
	num++;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-11-27 14:12:34     打赏
29楼
stm32定时器中断代码:
  * @version V3.5.0
  * @attention
#include <stdio.h>
long flag,temp,num;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
	SystemInit();
        - One Stop Bit
        - No parity
  * @param  None
  * @retval None
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
	while(n--)
	delay_us(1000);
int main(void)
USART_int(115200);
  while (1){
		if(flag == 2000)
    flag = 0;
			//delay_ms(80)
		if(temp == 3000)
    temp = 0;
	if(num == 1000)
    num = 0;
		delay_ms(150);*/
	flag++;
	temp++;
	num++;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-11-27 23:16:08     打赏
30楼
看代码是那么回事
不过,显示效果似乎不是很能区分这几个定时器的作用啊
